  3. SI7021 Multisensor - first try
multisensorsi7021
26 Posts 9 Posters 23.6k Views 6 Watching
  • dakkyD Offline
    dakkyD Offline
    dakky
    does the sleeping current come down to an acceptable level when removing the regulator? 1500uA is quite much for a battery powered node.
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • N Offline
      N Offline
      n3ro
      wrote on last edited by n3ro
      #22
      @dakky said:
      1500uA
      The sleeping current is ~240uA.
      But it's possible to tune it a little bit more.
      pimatic + MySensors + Homeduino + z-way
      https://github.com/n3roGit/MySensors_n3ro
      • dakkyD Offline
        dakkyD Offline
        dakky
        hmm ok 240uA is better of course, but still far away from
        @m26872 said:
        Mine sleeps at 11uA.
        N 1 Reply Last reply
        • dakkyD dakky
          N Offline
          N Offline
          n3ro
          @dakky Yes, this is because of the multiple sensors on my board. maybe somebody have more tuning tipps.
          • R riataman
            @n3ro said:
            Big THX,
            now i have understand how to use the si7021 :)
            Reading works great!
            But the sleeping current is very high ~1500uA
            If you got this breakout: http://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32340228487.html?ws_ab_test=searchweb201556_1_79_78_77_80,searchweb201644_5,searchweb201560_1 it includes a 3.3v regulator and level shifting so you can actually use the sensor with a 5v arduino but it consumes quite a bit of current (60uA in the ones I got) even when idling.
            What I did was desolder the regulator and solder a small wire to bypass it (sorry for potato quality pic).
            Then I ordered this breakout for future nodes: http://www.aliexpress.com/item/New-HTU21D-Temperature-and-Humidity-Sensor-Module/1970355069.html?ws_ab_test=searchweb201556_1_79_78_77_80,searchweb201644_5,searchweb201560_1 that one doesn't seem to include any additional circuits (other than the pull up resistor and safety? resistor).
            M Offline
            M Offline
            Maciej Kulawik
            Thanks for tip!
            Unfortunatelly quite expensive. I bought my Si7021 modules on ali for 2,9$.
            And what chip is used on this HTU21D module? Si2071 too?
            If not, what library is to be used to communicate?
            • G Offline
              G Offline
              GertSanders
              wrote on last edited by GertSanders
              #26
              Adafruit have a library for the htu21d which works well with Mysensors
