  3. Dust Sensor (1.4)
Dust Sensor (1.4)
26 Posts 5 Posters 27.4k Views 5 Watching
  • epierreE
    epierreE
    epierre
    The Shinyei PPD42 has now its sketch :
    https://github.com/empierre/arduino/blob/master/DustSensor_Shinyei_PPD42NS.ino
    @hek either the SamYoung or Shinyei can be proposed, the sharp is definetly out of the race ...
    Both those sensors give similar values whih is a very good point.
    z-wave - Vera -> Domoticz
    • epierreE
      epierreE
      epierre
      • epierreE
        epierreE
        epierre
        A good question I had from Rob:
        What is the Unit of the Dust sensors ? I quess it is not in ppm ?
        This is in particules per cubic inch (in imperial units) or particules per 283 ml.
        I can't find a ppm conversion, at best I could do a particules per litres by multiplicating per 3.53. what do you think ?
        • epierreE
          epierreE
          epierre
          wrote on last edited by epierre
          #24
          ok so taking some assumptions for the PPD42NS with datasheet in particle per cubic feet:
          http://billpentz.com/woodworking/cyclone/dylos.cfm
           To estimate the mass of particles in this range we simply divided by 100 to obtain micrograms per cubic meters (μg/m3) of PM2.5 respirable. The resultant value can be converted to mg/m3 if desired by dividing again by 1000.
           PM2.5 = (753*3.53) / 100 = 25.2395 μg/m3  = 0.0252395 mg/m3
          Now for the DSM501 and PPD42NS corrected, the formula to PPM:
          https://en.wikipedia.org/wiki/Air_pollutant_concentrations
          ppmv=mg/m3 * (0.08205*Tmp)/Molecular_mass
          ppmv=0.0252395 *  (0.08205*19)/0,01 = 0,207
          • epierreE
            epierreE
            epierre
            Warning on Shinyei:
            The only calibration data provided by the manufacturer's datasheet is for cigarette smoke particle count concentration. Based on these data, there is an approximate error of 25% in particle measurement across most of the sensor's range. At very low concentrations, the error becomes substantial (e.g., over 50% error below 100,000 particles per cubic feet)
            http://www.researchgate.net/publication/271225140_A_distributed_network_of_low-cost_continuous_reading_sensors_to_measure_spatiotemporal_variations_of_PM2.5_in_Xi'an_China
            • Tore André RosanderT
              Tore André Rosander
              wrote on last edited by Tore André Rosander
              #26
              Does anyone have info on how to wire the GP2Y1010AU0F?
              My cable is almost the same as on the picture https://www.mysensors.org/build/dust
              The red, black and yellow is in the same place, but from there it goes white, green, blue.
              EDIT: Found that Red is vcc, black is signal and yellow is ground.
              Do this sensor need calibration?
              And what is considered a high value for dust?
              And is it only those three wires that needs to be connected to the arduino? Not the led?
