  3. Domoticz
  4. Domoticz and ACK
Domoticz and ACK
9 Posts 4 Posters 6.4k Views 3 Watching
  • Y
    Y
    yury
    wrote on last edited by yury
    Is there any way to make Domoticz read back acknowledgements from relay nodes when you turn them on or off? Like when you press on and if radio fails GUI icon will show as it is off.
    • N
      N
      NewFolk
      wrote on last edited by NewFolk
      Hello @yury
      Did you find workaround ?
      You could ask gizmocuz for help.
      https://www.domoticz.com/forum/viewtopic.php?f=42&t=7839&p=58270#p58270
      • Y
        Y
        yury
        Hello @NewFolk !
        Not yet.
        Thanks for your post in domoticz forum!
        • N
          N
          NewFolk
          Great news guys!!!
          Take a look at Beta version #3448.
          http://www.domoticz.com/forum/viewtopic.php?f=42&t=7839&p=59180#p59163
          • Y
            Y
            yury
            Super!!!
            One little issue I found so far. If there is a repeater used between the node and the gateway, somehow domoticz accept ack from from repeater even if node is off line.
            Otherwise it works very nice.
            • N
              N
              NewFolk
              Are you sure? Post it on domoticz forum. I can`t test this.
              • P
                P
                pjr
                Eh. better question could be why repeater sends that ack in any case? Shouldnt it behave just as repeater... :/
                fetsF 1 Reply Last reply
                • P pjr
                  fetsF
                  fetsF
                  fets
                  @pjr :+1:
                  • Y
                    Y
                    yury
                    Everything is OK. It was my mistake.
                    I did not do clear EPROM properly... so I ended up with the repeater and the node with the same nodeID which I hard coded. That is why repeater ACK was accepted as node ACK.
                    All work great.
