  3. This should be a simple one! Water level test (not on constantly)
5 Posts 3 Posters 1.7k Views 2 Watching
  • P
    P
    punter9
    Ok I am working away steadily at my automatic garden. I could use some help figuring out how to power up, read, and then power down my water level sensors.
    Currently I have 4 bolts in a 5 gallon bucket for water (and a pump). The bottom bolt is ground and the top 3 are for various water level indications. Currently I have it set up to read from digital pins but these are on all the time and this will cause significant amounts of electrolysis. What I would like to do is utilize millis and pin settings to turn the pins on, take a reading, and turn them off. Due to the nature of my operation I only need to do this about 4 times a day.
    If anyone could help me out with my code I would really appreciate it!
    #include <Bounce2.h>
    #define CHILD_ID3 3
    #define BUTTON_PIN1  3  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID4 4
    #define BUTTON_PIN2  4  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID5 5
    #define BUTTON_PIN3  5  // Arduino Digital I/O pin for button/reed switch
    long previousMillis = 0;
    long interval = (10000); //delay betweein readings - 1000 is 1 second
    Bounce debouncer = Bounce();
    int oldValue1=-1;
    int oldValue2=-1;
    int oldValue3=-1;
    MyMessage msg1(CHILD_ID3,V_TRIPPED), msg2(CHILD_ID4,V_TRIPPED),msg3(CHILD_ID5,V_TRIPPED); // Change to V_LIGHT if you use S_LIGHT in presentation below
      gw.begin();
     gw.sendSketchInfo("3 Binary Switches", "1.0");
      pinMode(BUTTON_PIN1,INPUT);
      pinMode(BUTTON_PIN2,INPUT);
      pinMode(BUTTON_PIN3,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN1,HIGH);
      digitalWrite(BUTTON_PIN2,HIGH);
      digitalWrite(BUTTON_PIN3,HIGH);
      gw.present(CHILD_ID3, S_DOOR);// Register binary input sensor to gw (they will be created as child devices)
      gw.present(CHILD_ID4, S_DOOR); // You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage.
      gw.present(CHILD_ID5, S_DOOR);  // If S_LIGHT is used, remember to update variable type you send in. See "msg" above.
      if (currentMillis - previousMillis > interval) {
      debouncer.update();
      int value1 = debouncer.read();
      int value2 = debouncer.read();
      int value3 = debouncer.read();
      value1 = digitalRead(BUTTON_PIN1);
      value2 = digitalRead(BUTTON_PIN2);
      value3 = digitalRead(BUTTON_PIN3);
      gw.send(msg1.set(value1==HIGH ? 1 : 0));// Send in the new value
      oldValue1 = value1;
      gw.send(msg2.set(value2==HIGH ? 1 : 0));// Send in the new value
      oldValue2 = value2;
      gw.send(msg3.set(value3==HIGH ? 1 : 0));// Send in the new value
      oldValue3 = value3;
    • sundberg84S
      Hi!
      It might be possible to use gw.sleep(SLEEP_TIME); to power your node down when its not used?
      I dont know if you have to set the pins low before this but better safe... ?
      There are many examples, temp sketch, that uses this.
      I use sleep all the time to save battery on my nodes and that works great.
      • P
        P
        punter9
        wrote on last edited by punter9
        Thanks for the help!
        I may be wrong but I believe that only sleeps the radio but wouldn't shut down the digital pins in the water (the electrolysis). I'm also a noob so that may be way off lol.
        I have a relay attached to it as well so I really need it to be running. With the help from this forum I am using digital pins to power my moisture sensors and turning them on and off to prevent electrolysis (take a reading on analog pin). Works great, I'd like a similar setup here if possible
          Move
          out from setup(), place them just after
          debouncer.update();
          instead, and add
            // Deactivate internal pull-up
            digitalWrite(BUTTON_PIN1,LOW);
            digitalWrite(BUTTON_PIN2,LOW);
            digitalWrite(BUTTON_PIN3,LOW);
          after
          oldValue3 = value3;
          and you should be OK.
          • P
            P
            punter9
            @mfalkvidd said:
            thanks! That makes a ton of sense. These forums are awesome, I really appreciate everybody
