  3. Relays and Touch-Panel
1 Posts 1 Posters 1.2k Views 2 Watching
  • D Offline
    Delranon
    wrote on last edited by Delranon
    I´m using a Touchpanel with 16 Buttons for controlling different lights in my basement/man-cave.
    It is this one: http://www.aliexpress.com/item/New-16-Way-Channel-Capacitive-Touch-Switch-Digital-Touch-Sensor-Module-PCB-Board-TTP229-Electronic-Components/32343209711.html
    Each Button switch one Relay - this is working so far - but now i want to integrate the relays also with mysensors,
    so that i can see the Status, and switch the Relais also with the controller (domotiz).
    My current working code is here: https://github.com/Delranon/cave-control/blob/master/cave_control/cave_control.ino
    I´ve seen the RelayActuator Example but these are always with a hardware button, but i get the button as a variable from the TouchPanel-Library and
    switch the relays like this:
    if (key == 5)   //Button pushed
          { if (Relais5State == 0)         // Relais is currently off
            { digitalWrite(Relais5, LOW);  //turn Relais on
    And now i´m looking how to send to the controller that relay 1 is turned on and that i can it also turn off via the controller interface...
    Any help or tips would be awesome!
    Thanks Del
