  3. RelayActuator with battery poweredsensor
3 Posts 2 Posters 1.1k Views 2 Watching
  • N
    N
    NBM
    wrote on last edited by NBM
    Hey
    I have a problem with my sketch.
    It is a relay with battery.
    When i turns ON the relay on vera nothing happens and so on.
    But the vera send command when i toggle it.
    Sometimes it have problems with sending the command from vera
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
    unsigned long SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
      analogReference(INTERNAL1V1);
      #else
      analogReference(INTERNAL);
      gw.begin();
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
       gw.process();
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       float batteryV  = sensorValue * 0.003363075;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
       gw.sleep(SLEEP_TIME);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    Can anyone help.
    /Nikolaj
      I don't think you can do gw.sleep. gw.sleep turns the radio off, so the sensor wouldn't receive the command from your controller.
      • N
        N
        NBM
        Of course i delete the line gw.sleep(SLEEP_TIME);
