  3. Identifying Pro Mini 5v and 3.3v, Is this correct/safe ?
4 Posts 4 Posters 1.9k Views 2 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I have a bunch of Pro minis witch have been mixed. I looked for a way to identify them in a easy way but never found any method that was understandeble to me. But now I just found a super easy way.
    Connect 5v to RAW/GND, use a multimeter to check the power of VCC/GND. It shows 3.3v or 4.8-5v.
    The post was written by "CrossRoads" on the arduino.cc forum.
    Can you measure the VCC pin when power is applied to Raw? If its 3.3V, then you've got a 3.3V/8MHz board.
    The chip itself will happily run at 3.3V or 5V.
    Is it really this easy?
    fetsF 1 Reply Last reply
      fetsF
      fetsF
      fets
      @Cliff-Karlsson yep, that's what I did
      • E
        E
        emc2
        If you have good eyes most of the time you can look at the onboard power regulator if it says 5, or 50 (5V) or 33 (3.3V)
        • N
          N
          novicit
          On my 5V minis, the 16mhz crystal is much larger (long silver oval component stamped 16.00) than on 3.3v. At least on mine.
