  3. "Error sending switch command, check device/hardware !"
3 Posts 2 Posters 1.4k Views 1 Watching
  • P
    P
    punter9
    I have a mysensors relay node that I have been using acting very oddly. If I unplug the node and plug it back it it will work as it should a few times (on/off). After I cycle it about 3 times it stops working and instead I get the following error "Error sending switch command, check device/hardware !"
    If I unplug it, it works again about 3 times then right back into this pattern of behavior. Any ideas what to do with this?
    The sketch is unmodified from mysensors. I thought it may be a range issue so I took the gateway close to the lamp and I have the same issue.
    Domoticz V2.3530
    Raspbery PI model B
    Arduino Nano usb gateway with NRF24L01+
    Mysensors V1.5
      The relay might use too much power, causing a voltage dip that prevents the mcu from working correctly. Which capacitors and what power supply are you using? (How to ask for help)
      • P
        P
        punter9
        wrote on last edited by punter9
        Adding a capacitor to the radio is what I needed to do! Made all the difference in the world!
