  3. Iboard - Cheap Single board Ethernet Arduino with Radio
iboard
74 Posts 27 Posters 69.4k Views 9 Watching
  • T TommySharp
    I know this is a basic question but what do I need to buy to program this using USB from my PC? So far I've just tinkered with Nanos which have a usb port on it.... An ebay link would be great!
    korttomaK
    korttomaK
    korttoma
    @TommySharp something like this or simlar http://www.itead.cc/foca.html
    • Tomas
    • T TommySharp
      DwaltD
      DwaltD
      Dwalt
      @TommySharp
      I just changed over to the iBoard Ethernet gateway from serial. I used the FTDI breakout board to program it. Very simple to use. The FTDI board is also needed for programming pro minis.
      • T
        tbully
        Hello Everyone. Sorry to bother you. I somehow screwed up my iBoard (hardware / trace modification) sketch/config today and was hoping someone could help me think through this.
        I was having a problem with one of my far away sensors from hearing the gateway so I thought I'd increase power. When I compiled and uploaded the code, I started getting: "0;0;3;0;9;radio init fail"
        I thought maybe my MyConfig.H file was incorrect. However, I referenced this schematic (and took in to account @gregl 's wiring changes), and my values look OK. The original setup URL referenced by Greg no longer exists on the MySensor page. Mysensors Ethernet
        I tried changing the radio and supply on a whim. That didn't make a difference (not surprised as it has been working fine for months before trying to change the power setting)
        Here's my sketch followed by my config file. Please help.....
        Sketch
         * Version 1.0 - Henrik EKblad
         * COMPILING WIZNET (W5100) ETHERNET MODULE
         * > Edit MyConfig.h in (libraries\MySensors\) to enable softspi (remove // before "#define SOFTSPI").
         * COMPILING ENC28J60 ETHERNET MODULE
         * > Use Arduino IDE 1.5.7 (or later)
         * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
         * > Remove Ethernet.h include below and include UIPEthernet.h
         * > Remove DigitalIO include
         * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
         * VERA CONFIGURATION:
         * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
         * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
         * LED purposes:
        #define NO_PORTB_PINCHANGES
        #include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
        #include <MySigningNone.h>
        #include <MyTransportRFM69.h>
        #include <MyTransportNRF24.h>
        #include <MyHwATMega328.h>
        #include <MySigningAtsha204Soft.h>
        #include <MySigningAtsha204.h>
        #include <MyParserSerial.h>
        #include <stdarg.h>
        #include <PinChangeInt.h>
        #include "GatewayUtil.h"
        // Use this if you have attached a Ethernet ENC28J60 shields
        // #include <UIPEthernet.h>
        // Use this for WizNET W5100 module and Arduino Ethernet Shield
        #include <Ethernet.h>
        #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
        #define INCLUSION_MODE_PIN  5 // Digital pin used for inclusion mode button
        #define RADIO_CE_PIN        3  // radio chip enable
        #define RADIO_SPI_SS_PIN    8  // radio SPI serial select
        #define RADIO_ERROR_LED_PIN 11  // Error led pin
        #define RADIO_RX_LED_PIN    12  // Receive led pin
        #define RADIO_TX_LED_PIN    13  // the PCB, on board LED
        MyTransportNRF24 transport(RADIO_CE_PIN, RADIO_SPI_SS_PIN, RF24_PA_LEVEL_GW);
        //MyTransportRFM69 transport;
        // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
        //MySigningNone signer;
        //MySigningAtsha204Soft signer;
        //MySigningAtsha204 signer;
        // Hardware profile
        MyHwATMega328 hw;
        // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
        // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
        #ifdef WITH_LEDS_BLINKING
        MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
        #else
        MySensor gw(transport, hw /*, signer*/);
        #define IP_PORT 5003        // The port you want to open
        IPAddress myIp (192, 168, 34, 13);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
        byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
        // a R/W server on the port
        EthernetServer server = EthernetServer(IP_PORT);
        // handle to open connection
        EthernetClient client = EthernetClient();
        char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
        int inputPos = 0;
        bool sentReady = false;
        void output(const char *fmt, ... ) {
           va_list args;
           va_start (args, fmt );
           vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
           va_end (args);
           Serial.print(serialBuffer);
           server.write(serialBuffer);
          Ethernet.begin(mac, myIp);
          setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
          // Add interrupt for inclusion button to pin
          PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
          // give the Ethernet interface a second to initialize
          delay(1000);
          // Initialize gateway at maximum PA level, channel 70 and callback for write operations
          gw.begin(incomingMessage, 0, true, 0);
          // start listening for clients
          server.begin();
          gw.process();
          checkButtonTriggeredInclusion();
          checkInclusionFinished();
          // if an incoming client connects, there will be
          // bytes available to read via the client object
          EthernetClient newclient = server.available();
          // if a new client connects make sure to dispose any previous existing sockets
          if (newclient) {
              if (client != newclient) {
               client.stop();
               client = newclient;
               output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
           if (client) {
             if (!client.connected()) {
               client.stop();
             } else if (client.available()) {
               // read the bytes incoming from the client
               char inChar = client.read();
               if (inputPos<MAX_RECEIVE_LENGTH-1) {
                 // if newline then command is complete
                 if (inChar == '\n') {
                   Serial.println("Finished");
                    // a command was issued by the client
                    // we will now try to send it to the actuator
                    inputString[inputPos] = 0;
                    // echo the string to the serial port
                    Serial.print(inputString);
                    parseAndSend(gw, inputString);
                    // clear the string:
                    inputPos = 0;
                 } else {
                   // add it to the inputString:
                   inputString[inputPos] = inChar;
                   inputPos++;
              } else {
                 // Incoming message too long. Throw away
                 inputPos = 0;
        Config File
        #ifndef MyConfig_h
        #define MyConfig_h
        #include <stdint.h>
        // Enable debug flag for debug prints. This will add a lot to the size of the final sketch but good
        // to see what is actually is happening when developing
        #define DEBUG
        // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
        #define ENABLED_SERIAL
        // Serial output baud rate (for debug prints and serial gateway)
        #define BAUD_RATE 115200
        *  Over the air firmware updates
        // The following define enables the safe over-the-air firmware update feature
        // which requires external flash and the DualOptiBoot bootloader.
        // Note: You can still have OTA FW updates without external flash but it
        // requires the MYSBootloader and disabled MY_OTA_FIRMWARE_FEATURE
        //#define MY_OTA_FIRMWARE_FEATURE
        // Slave select pin for external flash
        #define MY_OTA_FLASH_SS 8
        // Flash jdecid
        #define MY_OTA_FLASH_JDECID 0x1F65
        *  Information LEDs blinking
        // This feature enables LEDs blinking on message receive, transmit
        // or if some error occured. This was commonly used only in gateways,
        // but now can be used in any sensor node. Also the LEDs can now be
        // disabled in the gateway.
        // #define WITH_LEDS_BLINKING
        // The following setting allows you to inverse the blinking feature WITH_LEDS_BLINKING
        // When WITH_LEDS_BLINKING_INVERSE is enabled LEDSs are normally turned on and switches
        // off when blinking
        //#define WITH_LEDS_BLINKING_INVERSE
        // default LEDs blinking period in milliseconds
        #define DEFAULT_LED_BLINK_PERIOD 300
        // The RX LED default pin
        #define DEFAULT_RX_LED_PIN 6
        // The TX LED default pin
        #define DEFAULT_TX_LED_PIN 5
        // The Error LED default pin
        #define DEFAULT_ERR_LED_PIN 4
        *  Message Signing Settings
        // Disable to completly disable signing functionality in library
        //#define MY_SIGNING_FEATURE
        // Define a suitable timeout for a signature verification session
        // Consider the turnaround from a nonce being generated to a signed message being received
        // which might vary, especially in networks with many hops. 5s ought to be enough for anyone.
        #define MY_VERIFICATION_TIMEOUT_MS 5000
        // Enable to turn on whitelisting
        // When enabled, a signing node will salt the signature with it's unique signature and nodeId.
        // The verifying node will look up the sender in a local table of trusted nodes and
        // do the corresponding salting in order to verify the signature.
        // For this reason, if whitelisting is enabled on one of the nodes in a sign-verify pair, both
        // nodes have to implement whitelisting for this to work.
        // Note that a node can still transmit a non-salted message (i.e. have whitelisting disabled)
        // to a node that has whitelisting enabled (assuming the receiver does not have a matching entry
        // for the sender in it's whitelist)
        //#define MY_SECURE_NODE_WHITELISTING
        // MySigningAtsha204 default setting
        #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
        // MySigningAtsha204Soft default settings
        #define MY_RANDOMSEED_PIN 7 // A7 - Pin used for random generation (do not connect anything to this)
        // Key to use for HMAC calculation in MySigningAtsha204Soft (32 bytes)
        #define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
        *  NRF24L01 Driver Defaults
        #define RF24_CE_PIN		   9  //norm
        #define RF24_CS_PIN		   10 //norm
        //#define RF24_CE_PIN		   3  //gateway
        //#define RF24_CS_PIN		   8  //gateway
        //#define RF24_CE_PIN		   17 //lcd controller
        //#define RF24_CS_PIN		   18  //lcd controller
        #define RF24_PA_LEVEL 	   RF24_PA_LOW
        #define RF24_PA_LEVEL_GW   RF24_PA_LOW
        // RF channel for the sensor net, 0-127
        #define RF24_CHANNEL	   76
        //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
        #define RF24_DATARATE 	   RF24_250KBPS
        // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
        #define RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
        // Enable SOFTSPI for NRF24L01 when using the W5100 Ethernet module
        #define SOFTSPI
        #ifdef SOFTSPI
        	// Define the soft SPI pins used for NRF radio
            //const uint8_t SOFT_SPI_MISO_PIN = 16;  //norm - scene controller
            //const uint8_t SOFT_SPI_MOSI_PIN = 15;  //norm - scene controller
            //const uint8_t SOFT_SPI_SCK_PIN = 14;  //norm - scene controller
            const uint8_t SOFT_SPI_MISO_PIN = 12;  //gateway
            const uint8_t SOFT_SPI_MOSI_PIN = 11;  //gateway
            const uint8_t SOFT_SPI_SCK_PIN = 13;  //gateway
        *  RFM69 Driver Defaults
        // Default network id. Use the same for all nodes that will talk to each other
        #define RFM69_NETWORKID     100
        // Default frequency to use. This must match the hardware version of the RFM69 radio (uncomment one):
        // #define RFM69_FREQUENCY   RF69_433MHZ
        #define RFM69_FREQUENCY   RF69_868MHZ
        //#define FREQUENCY     RF69_915MHZ
        // Enable this for encryption of packets
        //#define RFM69_ENABLE_ENCRYPTION
        #define RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
        DwaltD 1 Reply Last reply
        • T tbully
          Sketch
           * LED purposes:
          #include <stdarg.h>
          // Hardware profile
          MyHwATMega328 hw;
          #else
          int inputPos = 0;
             va_list args;
             va_end (args);
            delay(1000);
            server.begin();
            gw.process();
            if (newclient) {
                 client.stop();
                 client = newclient;
             if (client) {
                 client.stop();
                      inputPos = 0;
                   } else {
                     inputPos++;
                } else {
                   inputPos = 0;
          Config File
          #ifndef MyConfig_h
          #define MyConfig_h
          #include <stdint.h>
          #define DEBUG
          // Flash jdecid
          #define SOFTSPI
          #ifdef SOFTSPI
          DwaltD
          DwaltD
          Dwalt
          @tbully
          I vaguely remember getting the 'radio inti fail' error when i first setup my iBoard (with hardware mod) and the only difference i see between my sketch and yours is mapping the inclusion button and led pins to analog pin numbers.
          #define INCLUSION_MODE_PIN  14 // Digital pin used for inclusion mode button A0
          #define RADIO_ERROR_LED_PIN 15  // Error led pin A1
          #define RADIO_RX_LED_PIN    16  // Receive led pin A2
          #define RADIO_TX_LED_PIN    17  // the PCB, on board LED A3
          • T
            tbully
            Thanks @Dwalt I'm pulling my hair out here.
            Pin 5 should matter (nor should the others) as it is freed up with the "hardware mod" of @gregl 's engineering.
            I changed all four settings anyway, just in case. No go.
            Starting to wonder if something is going on with the board.......
            • T
              tbully
              wrote on last edited by tbully
              #66
              To close the loop on this (and to help future dwellers), a new board solved the issue. Not sure what wasn't working properly on the old board but I'm up and running again (with the same old radio, supply, etc).
              Also, since I've learned a little and now understand a few of the configs better since my original iBoard build, I was able to do this WITHOUT the hardware mod.
              I set the following in MyConfig.H:
              const uint8_t SOFT_SPI_MISO_PIN = 6;
              const uint8_t SOFT_SPI_MOSI_PIN = 5;
              const uint8_t SOFT_SPI_SCK_PIN = 7;
              My failure from several months ago was not setting the CE and SS pins properly in my sketch. I also took @Dwalt 's advice and updated my inclusion and LED pins (even though I didn't use them):
              • C
                C
                cleight
                I have been trying to get my iBoard working correctly for a few months on and off and finally got it up and running with good range and things are working good. However I am having an issue with the gateway always being stuck in inclusion mode, I have the following sketch, I would like to retain the onboard LED's but I don't have an inclusion button or need one since I can start the inclusion process from Vera. Any guidance would be greatly appreciated.
                 * LED purposes:
                #include <stdarg.h>
                #define RADIO_ERROR_LED_PIN 7  // Error led pin
                #define RADIO_RX_LED_PIN    6  // Receive led pin
                #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
                // Hardware profile
                MyHwATMega328 hw;
                #else
                IPAddress myIp (192, 168, 2, 62);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                int inputPos = 0;
                   va_list args;
                   va_end (args);
                  delay(1000);
                  server.begin();
                  gw.process();
                  if (newclient) {
                       client.stop();
                       client = newclient;
                   if (client) {
                       client.stop();
                            inputPos = 0;
                         } else {
                           inputPos++;
                      } else {
                         inputPos = 0;
                • 5546dug5
                  5546dug5
                  5546dug
                  wrote on last edited by 5546dug
                  #68
                  @gregl or anyone with info
                  this is the second iboard gateway to be set up for me. The first went off without a hitch. It was and is still up and running flawlessly, how ever there is aproblem I have to day.
                  I believe I have used the same program as is indicated in this thread and have done so by the h/w method.
                  When using the arduino 1.6.5 IDE and set to Duemilove board 328 processer and proper USB port, when using the serial moniter the message "0,0,3,0,14 gateway started " is what is shown.
                  However when Iboard is plugged into Ethernet port on modem, there is no interaction on the vera 3 dashboard (ui5) and for the life of me I can not figure out the issue.
                  The power LED as well as LINK ,SPD, FDX are on steady with occasional blinks of the Rx led
                  suggesting there is some communication between iboard and modem. As there is no check wires, all in the board seems well.
                  Any ideas on the problemI? I have tried different rf24 and power supplies or have I forgot to do something with the vera. I had usb gateway but it has been deleted from vera3.
                  Thanks doug.
                  Edit When I go to the router and inspect for connected things the Iboard does show up under the proper reserved ip (10.0.0.20) with port 5003.
                  This unit is in remote home and first unit is at residence, both with own vera but both use the same mac dead beef feed.
                  • 5546dug5 5546dug
                    Thanks doug.
                    DwaltD
                    DwaltD
                    Dwalt
                    @5546dug It sounds like everything is working correctly with the iBoard itself, did you configure the MySensors plugin for the IP of the GW? When I switched from serial GW to iBoard, I did not delete the plugin, I just entered the IP Addy in the plugin settings and boom, everything worked, and zero hiccups with the GW ever since.
                    • 5546dug5
                      5546dug5
                      5546dug
                      @Dwalt I think this where the issue is I cant seem to get the My Sensors plug in to show on the vera3 dashboard.
                      • 5546dug5
                        5546dug5
                        5546dug
                        @Dwalt I believe your reply caught my problem, in IP address bar I was missing the semi colons on the DEADBEEFFEED mac, It would appear that the issue has been resolved for now .
                        Thanks a lot!
                        • Mercury69M
                          Mercury69M
                          Mercury69
                          Dear All,
                          I just buyed an iboard and following your instruction I tried to get it working in my domoticz configuration, but without success.
                          As at today MySensors library is updated to ver. 2, can you please tell me how to proceed in order to have it working correctly ?
                          I used the sketch available in MySensors Library in my arduino IDE 1.6.13, but I never able to ping it from my computer.
                          As for now I prefere don't go for hardware modification, can you please suggest me what kind of modification I have to do and where I have to do it ?
                          Because I don't know if I have to modify only the sketch or if I have to modify the file MyConfig.h or what other file I have to modify.
                          Thank you in advance for your help.
                          T 1 Reply Last reply
                          • Mercury69M Mercury69
                            Dear All,
                            TimO
                            @Mercury69
                            Try this sketch:
                             * Contribution by Tomas Hozza <thozza@gmail.com>
                             * LED purposes:
                            //#define MY_DEBUG
                            #define MY_GATEWAY_W5100
                            // signing
                            //#define MY_SIGNING_SOFT
                            //#define MY_SIGNING_REQUEST_SIGNATURES
                            // radio on the same spi bus.
                              #define MY_SOFTSPI
                              #define MY_SOFT_SPI_SCK_PIN 7
                              #define MY_SOFT_SPI_MISO_PIN 6
                              #define MY_SOFT_SPI_MOSI_PIN 5
                            #define MY_RF24_CE_PIN 3
                            #define MY_RF24_CS_PIN 8
                            #define MY_IP_ADDRESS 192,168,2,2   // If this is disabled, DHCP is used to retrieve address
                            #define MY_PORT 5003
                            #if defined(MY_USE_UDP)
                              #include <EthernetUdp.h>
                            • Mercury69M
                              Mercury69M
                              Mercury69
                              @TimO
                              Thank you very much for your help, now I succesfully connected my iboard card as LAN Gateway without doing any HW modification and even any software modification to any library, simply using the sketch you sent here.
                              For general information to other people that want to use the iboard card with Domoticz, to avoid any problem like the following:
                              2016-12-18 12:06:40.840 MySensors: trying to connect to: 192.168.1.133:5603
                              2016-12-18 12:06:41.841 MySensors: connected to: 192.168.1.133:5603
                              2016-12-18 12:06:45.841 MySensors: Connection reset!
                              2016-12-18 12:06:45.842 TCP: Reconnecting in 30 seconds...
                              Consider to use the Arduino IDE 1.6.8 to compile and upload the sketch, otherwise, with newest Arduino IDE you will get the error messages above.
                              Thank you again for you help and a big hello to all the members of the forum.
                              Regards
