  3. Soil Sensor analog values differ on Uno vs Pro Mini
soil sensorunopro mini
28 Posts 8 Posters 17.6k Views 1 Watching
    @Moshe-Livne
    Try it!!
    int soilValue = 250;
      Serial.begin(115200);
      Serial.println(map(soilValue, 1023,0,100,0));
    have you run into 123dcircuits yet?
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @BulldogLowell not yet!!! my first encounter with arduino was only a few weeks ago.... so much to learn! the wood are lovely dark and deep, but i have promises to keep....
    • F
      F
      fred97
      hello
      it's working but is not inverted :+1:
      314
      send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:30
      294
      send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:28
      287
      299
      send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:29
      313
      1023
      send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:100
      100 is when is dry and 220/250 is when the sensor is in water .
      i just need little more help for invert value , 100 = in water and 0 when is dry
      thx
      • F fred97
        hello
        314
        294
        287
        299
        313
        1023
        thx
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        wrote on last edited by BulldogLowell
        #23
        @fred97
        @BulldogLowell said:
        gw.send(msg.set(map(soilValue, 0, 1023, 0 ,100));
        like this:
        gw.send(msg.set(map(soilValue, 100, 250, 0, 100));
        it maps 100 to zero and 250 to 100
        Let me know if that works for you.
        or... you can try this to bound the returned value by zero and 100:
        gw.send((max(min(map(soilValue, 100,250,0,100), 100), 0)));
        confusing but is is mapping the value, and limiting to 100 and then making sure it is at least zero (i.e. non-negative).
        or just:
        gw.send(constrain(map(soilValue, 100,250,0,100), 0, 100));
        • F
          F
          fred97
          gw.send(msg.set(map(soilValue, 100, 250, 0, 100)));```
          you have forget one ) at last .
          sensor started, id 2
          send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
          send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
          read: 0-0-2 s=255,c=3,t=6,pt=0,l=1:M
          send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=25,st=ok:Soil Moisture Sensor - an
          send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
          send: 2-2-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
          1023
          send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:615
          285
          send: 2-2-0-0 s=0,c=1,t=1,pt=4,l=4,st=ok:123
          250 is when is in water and 1023 is dry , it's alway inverted , i can test 2 other exemple because there is a problem in sketch maybe ;or ) when is try this
          and for other 2 exemple i can send to arduino compiling error
          sketch_may24a.ino: In function 'void loop()':
          sketch_may24a:31: error: no matching function for call to 'MySensor::send(long int)'
          C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:142: note: candidates are: bool MySensor::send(MyMessage&, bool)
          • F fred97
            1023
            285
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @fred97
            Post your entire sketch.
            • F
              F
              fred97
              #define ANALOG_INPUT_SOIL_SENSOR A0
              #define CHILD_ID 0 // Id of the sensor child
              MyMessage msg(CHILD_ID, V_HUM);
              int lastSoilValue = -1;
              gw.begin();
              gw.sendSketchInfo("Soil Moisture Sensor - analog", "1.0");
              // sets the soil sensor analog pin as input
              pinMode(ANALOG_INPUT_SOIL_SENSOR, INPUT);
              gw.present(CHILD_ID, S_HUM);
              // Read analog soil value
              int soilValue = analogRead(ANALOG_INPUT_SOIL_SENSOR);
              if (soilValue != lastSoilValue) {
              Serial.println(soilValue);
              lastSoilValue = soilValue;
              // Power down the radio and arduino until analog input changes.
              gw.sleep(1000);
              is the same sketch but i have changed only
              gw.send(msg.set(static_cast<int>(static_cast<float>(1023 - soilValue))/1023*100)); // Send the relative moisture. this will probably work only on nano or uno as I used 1023
              by this
              i don't understand why is alway inverted ??
              • F fred97
                gw.begin();
                gw.sleep(1000);
                by this
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                try to use this:
                gw.send(msg.set(constrain(map(soilValue, 1023, 250, 0, 100),0,100)));
                it maps 1023 to zero and 250 to 100... that is what you want, yes?
                  gw.begin();
                  gw.sleep(1000);
                • F
                  F
                  fred97
                  thanks you very much work great !
