  3. Burned out RPi?
Burned out RPi?
2 Posts 2 Posters 4.0k Views 2 Watching
  • barduinoB
    barduinoB
    barduino
    Hi Folks,
    Risking a bit of an off-topic, I was wondering if this community could help on this.
    I was using an RPi with a serial gateway connected running mosquitto and openhab fine for more than a month.
    Yesterday the raspberry stopped recognizing anything plugged in the USB ports.
    Otherwise seems working fine.
    I got the dreaded message "usb 1-1-port2: over-current change" with nothing connected to the USB's.
    The red light is always on, the green blinks occasionally and the RPi boots normally form the SD card
    I'm using a 2 amp "good"power supply.
    Has anyone experienced this? Is it solvable?
    • D
      D
      Drcashman
      You might find fix here.
      https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=110164
