  3. ATMEGA328 PullUp Resistor
4 Posts 3 Posters 2.6k Views 4 Watching
  • SoloamS
    SoloamS
    Soloam
    Hello, I would like to make a smaller solution to my nodes, so I'm going to make a standalone ATMEGA 328 solution.
    I have the node working and I would like to use it to make a switch, when I press a button I want my ATMEGA to do something (for example turn on the light). Can I use the same approach that it's used here http://www.mysensors.org/build/binary ? Ground to Digital pin with a switch in the middle! Electronic is not my strong point, and I don't want to blow my atmegas.
    Thank You
    • peteoritoP
      peteoritoP
      peteorito
      Yes! with digitalWrite(BUTTON_PIN,HIGH); you put BUTTON_PIN with A PullUp Resistor
      • AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        The code:
        // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
        could/ should be replaced by, more natural and easy to comprehend... (since IDE 1.0.1)
        // Setup the button and internal pull_up
          pinMode(BUTTON_PIN, INPUT_PULLUP);
        • SoloamS
          SoloamS
          Soloam
          Thank you all for the fast response!
          Best Regards
