Signing_Soft in dev branch - How to do?
@Anticimex I thought to be using only soft signing...
#include <sha204_library.h> #include <sha204_lib_return_codes.h> #define MY_CORE_ONLY #include <MySensor.h> #if DOXYGEN #define LOCK_CONFIGURATION #define LOCK_DATA #define SKIP_KEY_STORAGE #define USER_KEY #define SKIP_UART_CONFIRMATION #define USE_SOFT_SIGNING #define STORE_SOFT_KEY #define USER_SOFT_KEY #define STORE_SOFT_SERIAL #define USER_SOFT_SERIAL #define STORE_AES_KEY #define USER_AES_KEY #endif //#define LOCK_CONFIGURATION //#define LOCK_DATA //#define SKIP_KEY_STORAGE //#define USER_KEY //#define SKIP_UART_CONFIRMATION #define USE_SOFT_SIGNING #define STORE_SOFT_KEY #define USER_SOFT_KEY #define STORE_SOFT_SERIAL #define USER_SOFT_SERIAL #define STORE_AES_KEY #define USER_AES_KEY #if defined(SKIP_UART_CONFIRMATION) && !defined(USER_KEY) #error You have to define USER_KEY for boards that does not have UART #endif #ifdef USER_KEY /** @brief The user-defined HMAC key to use for personalization */ #define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 /** @brief The data to store in key slot 0 */ const uint8_t user_key_data[32] = {MY_HMAC_KEY}; #endif #ifdef USER_SOFT_KEYI copied the header of the SecurityPersonalizer (just stripped the comments to make it shorter). Do I have activated atsh somewhere without noticing?
@Anduril try ditching the SHA204 library includes at the top. Not sure if they are required for soft signing. Can't remember if I put them there for a reason.... Long time ago I coded for MySensors :(
@Anticimex Thank you. Deactivating those sha libs made the code compile and work.
