  3. Parking Sensor problem
5 Posts 4 Posters 1.9k Views 3 Watching
  • mikeg291M
    mikeg291M
    mikeg291
    Just completed building the parking sensor project and interfaced it to a Vera edge via NRF2501,s and every thing works. The problem I am having is the sensor (monitoring it with serial monitor to confirm ) when a vehicle is parked it changes states ever 5 seconds from car parked to car gone . this does not occur when vehicle is actually gone . It reports correctly. I have verified connections, reloaded the sketch and now I am at a complete loss . Any suggestions .
      Welcome @mikeg291 !
      Uncomment this
      //  Serial.println(fullDist);
      and see what the serial output look like. That should give a clue into what is happening.
      • mikeg291M mikeg291
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        wrote on last edited by BulldogLowell
        @mikeg291
        It could be that transient sound waves are reflecting/scattering around and affecting the readings. The NewPing library states that 29milliseconds should be the shortest delay between reads.
        Sound travels a little more than one foot in 1millisecond so you have an inherent delay in an empty garage; 15 feet each way, for example is about 30milliseconds from ping to read.
        So, if you insert a delay(50) after you obtain the distance you may leave enough time for all of the sound to be absorbed or reflected away.
          unsigned long now = millis();
          unsigned int fullDist = (sonar.ping_median() / US_ROUNDTRIP_CM);
          int displayDist = min(fullDist, MAX_DISTANCE);
          if (displayDist == 0 && skipZero<10) {
            // Try to filter zero readings
            skipZero++;
            return;
          delay(50);  // try this
          // etcetera
        finch666F 1 Reply Last reply
          @mikeg291
              skipZero++;
              return;
            // etcetera
          finch666F
          finch666F
          finch666
          @BulldogLowell said:
          @mikeg291
          I second this. Built the sensor with a neopixel ring and the leds go berserk when I am about 3 cm away from the sensor with my hand.
          • mikeg291M
            mikeg291M
            mikeg291
            Problem solved Turned out to be a bad sensor and with mfalkvidd 's suggestion troubleshooting was a lot easier . Thanks
