  3. Yet another PCB to address (nearly) all Arduino pins
26 Posts 6 Posters 12.6k Views 9 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @tbowmo I have been working on a similar board. The matter of external connections for switches and external sensors keeps me busy. The 1,27 mm spaced headers seem like a possible solution. But I have not found any female headers with wires (Dupont style) to go with the male versions. How do you solve the connection problem ?
    • P
      P
      phil83
      @GertSanders: On aliexpress you can find sets of male and female 1.25mm connectors, do you think about something like that:
      http://de.aliexpress.com/item/20sets-Micro-1-25mm-5pin-Cable-JST-1-25-5-Pin-Male-Female-Connector-plug-with/32464250609.html?spm=2114.010208.3.2.BMcTZF&ws_ab_test=searchweb201556_9,searchweb201644_5_505_506_503_504_301_10020_502_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_2,searchweb1451318400_-1,searchweb1451318411_6448&btsid=8ded8c25-db33-49ed-835b-307cb83c0f47
      • P
        P
        phil83
        As I read your post again, you mean something like this:
        http://de.aliexpress.com/item/5-sets-Double-Row-Female-Socket-SMD-2-10-20pin-1-27mm-Pin-Header-connector/32542921161.html?isOrigTitle=true
        • P phil83
          GertSandersG
          GertSandersG
          GertSanders
          @phil83 the micro connector set with the wires is a very good suggestion. I will look around some more.
          • P
            P
            phil83
            I finally went on with the project and received the pcbs last week... my soldering oven is running and I could finish the first board (still some parts are missing :-( ) If only I had more time to work on that...
            Here are some impressions:
            I soldered some cables so that I can program it and check via ftdi...
            More to come soon...
            • P phil83
              GertSandersG
              GertSandersG
              GertSanders
              @phil83
              Share this on OpenHardware.io !
