  3. Door switch - sleep
Door switch - sleep
6 Posts 5 Posters 3.9k Views 3 Watching
  • I
    I
    insomnia
    wrote on last edited by insomnia
    I use this sketch for a door switch and i wan't to make it battery powered and also wan't to make the arduino go to sleep. Is this possible and how do i do that?
    gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME); Doesn't work with interrupt in this sketch
    #include <Bounce2.h>
    #define CHILD_ID1 3
    #define BUTTON_PIN1  3  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID2 4
    #define BUTTON_PIN2  4  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID3 5
    #define BUTTON_PIN3  5  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce(); // debouncer for the second switch
    Bounce debouncer3 = Bounce(); // debouncer for the third switch
    int oldValue1=-1;
    int oldValue2=-1; // second switch needs to have it's own old state
    int oldValue3=-1; // second switch needs to have it's own old state
    unsigned long SLEEP_TIME = 900000; // Sleep time between reports (in milliseconds)
    int oldBatteryPcnt = 0;
    MyMessage msg1(CHILD_ID1,V_TRIPPED), msg2(CHILD_ID2,V_TRIPPED),msg3(CHILD_ID3,V_TRIPPED);
      gw.begin();
       analogReference(INTERNAL1V1);
    #else
       analogReference(INTERNAL);
      gw.begin();
      gw.sendSketchInfo("Door Sensor Battery meter", "1.0");
     // Setup the button
      pinMode(BUTTON_PIN1,INPUT_PULLUP ); // You can assign pinmode and use pullup in one statement.
      pinMode(BUTTON_PIN2,INPUT_PULLUP);
      pinMode(BUTTON_PIN3,INPUT_PULLUP);
      // Activate internal pull-up
     // digitalWrite(BUTTON_PIN1,HIGH);
    //  digitalWrite(BUTTON_PIN2,HIGH);
    //  digitalWrite(BUTTON_PIN3,HIGH);
      // After setting up the button, setup debouncer1
      debouncer1.attach(BUTTON_PIN1);
      debouncer1.interval(5);
      debouncer2.attach(BUTTON_PIN2);
      debouncer2.interval(5);
      debouncer3.attach(BUTTON_PIN3);
      debouncer3.interval(5);
      gw.present(CHILD_ID1, S_DOOR);
      gw.present(CHILD_ID2, S_DOOR);
      gw.present(CHILD_ID3, S_DOOR);
      // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       float batteryV  = sensorValue * 0.003363075;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
      // Check if the first switch state has changed
      debouncer1.update();
      // Get the update value
      int value = debouncer1.read();
      if (value != oldValue1) {
         // Send in the new value
         gw.send(msg1.set(value==HIGH ? 1 : 0));
    //     gw.send(msg2.set(value==HIGH ? 1 : 0)); // this is where you turn the second switch in your controller
    //     gw.send(msg3.set(value==HIGH ? 1 : 0));  // this is where you turn the third switch in your controller
         oldValue1 = value;
      // Check if the 2nd switch state has changed
      debouncer2.update();
      value = debouncer2.read(); // no need to redeclare it (I removed int)
      if (value != oldValue2) {
    //     gw.send(msg1.set(value==HIGH ? 1 : 0));
         oldValue2 = value;
      // Check if the third switch state has changed
      debouncer3.update();
      value = debouncer3.read(); // no need to redeclare it (I removed int)
      if (value != oldValue3) {
         oldValue3 = value;
    DwaltD SparkmanS m26872M 3 Replies Last reply
    • I insomnia
      #define CHILD_ID1 3
      #define CHILD_ID2 4
      #define CHILD_ID3 5
      int oldValue1=-1;
        gw.begin();
      #else
        gw.begin();
       // Setup the button
         #ifdef DEBUG
         #ifdef DEBUG
           oldValue1 = value;
           oldValue2 = value;
           oldValue3 = value;
      DwaltD
      DwaltD
      Dwalt
      @insomnia
      You need to declare your interrupts to use the interrupt-from-sleep function. Right now it looks like your sketch is sleeping 15 minutes and then checking your door sensors and going back to sleep..
      • I
        I
        insomnia
        Like this
        #define INTERRUPT DIGITAL_INPUT_SENSOR-3
        #define INTERRUPT DIGITAL_INPUT_SENSOR-4
        #define INTERRUPT DIGITAL_INPUT_SENSOR-5
        Is this correct?
        M 1 Reply Last reply
        • I insomnia
          Like this
          Is this correct?
          mbj
          @insomnia I can not see any defined interrupt or the interrupt related function in your code. Starting with the Arduino docs is often helpful why I suggest taking a look at https://www.arduino.cc/en/Reference/AttachInterrupt. For only one switch a hardware interrupt will work fine.
          If you need to monitor a few more switches and you use an Arduino with 328P processor there are only 2 hardware interrupts available. Then the pin change interrupts may help but the task is getting more complicated, see for example http://playground.arduino.cc/Main/PinChangeInterrupt but there are libraries like https://github.com/GreyGnome/EnableInterrupt (which I so far not have tested).
          Then there are ways of dealing with heaps of interrupts as well but that is far beyond my knowledge.
          • I insomnia
            #define CHILD_ID1 3
            #define CHILD_ID2 4
            #define CHILD_ID3 5
            int oldValue1=-1;
              gw.begin();
            #else
              gw.begin();
             // Setup the button
               #ifdef DEBUG
               #ifdef DEBUG
                 oldValue1 = value;
                 oldValue2 = value;
                 oldValue3 = value;
            SparkmanS
            SparkmanS
            Sparkman
            @insomnia Take a look at this article as it describes how to use one interrupt pin for multiple swirches: http://www.gammon.com.au/forum/?id=11091.
            Cheers
            Al
            • I insomnia
              #define CHILD_ID1 3
              #define CHILD_ID2 4
              #define CHILD_ID3 5
              int oldValue1=-1;
                gw.begin();
              #else
                gw.begin();
               // Setup the button
                 #ifdef DEBUG
                 #ifdef DEBUG
                   oldValue1 = value;
                   oldValue2 = value;
                   oldValue3 = value;
              m26872M
              m26872M
              m26872
              @insomnia
              Have you seen the basic MySensors example BinarySwitchSleepSensor ?
              (Personally I use a longer button settle delay though.)
