  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 141.9k Views 7 Watching
  • M msebbe
    @celonunes
    Yes, both from windows cmd and from the router ui with this result:
    PING 192.168.1.197 (192.168.1.197): 56 data bytes
    --- 192.168.1.197 ping statistics ---
    5 packets transmitted, 0 packets received, 100% packet loss
    Could be that I have not changed the MAC adress cause I tried to figure out how to do it but I dont understand this part from the MQTT gateway sketch:
    *1 -> NOTE: Keep first byte at x2, x6, xA or xE (replace x with any hex value) for using Local Ranges.
     #define TCP_PORT 1883						// Set your MQTT Broker Listening port.
     IPAddress TCP_IP ( 192, 168, 1, 197 );				// Configure your static ip-address here
     uint8_t TCP_MAC[] = { 0x02, 0xDE, 0xAD, 0x00, 0x00, 0x42 };	// Mac-address - You should change this! see note *2 above!
    M Offline
    M Offline
    marceloaqno
    Code Contributor
    @msebbe Which library your are using for the ENC28J60? The UIPEthernet has some examples you could try to test if your module is working.
    M 1 Reply Last reply
    • M marceloaqno
      @Chaotic said:
      The MQTT Broker is the MQTT server so if I wanted to use this with openhab on a pi I would just need the MQTT plugin and then point it to the IP of the gateway?
      That's right.
      C Offline
      C Offline
      Chaotic
      @celonunes
      Just wanted to say I was able to get this working.
      Also found a nice little MQTT utility that makes it easy to see the messages being sent from the broker/openhab.
      I'm sure I'll have more questions but most of my hardware is still on a boat from china so will be a little while till I discover them.
      • M marceloaqno
        M Offline
        M Offline
        msebbe
        wrote on last edited by msebbe
        #103
        @celonunes In the Mqtt broker sketch, Ethernet.h was included. I suppose it should be UIPEthernet.h for me? So I tried that but nothing.
        I had better luck with the UIPEthernet examples, there my arduino shows up with an ip and mac adress.. Hmmm.
        edit:
        So after using UIPEthernet "Advanced chat server" sketch, the MAC and IP showed up in my router. When I then tried with the MQTT sketch with UIPEthernet.h it would not work. So then I tried to copy the MAC and IP I used in the chat server sketch into the Mqtt sketch and bom! I can now ping it, so I guess it works now?
        edit2: Should it say anything more then "Started!" on serial monitor? Like "on ip 192.168.1.197" or something like that? Since Im now trying the MQTT in pidome as I know how to use pidome better. Pidome states;
        Connected: Yes, with 192.168.1.197:1883 at topic: MyMQTT/# (without subscribe promise)
        Last receive time: 00-00-0000 00:00
        Last send time: 00-00-0000 00:00
        This is what Serial monitor says http://i61.tinypic.com/i252kn.png
        But when I use device discovery it cannot find the temperature sensor that could be found using the serial gateway :/
        • C Offline
          C Offline
          Chaotic
          Hi everyone,
          Finally got this working but had a couple of quetions
          Does the MQTT Broker gateway not handle requests for time? I currently have a node that I'm using as an alarm clock which has a RTC module. I had hoped to be able to update the time via the gateway and polling the time from one of my computers which are connected to NTP servers but the message never seems to get put on a MQTT message so I can't have a computer respond to it.
          • M msebbe
            edit:
            M Offline
            M Offline
            marceloaqno
            Code Contributor
            #105
            @msebbe It doesn't print your ip, those numbers after "Started!" is related to mqtt packages showing that PiDome is connected.
            For the device discovery, there are probably a lot of other people who can help you with that because I don't know much about PiDome.
            • C Chaotic
              Hi everyone,
              M Offline
              M Offline
              marceloaqno
              Code Contributor
              @Chaotic MQTT Broker gateway doesn't handle time requests.
              • M marceloaqno
                That's right.
                M Offline
                M Offline
                msebbe
                #107
                @celonunes Ok, thanks! I got the discovery working by just rebuilding the same sensor from scratch!
                Sorry for so many questions.. But I have now changed to Openhab and got it working with my MQTT gateway. Now Another problem appear:
                http://i60.tinypic.com/2d2eqzk.png[/IMG
                I would like to display the temperature in °C like in your guide sketch (wich I am using) but instead it looks like in the picture. Same thing about humidity, why is it like this?
                Edit: For anyone wondering, I solved the issue with the degree symbol not showing up properly by replacing "°C" with "& deg;C" without space between & deg
                • Brett JenkinsB Offline
                  Brett Jenkins
                  Hi Folks,
                  New to mysensors and am impressed. I've been playing with OpenHAB and MQTT so this sounds like an interesting project. My question though, which might have been answered but I'm finding it hard to find the answer, is - is this bidirectional? As in if I had a 'sensor' on the Arduino network and that went over the radio network, hit the gateway and then got picked up by OpenHAB, could I then, if I had a 'actuator' or a 'do-er' node on the network, send a message to MQTT from OpenHAB to change the status of that actuator device? So for instance to start a motor controlling blinds for instance? Or is it a read only system?
                  C 1 Reply Last reply
                  • Brett JenkinsB Brett Jenkins
                    Hi Folks,
                    C Offline
                    C Offline
                    Chaotic
                    @Brett-Jenkins
                    It works both ways.
                      Brett Jenkins
                      • K Offline
                        K Offline
                        kunall
                        wrote on last edited by kunall
                        #111
                        How can I implement MQTT for MQ-2 Gas sensor the correct way? In the mysensor sketch there is only one child ID and one V_VAR1 but 3 different outputs: LPG, CO and Smoke? I'm only receiving CO value and not all 3 in openhab.
                        • K kunall
                          C Offline
                          C Offline
                          Chaotic
                          @kunall There is V_VAR1-5 actually
                          V_VAR1	24	Custom value
                          V_VAR2	25	Custom value
                          V_VAR3	26	Custom value
                          V_VAR4	27	Custom value
                          V_VAR5	28	Custom value
                          Personally I would set up each value you want as a S_CUSTOM if you can't figure out another sensor type that fits.
                          For smoke you can use S_SMOKE
                          For Air Quality S_AIR_QUALITY
                          Not sure what you'd want to use for CO2 through
                          http://www.mysensors.org/download/serial_api_14
                          K 1 Reply Last reply
                          • C Chaotic
                            K Offline
                            K Offline
                            kunall
                            #113
                            @Chaotic Thanks! I will try this and get back with result.
                            • D Damme
                              How to Set-up MQTTGateway with OpenHAB
                              What is MQTTGateway:
                              MQTTGateway will act as a broker, a server. And any MQTT clients should be able to connect to it (Please let me know if you experience problems).
                              MQTTGateway is a very simple implementation. It will not care if the client subscribes to anything or not.
                              Every node package it receives it will publish to the client. Sketch name and version is also implemented.
                              Most clients handle this well and just ignores messages it hasn't been subscribed yet.
                              There are some settings in MQTT that can be good to take a look at.
                              You will need to configure TCP_IP and TCP_PORT.
                              MQTTGateway will also give nodes an ID between MQTT_FIRST_SENSORID and MQTT_LAST_SENSORID. The last position is stored in EEprom.
                              As standard MQTT_SEND_SUBSCRIPTION is enabled. This basically means that the broker will send a empty payload to the node upon a subscribe package. This can be useful. Just keep in mind that you can receive empty payload packages.
                              The MQTTGateway will also present its SketchName and SketchVersion.
                              Lets get started!
                              First follow https://github.com/openhab/openhab/wiki/Quick-Setup-an-openHAB-Server You can setup and try with DEMO configuration first.
                              Then we need to unpack org.openhab.binding.mqtt into addons folder * NOTE (During development of MQTTGateway I found a bug inside openhab mqtt client which is solved in 1.6.0 nightly build. Use this nightly addon if you experience problems)
                              • openhab.cfg
                                All you need to do here is to add
                                mqtt:mysensor.url=tcp://192.168.0.234:1883
                                mqtt:mysensor.clientId=MQTT
                              ClientID does not matter at all (just keep it short). And IP and Port is self explanatory.
                              Now you can start OpenHAB, it will connect but nothing more will happen.
                              This is because we hasn't subscribed to anything and OpenHAB will just ignore every incoming package.
                              So here comes a sample configuration of OpenHAB.
                              • items/test.items
                                Group all
                                Group node1 (all)
                                Group node2 (all)
                                Group sketch (all)
                                Number node1_temp "Temp [%.1f °C]" (node1,all) {mqtt="<[mysensor:MyMQTT/20/10/V_TEMP:state:default]"}
                                Number node1_humid "Humid [%.1f %%Rh]" (node1,all) {mqtt="<[mysensor:MyMQTT/20/11/V_HUM:state:default]"}
                                Switch node2_sw1 "sw2" (node2,all) {mqtt=">[mysensor:MyMQTT/21/1/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/21/1/V_LIGHT:command:OFF:0]"}
                                Switch node2_sw2 "sw2 send + recieve example" (node2,all) {mqtt=">[mysensor:MyMQTT/21/2/V_LIGHT:command:ON:1],>[mysensor:MyMQTT/21/2/V_LIGHT:command:OFF:0],<[mysensor:MyMQTT/21/2/V_LIGHT:command:MAP(1on0off.map)]"}
                                String sketch20 "Sketch name 20 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/20/255/V_SKETCH_NAME:state:default]"}
                                String sketch21 "Sketch name 21 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/21/255/V_SKETCH_NAME:state:default]"}
                                String sketch22 "Sketch name 22 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/22/255/V_SKETCH_NAME:state:default]"}
                                String sketch23 "Sketch name 23 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/23/255/V_SKETCH_NAME:state:default]"}
                                String sketch24 "Sketch name 24 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/24/255/V_SKETCH_NAME:state:default]"}
                                String sketch25 "Sketch name 25 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/25/255/V_SKETCH_NAME:state:default]"}
                                String sketch26 "Sketch name 26 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/26/255/V_SKETCH_NAME:state:default]"}
                                String sketch27 "Sketch name 27 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/27/255/V_SKETCH_NAME:state:default]"}
                                String sketch28 "Sketch name 28 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/28/255/V_SKETCH_NAME:state:default]"}
                                String sketch29 "Sketch name 29 [%s]" (sketch,all) {mqtt="<[mysensor:MyMQTT/29/255/V_SKETCH_NAME:state:default]"}
                              We also need to create a sitemap :
                              • sitemap/test.sitemap
                                sitemap demo label="Menu"
                                Frame label="test" {
                                Group item=node1 label="Temp hum node"
                                Group item=node2 label="Switch node"
                                Group item=sketch label="Sketch names"
                                Group item=all label="Everything"
                              and a simple transformation file :
                              • transform/1on0off.map
                                1=ON
                                0=OFF
                              If everything worked and I didn't forget anything just fire up :
                              http://[Openhab]:8080/openhab.app?sitemap=test
                              After you restart one of your node's the data and sketch name should be visible.
                              Openhab will forget everything after every restart. Use persistence to fix this (https://github.com/openhab/openhab/wiki/rrd4j-Persistence)
                              A Offline
                              A Offline
                              artur
                              @Damme
                              how to run MySensors ( MQTT gateway) on the arduino due + Wiznet5100 + NRf24l01?
                              Get the error:
                              Arduino: 1.5.8 (Windows 8), Board: "Arduino Due (Programming Port)"
                              In file included from Z:\arduino-1.5.8-new\libraries\DigitalIO/DigitalIO.h:31:0,
                                               from EthernetGateway.ino:41:
                              Z:\arduino-1.5.8-new\libraries\DigitalIO/DigitalPin.h:30:20: fatal error: avr/io.h: No such file or directory
                               #include <avr/io.h>
                              compilation terminated.
                              Ошибка компиляции.
                                enabled in File > Preferences.
                              • H hooraysimpsons
                                @celonunes Nope. I figured it out. In my openhab config file there was space prior to my MQTT related lines
                                " mqtt:mysensor.url=tcp://192.168.1.134:1883"
                                " mqtt:mysensor.clientId=OpenhabMQTT"
                                Instead of
                                "mqtt:mysensor.url=tcp://192.168.1.134:1883"
                                "mqtt:mysensor.clientId=OpenhabMQTT"
                                Removed the space and now I get my light sensor output value. I still don't get the sketch name coming through but I'll look into that later.
                                IdeasKickerI Offline
                                IdeasKicker
                                @hooraysimpsons this solved my problem too! Everything else in my setup was a quick job but problem solving this issue took half a day. It should be more widely circulated..
                                • S Offline
                                  siod
                                  Hi guys,
                                  I dind´t read all comments so I hope this wasn´t answered before: I would like to know how to setup an arduino + NRF24L01 Node:
                                  • how to initialize the node
                                  • what should the Arduino sketch look like to start MQTT
                                  Thanks for your help!!
                                  still learning...
                                  • S Offline
                                    siod
                                    Ok,forget my last post, I have a new problem:
                                    When I uplaod the EthernetGW Sketch to my arduino nano I can see MQTT messages coming in from one node int the arduino serial monitor. So now I uploaded the MQTTGW sketch to my nano because I would like to use openhab. But after uploading the sketch all info I get from serial monitor is "Started!", nothing else is showing up.
                                    I can still ping the MQTT gateway but it seems like it´s not receiving any mqtt message, at least no the state of my node. Could you please help and support me here? Thanks in advance!
                                    still learning...
                                    • S Offline
                                      siod
                                      nobody experiencing this problem? Any idea how I could start fixing this? Pls help!
                                      still learning...
                                      • E Offline
                                        E Offline
                                        engy
                                        I have made this gateway with W5100.
                                        Everything looks OK, except random connection failures.
                                        Clients - MyMQTT (android), Openhab are loosing contact with the broker time after time.
                                        The issue can occur every 5 - 60 mins.
                                        Any ideas what could be the problem?
                                        Thank you in advance.
                                        • D Offline
                                          drock1985
                                          Was hoping someone could help a MQTT and openHab newb here. i have Openhab configured and running with Phillips Hue and Wemo, and trying to integrate MySensors. I build the 1.5 version MQTT gateway using the W5100 module, and all is working (can ping the gateway noproblem, and receiving data from a sensor). The problem is, i'm not sure how to add the line into the items and sitemap file....
                                          Here is the output that I am getting from the MQTT serial monitor. The sensor I have connected is a 3-in-1 with motion PIR, and DHT22 temp/humid and a hard configured Node_ID of 3 (or, should be).
                                          0;0;3;0;9;read: 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
                                          0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.3
                                          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.1
                                          0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.2
                                          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.0
                                          0;0;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.9
                                          0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.4
                                          Can someone help me get the information to display in OpenHab? Please.
                                          My Projects
                                          2 Door Chime Sensor
                                          Washing Machine Monitor
                                          12.2k
