  3. RFM69HW serial output no data
3 Posts 2 Posters 1.3k Views 2 Watching
  • SweebeeS Offline
    SweebeeS Offline
    Sweebee
    My gateway receives this:
    0;0;3;0;9;read: 1-1-0 s=1,c=3,t=16,pt=0,l=0,sg=0:
    while it should receive?
    0;0;3;0;9;read: 1-1-0 s=1,c=3,t=16,pt=0,l=0,sg=0:1
    My sketch:
    #include <MyTransportRFM69.h>
    #include <MySigningAtsha204Soft.h>
    #define NODE_ID 1
    #define PIN_G 4
    #define PIN_O 5
    #define PIN_R 6
    int sentG = 1;
    int sentO = 1;
    int sentR = 1;
    //Construct MySensors library
    MyHwATMega328 hw;
    MyMessage groen(1, V_TRIPPED);
    MyMessage oranje(2, V_TRIPPED);
    MyMessage rood(3, V_TRIPPED);
    MyTransportRFM69 transport;
    MySensor gw(transport, hw);
    /* Initialization        */
        pinMode(PIN_G, INPUT);
        digitalWrite(PIN_G, HIGH);
        pinMode(PIN_O, INPUT);
        digitalWrite(PIN_O, HIGH);
        pinMode(PIN_R, INPUT);
        digitalWrite(PIN_R, HIGH);
        gw.begin(NULL, NODE_ID, false);
    /* Main loop        */
    void loop(){
      // GROENE KNOP
      int valueG = digitalRead(PIN_G);
        if (valueG != sentG) {
          Serial.println("GROEN");
          gw.send(groen.set(1));
          sentG = valueG;
      // ORANJE KNOP
      int valueO = digitalRead(PIN_O);
      if (valueO != sentO) {
        Serial.println("ORANJE");
        gw.send(oranje.set(1));
        sentO = valueO;
      // RODE KNOP
      int valueR = digitalRead(PIN_R);
      if (valueR != sentR) {
        Serial.println("ROOD");
        gw.send(rood.set(1));
        sentR = valueR;
    • SweebeeS Sweebee
      My sketch:
      #define NODE_ID 1
      #define PIN_G 4
      #define PIN_O 5
      #define PIN_R 6
      int sentG = 1;
      int sentO = 1;
      int sentR = 1;
      MyHwATMega328 hw;
      /* Main loop        */
      void loop(){
        // GROENE KNOP
            sentG = valueG;
        // ORANJE KNOP
          sentO = valueO;
        // RODE KNOP
          sentR = valueR;
      martinhjelmareM Offline
      martinhjelmare
      @Sweebee
      The serial output you've received is an internal message about signing nonce.
      You don't present the sensors in setup, which is why you don't see any more output, about sensors tripping.
      See:
      http://www.mysensors.org/download/sensor_api_15
      and
      http://www.mysensors.org/download/serial_api_15
      and
      http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/3
      • SweebeeS Offline
        SweebeeS Offline
        Sweebee
        Yes thanks, totally forgot that.
