  3. How to take a reading from MiCS 4514
4 Posts 2 Posters 2.8k Views 1 Watching
  • B
    B
    bhavika
    I am confused with MiCS 4514 sensor. What I had done is :
    1. using MiCS quick start evaluation board, measured ADC value
    2. calculated Vout and from that calculated R0.
    3. Rs/R0 concentration gives me high value, which is not possible, My data is as follows
      clean air file is used for the purpose of R0 value
      https://drive.google.com/file/d/0B8sF8a6FHoseWjhWOHRoYzIxakk/view?usp=sharing
    and Polluted file is used to calculate the actual pollution
    https://drive.google.com/file/d/0B8sF8a6FHoseR1BnclhCUHdibEU/view?usp=sharing
    I am confused. Please help me
    • epierreE
      epierreE
      epierre
      is your R0 in Ohm or KOhm in your formula ?
      z-wave - Vera -> Domoticz
      • B
        B
        bhavika
        Its in ohm
        • B
          B
          bhavika
          In clean air, I calculated the value of R0 by using MiCS quick evaluation board.
          Formula applied :(ADC/(RESOLUTION - ADC)) * 51820---for NO2
          and (ADC/(ADC-RESOLUTION))*100820 -- for CO
          and in polluted air I applied same formula and gave it a name Rs
          Then took ratio of Rs/R0 which is less than one.
          So I had a slope and its constant meand y = m*x + c
          But i do not know how to derive equation to find out the value of ppm from Rs/0
