  3. MyNodes.NET
  4. Moving Nodes to Different Panel
Scheduled Pinned Locked Moved MyNodes.NET
4 Posts 2 Posters 1.7k Views 2 Watching
  • D
    D
    d-smes
    I've just started playing with MyNodes and so far, it is REALLY GREAT! Thanks for all your hard work.
    Newbie question: All the MySensor nodes are created in the Main Panel. How do I move them to a different panel?
    The Dashboard gets really busy with just a single column of UI readings. Obviously this problem is solved if one splits up the Main Panel into multiple sub panels; ideally one panel per MySensor node. I know how to created a new panel, but there is no way to import the main panel. And in the Main Panel, I haven't found a way to export itself so I can import the MySensor nodes in the new sub panel.
    • derwishD
      derwishD
      derwish
      Hi. Thank you for the positive feedback.
      Move nodes from the main panel to another - one of the functions in my task list for the future. Now I can only advise to make all the nodes in the new sub-panels.
      D 1 Reply Last reply
      • derwishD derwish
        D
        D
        d-smes
        I tried that- I had a new sub-panel open and then went to the Main Panel and deleted the nodes. Unfortunately, the MySensor nodes were re-created in the Main Panel instead of the sub-panel. Is there a setting I missed that directs where they are created?
        derwishD 1 Reply Last reply
        • D d-smes
          derwishD
          derwishD
          derwish
          MySensor nodes are always generated in the main panel. I mean, I want to do that other existing nodes can be moved from the main panel to the sub-panels. I didn't think about MySensor nodes. Maybe I'll do so you can move them, too. But at the moment it is not possible.
