  3. Could you please suggest me good current sensor module to monitor the current of the motor ?
3 Posts 2 Posters 1.6k Views 1 Watching
    musthafafarhan
    [More information:
    I need to sense the current between the load and power supply. In this case. the load is a stepper motor which normally operates in 24V given from the power supply unit. My goal is to find the force of the motor, If I want to find the force, I need to know the torque value.
    In my project , I have no option to find the torque of the motor so I only way to find the current (different speed has different current value) so that I need to buy the current sensor module.
    please suggest me the right product which ill give the good accuracy and result. <<please also refer attached image for the general idea>> ](IMAG0264.jpg link url)
    • AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      Just thoughts: a stepper motor is usually one for which you control the speed with a special controller. The controller sends 'pulse sequences' to different coils in the motor with mostly fixed current. Very hard to determine speed by measuring current.
      If you have a 'servo' type of motor there is more of a relation.
      • AWIA
        AWIA
        AWI
        Is it an ac or DC motor.? In both cases you can measure current, but you can have a different solution. A board like http://m.ebay.com/itm/1pcs-5A-range-Current-Sensor-Module-ACS712-Module-NEW-/381374424345?nav=SEARCH
        Is an easy (invasive) solution.
