  3. Mi-Light controller for Mysensors
69 Posts 15 Posters 52.1k Views 27 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Ok, I tried with several bulbs now. First time I managed to pair as on/off switch but after that I had no luck. If anyone is using this with domoticz please describe the procedure of how to add the bulbs.
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      @ted
      I forgot to ask, but what controller have you been trying them out on? And are there any limitation to how many bulbs one repeater-node can control? I recall reading something about one original controller only being able to control 4 bulbs or similar.
      T 1 Reply Last reply
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Ok, I think I found a clue :), S_CUSTOM seams not to be supported by domoticz so I changed it to "gw.present(0, S_RGBW_LIGHT);"
        So now everything looks ok with a RGB selector and everything. But I still can only turn on and off the bulb and am not able to dim or set colors. So I guess there is some more serious witchcraft going on thats over my head.
          @ted
          ted
          wrote on last edited by ted
          #24
          @Cliff-Karlsson
          The milight uses a speical command, it is not likely to be compatible with the standard RGB light module in domoticz. The information about the milight protocol can be found here: https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
          I used openhab to assemble the command string for S_CUSTOM. Using the S_CUSTOM, you can control as many bulb as you want (by using different remote ID field in the milight protocol), although I only have 1 bulb. The node receives the milight protocol in plain ASCII string and convert the string to HEX before sending it out to the bulb. Hope this helps.
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            Ok, thanks for the help but it seams that I will have to use the standard-wifi bridges for now until someone smarter than me fixes the domoticz support.
            • Łukasz KostrzewaŁ
              Łukasz KostrzewaŁ
              Łukasz Kostrzewa
              Thank You for this solutin. Everythin works great but...
              I was able to pair with one bulb but I I do not know what to do to pair with others?
              Any idea?
              Best regard
              • Łukasz KostrzewaŁ Łukasz Kostrzewa
                Any idea?
                Best regard
                ted
                @Łukasz-Kostrzewa
                Each bulb is associated with a particular 'remote ID'. Bulbs having the same remote ID will repond to all commands having the same remote ID. Therefore, you can simply pick a different(or the same) remote ID to pair with a second bulb, and the second bulb can be controlled separately(or simultaneously) with the first one. I have not tried it but that should work according to the mi-bulb protocol.
                • Łukasz KostrzewaŁ
                  Łukasz KostrzewaŁ
                  Łukasz Kostrzewa
                  Thax for reply
                  But I don't understand :(
                  I don't have Milight bridge and I paired one Milight bulb to Dummy switch I have in my Domoticz My sensors.
                  And this works great but there is only one dummy switch.
                  When I add to arduino code one more (gw.present(0, S_LIGHT);) in Domoticz there is another Dummy switch but it controls the same lights then the first one. I don't know how to add (I don;t know it is possible) a second dummy to control another bulb without milight bridge.
                  • Łukasz KostrzewaŁ
                    Łukasz KostrzewaŁ
                    Łukasz Kostrzewa
                    Hi Ted
                    I understand now:)
                    I changed remote id to diffrent values but now my first dummy switch paired to my first bulb doesn't work.
                    I need to have another arduino to control another bulb?
                    Best regards
                    • Łukasz KostrzewaŁ
                      Łukasz KostrzewaŁ
                      Łukasz Kostrzewa
                      Another question...
                      Is there possibility to add to this code another one to control DHT11 temp and humidity sensor (from my sensors library)
                      I wanted to have 2 thing in one:)
                      Best regards
                        Hi Ted
                        I understand now:)
                        Best regards
                        ted
                        @Łukasz-Kostrzewa
                        The way I'd suggest is to modify the program to add more switches, each switch uses a different remote ID. Alternatively, you can use your controller to generate the necessary command string (with custom ID specific to the bulbs you want to control) and send it to the custom node as an ASCII string. The custom node will relay whatever command it receives to the bulbs.
                        • Łukasz KostrzewaŁ
                          Łukasz KostrzewaŁ
                          Łukasz Kostrzewa
                          Thx for answer
                          I am noob in programming. Maybe You can post an example how to modify the code?
                          Best regards
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            Excellent project! I have implemented reversed engineering for (1) some switches (2) LightWaveRF sockets. I tried to implemented Mi-Light with Mysensors but I having spent some time I decided to just buy a WiFi hub ($7) as it is natively supported in Domoticz.
                            Mi-Light is an excellent product price wise compare to Philips Hue
                            • Łukasz KostrzewaŁ
                              Łukasz KostrzewaŁ
                              Łukasz Kostrzewa
                              Hi
                              Anyone have idea how to modify the code to pair domoticz to more than one bulb?
                              With actual code I am able to ON/OFF only one bulb :(
                              Any idea?
                              Best regards
                              • Łukasz KostrzewaŁ
                                Łukasz KostrzewaŁ
                                Łukasz Kostrzewa
                                Anybody?
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  I would also like this to work with domoticz but as I lack the skills nececary I am now waiting on the next RFlink firmware witch is adding the feature of controlling mi-lights.
                                  I still think that the node/repeater as descripbed in this topic would be better but as I have no options the RFlink is better than using the standard milight bridge an any way.
                                  I have added a NRF24L01 PA to my RFlink gateway and am hoping that the range will cover my whole house.
                                  • Łukasz KostrzewaŁ
                                    Łukasz KostrzewaŁ
                                    Łukasz Kostrzewa
                                    Thx for info
                                    Best regards
                                    • Łukasz KostrzewaŁ
                                      Łukasz KostrzewaŁ
                                      Łukasz Kostrzewa
                                      I have new problem.
                                      I paired wrong bulb and now I can't unpair it.
                                      How to do that?
                                      Best regards
                                      • Iraklis KourtisI
                                        Iraklis KourtisI
                                        Iraklis Kourtis
                                        Hi Ted,
                                        Your project looks really amazing and I think it is exactly what I was looking for.
                                        I want to change my lighting at home. I am thinking of adding 8 LED strips that will be controlled by 2 x 4 Mi-Light remote controls and 2 x wifi bridges. As I would like to still be able to use the wall switches to turn them on/off I was thinking of using your solution. Do you think it will be feasible with your project? Also is there a way to reduce the wifi bridges to 1 instead of having 2?
                                        Thank you for this great project!
                                        Iraklis
                                          I have new problem.
                                          How to do that?
                                          Best regards
                                          ted
                                          @Łukasz-Kostrzewa
                                          sorry for the delay. you need to send the unpair command right after turning on the light. see https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
