  3. Bootloader and fuses for Pro Mini 3.3V using Arduino UNO as ISP
25 Posts 4 Posters 21.6k Views 2 Watching
  • Suresh MaliS Suresh Mali
    @mfalkvidd AVRDudess works with AVRISP mkii as well. Have you tried to detect the Pro Mini chip using AVRDudess+AVRISPMkii. Are you able to detect the chip using Mkii in AVRDudess?
    @Suresh-Mali I have tried, but without success. See the last three paragraphs in http://forum.mysensors.org/topic/3304/bootloader-and-fuses-for-pro-mini-3-3v-using-arduino-uno-as-isp/11
      #22
      Finally some success!
      I am now able to read and write the fuses on my Pro Minis using Arduino as ISP.
      I have uploaded the Arduino as ISP sketch (File->Examples->ArduinoISP in the Arduino IDE) to my Uno and connected the Uno to the Pro Mini as per the instructions in the sketch. The key was to use -b 19200 as parameter to avrdude, without that I'm unable to connect.
      Log from reading the fuses:
      C:\Users\Micke>"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude" -C"C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrd
      ude.conf" -v -patmega328p -c stk500v1 -Pcom3 -b 19200
      avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
               Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
               Copyright (c) 2007-2009 Joerg Wunsch
               System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
               Using Port                    : com3
               Using Programmer              : stk500v1
               Overriding Baud Rate          : 19200
               AVR Part                      : ATmega328P
               Chip Erase delay              : 9000 us
               PAGEL                         : PD7
               BS2                           : PC2
               RESET disposition             : dedicated
               RETRY pulse                   : SCK
               serial program mode           : yes
               parallel program mode         : yes
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
                                        Block Poll               Page                       Polled
                 Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                 eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                 flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                 lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                 signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
               Programmer Type : STK500
               Description     : Atmel STK500 Version 1.x firmware
               Hardware Version: 2
               Firmware Version: 1.18
               Topcard         : Unknown
               Vtarget         : 0.0 V
               Varef           : 0.0 V
               Oscillator      : Off
               SCK period      : 0.1 us
      avrdude: AVR device initialized and ready to accept instructions
      Reading | ################################################## | 100% 0.06s
      avrdude: Device signature = 0x1e950f
      avrdude: safemode: lfuse reads as FF
      avrdude: safemode: hfuse reads as DA
      avrdude: safemode: efuse reads as 5
      avrdude: safemode: Fuses OK (H:05, E:DA, L:FF)
      avrdude done.  Thank you.
      Log from writing the extended fuse to the same value it already has;
      ude.conf" -v -patmega328p -c stk500v1 -Pcom3 -b 19200 -Uefuse:w:0x05:m
               Using Port                    : com3
               PAGEL                         : PD7
               BS2                           : PC2
               RETRY pulse                   : SCK
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
               Hardware Version: 2
               Topcard         : Unknown
               Vtarget         : 0.0 V
               Varef           : 0.0 V
               Oscillator      : Off
               SCK period      : 0.1 us
      avrdude: reading input file "0x05"
      avrdude: writing efuse (1 bytes):
      Writing | ################################################## | 100% 0.03s
      avrdude: 1 bytes of efuse written
      avrdude: verifying efuse memory against 0x05:
      avrdude: load data efuse data from input file 0x05:
      avrdude: input file 0x05 contains 1 bytes
      avrdude: reading on-chip efuse data:
      Reading | ################################################## | 100% 0.02s
      avrdude: verifying ...
      avrdude: 1 bytes of efuse verified
      Log from turning off BOD:
      ude.conf" -v -patmega328p -c stk500v1 -Pcom3 -b 19200 -Uefuse:w:0x07:m
               Using Port                    : com3
               PAGEL                         : PD7
               BS2                           : PC2
               RETRY pulse                   : SCK
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
               Hardware Version: 2
               Topcard         : Unknown
               Vtarget         : 0.0 V
               Varef           : 0.0 V
               Oscillator      : Off
               SCK period      : 0.1 us
      avrdude: reading input file "0x07"
      Writing | ################################################## | 100% 0.05s
      avrdude: verifying efuse memory against 0x07:
      avrdude: load data efuse data from input file 0x07:
      avrdude: input file 0x07 contains 1 bytes
      avrdude: safemode: efuse reads as 7
      avrdude: safemode: Fuses OK (H:07, E:DA, L:FF)
        And I'm also able to upload a new bootloader to Pro Minu from Arduino IDE using an Arduino UNO as ISP.
        The ArduinoISP guide says that I might need to put a capacitor between reset and gnd on the Uno, but what I had to do is put a capacitor (0.1uF) on between reset and gnd the target Arduino Pro Mini.
        I don't understand why I need to do that, but uploading fails (avrdude says "verification error") 10 out of 10 tries without the capacitor. Upload is successful 10 out of 10 times with the capacitor.
        This is the log from a successful upload, in case it is useful for anyone else:
        C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
                 Using Port                    : COM3
                 PAGEL                         : PD7
                 BS2                           : PC2
                 RETRY pulse                   : SCK
                 Timeout                       : 200
                 StabDelay                     : 100
                 CmdexeDelay                   : 25
                 SyncLoops                     : 32
                 ByteDelay                     : 0
                 PollIndex                     : 3
                 PollValue                     : 0x53
                 Memory Detail                 :
                 Hardware Version: 2
                 Topcard         : Unknown
                 Vtarget         : 0.0 V
                 Varef           : 0.0 V
                 Oscillator      : Off
                 SCK period      : 0.1 us
        avrdude: erasing chip
        avrdude: reading input file "0x3F"
        avrdude: writing lock (1 bytes):
        avrdude: 1 bytes of lock written
        avrdude: verifying lock memory against 0x3F:
        avrdude: load data lock data from input file 0x3F:
        avrdude: input file 0x3F contains 1 bytes
        avrdude: reading on-chip lock data:
        avrdude: 1 bytes of lock verified
        Writing | ################################################## | 100% 0.06s
        avrdude: reading input file "0xDA"
        avrdude: writing hfuse (1 bytes):
        Writing | ################################################## | 100% 0.02s
        avrdude: 1 bytes of hfuse written
        avrdude: verifying hfuse memory against 0xDA:
        avrdude: load data hfuse data from input file 0xDA:
        avrdude: input file 0xDA contains 1 bytes
        avrdude: reading on-chip hfuse data:
        avrdude: 1 bytes of hfuse verified
        avrdude: reading input file "0xFF"
        avrdude: writing lfuse (1 bytes):
        C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex:i -Ulock:w:0x0F:m
        avrdude: 1 bytes of lfuse written
        avrdude: verifying lfuse memory against 0xFF:
        avrdude: load data lfuse data from input file 0xFF:
        avrdude: input file 0xFF contains 1 bytes
        avrdude: reading on-chip lfuse data:
        avrdude: 1 bytes of lfuse verified
                 Using Port                    : COM3
                 PAGEL                         : PD7
                 BS2                           : PC2
                 RETRY pulse                   : SCK
                 Timeout                       : 200
                 StabDelay                     : 100
                 CmdexeDelay                   : 25
                 SyncLoops                     : 32
                 ByteDelay                     : 0
                 PollIndex                     : 3
                 PollValue                     : 0x53
                 Memory Detail                 :
                 Hardware Version: 2
                 Topcard         : Unknown
                 Vtarget         : 0.0 V
                 Varef           : 0.0 V
                 Oscillator      : Off
                 SCK period      : 0.1 us
        avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
                 To disable this feature, specify the -D option.
        avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex"
        avrdude: writing flash (32652 bytes):
        Writing | ################################################## | 100% 0.00s
        avrdude: 32652 bytes of flash written
        avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex:
        avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex:
        avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex contains 32652 bytes
        avrdude: reading on-chip flash data:
        Reading | ################################################## | 100% -0.00s
        avrdude: 32652 bytes of flash verified
        avrdude: reading input file "0x0F"
        avrdude: verifying lock memory against 0x0F:
        avrdude: load data lock data from input file 0x0F:
        avrdude: input file 0x0F contains 1 bytes
        • L
          L
          LastSamurai
          The cap definitly has to on the programmer (uno) between reset and ground. Otherwise when you try to reset the target board for reprogramming you just reset the programmer (and then the programming fails).
          Strange that it worked the other way.
            After visiting @m26872 and getting great insights to his workflow and his projects, I can report this:
            • The avrisp mk ii I borrowed from a co-worker does not work. So that's why I wasn't successful using that device. AVR Studio gave some helpful error messages, much more helpful than Arduino IDE, so lesson learned: Use AVR Studio when troubleshooting.
            • Using my Arduino Uno as ISP worked fine at his place, even without the capacitor. When I got home, I tried 10 times without the capacitor and all but 1 were successful. Strange. But at least it works :)
            • We were not able to revive any of the 4 Pro Mini i "bricked" when experimenting. Good thing they are so cheap :)
            A BIG thanks to m26872 for helping me and for a nice visit to his home.
