  3. Wireing the Radio?
Wireing the Radio?
6 Posts 3 Posters 4.7k Views 2 Watching
  • cattooC
    cattooC
    cattoo
    Hi all,
    Well i need some help with the Wiring the NRF24L01+ Radio so i could use it as a Gateway.
    I have the a Arduino Nano V3 (clone) and from what ill could see on the wiring scheme thats on the build section its not the same.
    Could some nice person help me to get started with it :smiley:
    • sundberg84S
      Hi @cattoo and welcome!
      If you follow http://www.mysensors.org/build/connect_radio it should be ok.
      9-13 on that site is yours D9-D13
      GND = GND
      VCC = 3V3
      Good luck.
      • abuvlbA
        abuvlbA
        abuvlb
        Arduino Nano to NRF24L01+ Wiring
        (image0_1460170414252_cablage_nano_radio.png url)
        • cattooC
          cattooC
          cattoo
          So ill finally got all the "gear" and my first one is up. But ill need to know how to wire a battary and which things to remove for powersaving.
          Thanks to those who replyed earlier :)
          • sundberg84S
            @cattoo - I would use a 3.3v pro mini in that case and not a nano.
            Also start by reading this: https://forum.mysensors.org/topic/486/my-2aa-battery-sensor which i think is a good way to start.
            There is more advances things to do, but removing led and voltage regulator will get you far.
            • cattooC
              cattooC
              cattoo
              Ok, then ill just start to read.
