  3. Signing_Soft in dev branch - How to do?
24 Posts 3 Posters 6.3k Views 4 Watching
  • AndurilA Anduril
    @Anticimex I completely agree with you that this would not garantee a good random number. Thanks for explaining all this to me.
    One point still open to me is the AES key. Is it only used for encryption (which does not give a real security in our case)? I suppose it should be also kind of pre shared key, so same value on all nodes? I don't want to enable encryption at the moment, but might be good to already write keys to all nodes in case I want to use it in future.
    AnticimexA
    AnticimexA
    Anticimex
    @Anduril also, AES key can and should be different from HMAC key.
    • AndurilA
      AndurilA
      Anduril
      @Anticimex of course they should be different. I will use my password safe to create independent and strong keys.
      What length should the keys have? And how to add them in sketch? I tried with a 64 character hex key. But when adding it in as pure string or with 0x01,0x02,... the serial says all to be 0x00.
      AnticimexA 1 Reply Last reply
      • AndurilA Anduril
        AnticimexA
        AnticimexA
        Anticimex
        @Anduril the only sketch you add the keys to is the personalizer. And it should already have examples for how the keys should look. The personalizer will store your keys on the device. Then you reflash it with your sketch.
        • AndurilA
          AndurilA
          Anduril
          @Anticimex yeah first flash the personalizer and afterwards my own sketch. But where in the personalizer.ino to add the key? I tried in line 162, but serial monitor shows only
          EEPROM configuration:
          SOFT_HMAC_KEY | 0000000000000000000000000000000000000000000000000000000000000000
          #define USER_SOFT_KEY 0xDC, 0x59, 0x84, 0xC0, 0x5E, 0xDA, 0xD3, 0x2C, 0x59, 0x12, 0xB0, 0xE3, 0x55, 0x75, 0x7C, 0x51, 0xDC, 0x59, 0x84, 0xC0, 0x5E, 0xDA, 0xD3, 0x2C, 0x59, 0x12, 0xB0, 0xE3, 0x55, 0x75, 0x7C, 0x51
          with this definition (only arbitrary key). Is that correct?
          • AndurilA Anduril
            AnticimexA
            AnticimexA
            Anticimex
            @Anduril No, you cannot add spaces to the definition. It has to look exactly like the example. And you must not rename it. It's called MY_SOFT_HMAC_KEY. not USER_SOFT_KEY.
            • AndurilA
              AndurilA
              Anduril
              OK i found the problem, I misunderstood something. I thought I have to add the keys to the enabling command of USER_SOFT_KEY. but there are the real keys some lines below that with correct example how to look like. Now it works and I personalized my first node. Thanks a lot @Anticimex
              • AndurilA Anduril
                AnticimexA
                AnticimexA
                Anticimex
                @Anduril :thumbsup:
                • AndurilA
                  AndurilA
                  Anduril
                  @Anticimex Does this also work with a nodeMCU? I tried to personalize my ESP today and got an error:
                  C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp: In constructor 'atsha204Class::atsha204Class(uint8_t)':
                  C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp:16:18: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
                    device_port_DDR = portModeRegister(port);
                  C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp:18:18: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
                    device_port_OUT = portOutputRegister(port);
                  C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp:20:17: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
                    device_port_IN = portInputRegister(port);
                  Bibliothek sha204 im Ordner: C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204 (legacy) wird verwendet
                  Bibliothek MySensors in Version 2.0.0-beta im Ordner: C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\MySensors  wird verwendet
                  Bibliothek EEPROM in Version 1.0 im Ordner: C:\Users\Mat\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\EEPROM  wird verwendet
                  exit status 1
                  Fehler beim Kompilieren.
                  • AndurilA Anduril
                    exit status 1
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Anduril that's an error from the atsha driver. It is not adapted for "exotic" architectures. I recommend soft signing (or that you create a or with necessary adjustments that are backwards compatible with the Arduino boards currently in use).
                    • AndurilA
                      AndurilA
                      Anduril
                      @Anticimex I thought to be using only soft signing...
                      #include <sha204_library.h>
                      #include <sha204_lib_return_codes.h>
                      #define MY_CORE_ONLY
                      #if DOXYGEN
                      #define LOCK_CONFIGURATION
                      #define LOCK_DATA
                      #define SKIP_KEY_STORAGE
                      #define USER_KEY
                      #define SKIP_UART_CONFIRMATION
                      #define USE_SOFT_SIGNING
                      #define STORE_SOFT_KEY
                      #define STORE_SOFT_SERIAL
                      #define USER_SOFT_SERIAL
                      #define STORE_AES_KEY
                      #define USER_AES_KEY
                      //#define LOCK_CONFIGURATION
                      //#define LOCK_DATA
                      //#define SKIP_KEY_STORAGE
                      //#define USER_KEY
                      #ifdef USER_KEY
                      #ifdef USER_SOFT_KEY
                      I copied the header of the SecurityPersonalizer (just stripped the comments to make it shorter). Do I have activated atsh somewhere without noticing?
                      • AndurilA Anduril
                        #if DOXYGEN
                        #define LOCK_DATA
                        #define USER_KEY
                        //#define LOCK_DATA
                        //#define USER_KEY
                        #ifdef USER_KEY
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Anduril try ditching the SHA204 library includes at the top. Not sure if they are required for soft signing. Can't remember if I put them there for a reason.... Long time ago I coded for MySensors :(
                        AndurilA 1 Reply Last reply
                        • AnticimexA Anticimex
                          AndurilA
                          AndurilA
                          Anduril
                          @Anticimex Thank you. Deactivating those sha libs made the code compile and work.
                          • AndurilA Anduril
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @Anduril :thumbsup:
