  3. fresh install, now compile errors ?
4 Posts 3 Posters 1.9k Views 1 Watching
  • K
    K
    kr0815
    Because of some Problems with DS18b20, posted here in another thread, i decided to make a new Installation:
    • Arduino 1.0.6 in a Folder, in that subfolder the MySensors-Sketches, i adaptet the Settings in Arduino IDE to that Folder
    Now i get compile Errors
    What is going wrong ?
    In file included from PressureSensor.ino:31:
    C:\Users\KR\Desktop\arduino-1.0.6\Neuer Ordner\libraries\MySensors/MySensor.h:158: error: expected type-specifier before 'MyHwDriver'
    C:\Users\KR\Desktop\arduino-1.0.6\Neuer Ordner\libraries\MySensors/MySensor.h:158: error: default argument for parameter of type 'MyHw&' has type 'int'
    C:\Users\KR\Desktop\arduino-1.0.6\Neuer Ordner\libraries\MySensors/MySensor.h:158: error: expected ',' before 'MyHwDriver'
    • HoffanH
      HoffanH
      Hoffan
      It sounds that you use an very old Arduino 1.0.6
      You should use like 1.6.x
      • K
        K
        kr0815
        Thought i´d go better with the old 1.0.6, installed now on a fresh PC 1.6.6
        when compiling
          // put your setup code here, to run once:
          // put your main code here, to run repeatedly:
        i already get:
        Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
        WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
        But it compiles till the end
        Is ist ok to ignore this fault?
        • J
          J
          johnr
          I have the same problem. Downloaded 1.6.5 it works fine.
