  3. Kitchen Node .. Messy Code..
3 Posts 3 Posters 1.4k Views 3 Watching
    mrcage
    Hi There!
    Been playing around and used some great Sensors. Really love this sh#t :smile:
    I try to combine some sensors for my kitchen:
    3 Dallas temperature sensors
    1 Motion Sensor
    1 RGB strip
    1 Door (refrigerator)
    I think I have somewhere messed up my code.
    Not sure what I've done.. Motion, Door and RGB Strip works but I don't see any Temps.
     PROJECT: MySensors / RGB test for Light & Sensor
     PROGRAMMER: AWI/GizMoCuz
     DATE: september 27, 2015/ last update: October 10, 2015
     FILE: AWI_RGB.ino
     LICENSE: Public domain
     Hardware: Nano and MySensors 1.5
     Special:
      uses Fastled library with NeoPixel (great & fast RBG/HSV universal library)       https://github.com/FastLED/FastLED
     Remarks:
      Fixed node-id
      Added option to request/apply last light state from gateway
     Domoticz typicals - 2015 10 10:
      - Domoticz is using HUE values internally, there might be a slight difference then using direct RGB colors.
    #include <FastLED.h>
    #include <OneWire.h>
    #include <Bounce2.h>
    #define NODE_ID 1                      // fixed MySensors node id
    // Door
        #define CHILD_ID 6
        #define BUTTON_PIN  6  // Arduino Digital I/O pin for button/reed switch
    // Dallas temp
        //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    // Motion Sensor
        unsigned long SLEEP_TIME = 5000; // Sleep time between reports (in milliseconds)
        #define DIGITAL_INPUT_SENSOR 4   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
        #define CHILDMotion_ID 5   // Id of the sensor child
    /// RGB Strip
        const int stripPin = 5;                  // pin where 2812 LED strip is connected
        const int numPixel = 39;                  // set to number of pixels
        #define CHILDRGB_ID 4                  // Child Id's
        CRGB leds[numPixel];
        char actRGBvalue[] = "000000";               // Current RGB value
        uint16_t actRGBbrightness = 0xFF ;         // Controller Brightness
        int actRGBonoff=0;                        // OnOff flag
    // Start MySensor
    //Dallas
        int numSensors=3;
        boolean metric = true;
        MyMessage Tempmsg(0,V_TEMP);
    // Initialize RGB message
        MyMessage lastColorStatusMsg(CHILDRGB_ID,V_VAR1);
    // Initialize motion message
        MyMessage Motionmsg(CHILDMotion_ID, V_TRIPPED);
    // Door
        Bounce debouncer = Bounce();
        int oldValue=-1;
        MyMessage Doormsg(CHILD_ID,V_TRIPPED);
      sensors.begin();
         gw.present(i, S_TEMP);
      // RGB Strip
      FastLED.addLeds<NEOPIXEL, stripPin >(leds, numPixel); // initialize led strip
      gw.begin(incomingMessage, NODE_ID, false);      // initialize MySensors
      gw.sendSketchInfo("Keuken Node", "1.4");
      gw.present(CHILDRGB_ID, S_RGB_LIGHT);        // present to controller
      // Flash the "hello" color sequence: R, G, B, black.
      colorBars();
      //Request the last stored colors settings
      gw.request(CHILDRGB_ID, V_VAR1);
      // Door
         // Setup the button
        pinMode(BUTTON_PIN,INPUT);
        // Activate internal pull-up
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
        gw.present(CHILD_ID, S_DOOR);
      // Motion Sensor
      gw.present(CHILDMotion_ID, S_MOTION);
      gw.process();                       // wait for incoming messages
      // Door
            debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue) {
             // Send in the new value
             gw.send(Doormsg.set(value==HIGH ? 1 : 0));
             oldValue = value;
      //Dallas Temp
          gw.sleep(conversionTime);
            #if COMPARE_TEMP == 1
            #else
              gw.send(Tempmsg.setSensor(i).set(temperature,1));
      //gw.sleep(SLEEP_TIME); // Do I need this, as this is declared below?
      // Motion Sensor
          Serial.println(tripped);
          gw.send(Motionmsg.set(tripped?"1":"0"));  // Send tripped value to gw
          gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    void colorBars()
      SendColor2AllLEDs( CRGB::Red );   FastLED.show(); delay(500);
      SendColor2AllLEDs( CRGB::Green ); FastLED.show(); delay(500);
      SendColor2AllLEDs( CRGB::Blue );  FastLED.show(); delay(500);
      SendColor2AllLEDs( CRGB::Black ); FastLED.show(); delay(500);
    void SendColor2AllLEDs(const CRGB lcolor)
      for(int i = 0 ; i < numPixel ; i++) {
        leds[i] = lcolor;
    void SendLastColorStatus()
      String cStatus=actRGBvalue+String("&")+String(actRGBbrightness)+String("&")+String(actRGBonoff);
      gw.send(lastColorStatusMsg.set(cStatus.c_str()));
    String getValue(String data, char separator, int index)
     int found = 0;
      int strIndex[] = {0, -1};
      int maxIndex = data.length()-1;
      for(int i=0; i<=maxIndex && found<=index; i++){
      if(data.charAt(i)==separator || i==maxIndex){
      found++;
      strIndex[0] = strIndex[1]+1;
      strIndex[1] = (i == maxIndex) ? i+1 : i;
      return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
      if (message.type == V_RGB) {            // check for RGB type
        actRGBonoff=1;
        strcpy(actRGBvalue, message.getString());    // get the payload
        SendColor2AllLEDs(strtol(actRGBvalue, NULL, 16));
        SendLastColorStatus();
      else if (message.type == V_DIMMER) {           // if DIMMER type, adjust brightness
        actRGBonoff=1;
        actRGBbrightness = map(message.getLong(), 0, 100, 0, 255);
        FastLED.setBrightness( actRGBbrightness );
      else if (message.type == V_STATUS) {           // if on/off type, toggle brightness
        actRGBonoff = message.getInt();
        FastLED.setBrightness((actRGBonoff == 1)?actRGBbrightness:0);
      else if (message.type==V_VAR1) {            // color status
        String szMessage=message.getString();
        strcpy(actRGBvalue, getValue(szMessage,'&',0).c_str());
        actRGBbrightness=atoi(getValue(szMessage,'&',1).c_str());
        actRGBonoff=atoi(getValue(szMessage,'&',2).c_str());
      FastLED.show();
    mfalkviddM DwaltD 2 Replies Last reply
    • M mrcage
      Hi There!
      1 Motion Sensor
      1 RGB strip
       FILE: AWI_RGB.ino
       Special:
       Remarks:
        Fixed node-id
      // Door
          #define CHILD_ID 6
      // Dallas temp
      // Motion Sensor
      /// RGB Strip
      // Start MySensor
      //Dallas
          int numSensors=3;
      // Door
          int oldValue=-1;
        sensors.begin();
        // RGB Strip
        colorBars();
        // Door
           // Setup the button
        // Motion Sensor
        // Door
              debouncer.update();
               oldValue = value;
        //Dallas Temp
              #else
        // Motion Sensor
      void colorBars()
          leds[i] = lcolor;
       int found = 0;
        found++;
          actRGBonoff=1;
          actRGBonoff=1;
        FastLED.show();
      The code looks pretty ok to me. Proper indentation (ctrl+t) would be nice though.
      What is the serial output when DEBUG is enabled?
      Perhaps add some debug print in the loop would help troubleshooting.
      • M mrcage
        Hi There!
        1 Motion Sensor
        1 RGB strip
         FILE: AWI_RGB.ino
         Special:
         Remarks:
          Fixed node-id
        // Door
            #define CHILD_ID 6
        // Dallas temp
        // Motion Sensor
        /// RGB Strip
        // Start MySensor
        //Dallas
            int numSensors=3;
        // Door
            int oldValue=-1;
          sensors.begin();
          // RGB Strip
          colorBars();
          // Door
             // Setup the button
          // Motion Sensor
          // Door
                debouncer.update();
                 oldValue = value;
          //Dallas Temp
                #else
          // Motion Sensor
        void colorBars()
            leds[i] = lcolor;
         int found = 0;
          found++;
            actRGBonoff=1;
            actRGBonoff=1;
          FastLED.show();
        DwaltD
        DwaltD
        Dwalt
        @mrcage Do your temp sensors show up at all (as child devices) to your controller or are they just not sending data?
        You changed one define:
        int numSensors=3;
        I don't know if it is necessary, you call for a device count later in setup.
        What hardware are you using? Mega? You have typical 'interrupt' driven devices, door and motion...but you have your one wire bus on pin3 (interrupt 1) and define your motion interrupt as interrupt 2 (pin 4 minus 2 is 2)? I would suggest putting door and motion on pins 2 & 3, set up as interrupt functions and don't poll them continuously in the loop. I would also remove the sleep function since you are expecting incoming messages for your RGB strip and use millis to establish how often you check the Dallas sensors.
