  3. RFID and NRF24L01 Wireless Network Coding Issues
23 Posts 8 Posters 12.3k Views 8 Watching
  • IspandyI Ispandy
    @evb yes i have 2 nodes (node 3 and node 50) all with MRFC522 right now, the node 3 is working perfectly but i dont like add and remove card system, I just want to change the part of the RFID sketch on node 3 using the sketch above, so i make one node for test (node 50) and put the code
    send(lockMsg.set(false));
    and
    send(lockMsg.set(true));
    to this
    void granted ( uint16_t setDelay) {
      digitalWrite(blueLed, LED_OFF);   // Turn off blue LED
      digitalWrite(redLed, LED_OFF);  // Turn off red LED
      digitalWrite(greenLed, LED_ON);   // Turn on green LED
      digitalWrite(relay, LOW);     // Unlock door!
      delay(setDelay);          // Hold door lock open for given seconds
      digitalWrite(relay, HIGH);    // Relock door
      delay(1000);            // Hold green LED on for a second
    and i add this to node 50
    if (message.type == V_LOCK_STATUS) {
        // Change relay state
        if (!message.getBool()) {
          granted(300);
        // Write some debug info
        Serial.print(F("Lock status: "));
        else
          Serial.print(F("Incoming msg type: "));
          Serial.print(message.type);
          Serial.print(F(" id: "));
          Serial.print(message.sensor);
          Serial.print(F(" content: "));
          Serial.println(message.getInt());
    nothing happen...
    sketch Node 3
    // Enable debug prints
    #define MY_NODE_ID 3
    #define MY_RADIO_RF24
    //#define MY_RF24_CHANNEL  10
    #include <MFRC522.h>
    #include <Bounce2.h>
    #define RF_INIT_DELAY   125
    #define ONE_SEC         1000
    #define MAX_CARDS       18
    #define PROG_WAIT       10
    #define HEARTBEAT       10
    #define BAUD            115200
    /*Pin definitions*/
    #define LED_PIN         4
    #define GARAGEPIN       2
    #define SWITCH_PIN      3
    #define RST_PIN   7   //  MFRC
    #define SS_PIN    8   //  MFRC
    MFRC522      mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
    MFRC522::Uid olduid;
    MFRC522::Uid masterkey = { 4,{ 0xEF,0xDB,0x8E,0x79 },0 };
    byte       countValidCards = 0;
    MFRC522::Uid validCards[MAX_CARDS];
    void       ShowCardData(MFRC522::Uid* uid);
    bool       sameUid(MFRC522::Uid* old, MFRC522::Uid* check);
    void       copyUid(MFRC522::Uid* src, MFRC522::Uid* dest);
    bool       isValidCard(MFRC522::Uid* uid);
    int        releasecnt = 0;
    //#define    CHILD_ID_ALARM    2
    #define    CHILD_ID_LOCK     1
    Bounce     debouncer = Bounce();
    int        oldSwitchValue = -1;
    int        switchValue = 0;
    long       timer = -1;
    bool       programmode = false;
    bool       ledon;
    int        programTimer = 0;
    bool       armed = true;
    unsigned long lastTime = 0;
    MyMessage  lockMsg(CHILD_ID_LOCK, V_LOCK_STATUS);
    //MyMessage  lockArmMsg(CHILD_ID_ALARM, V_ARMED);
    //MyMessage  wrongMsg(CHILD_ID_ALARM, V_TRIPPED);
    void before() {
      // Make sure MFRC is disabled from the SPI bus
      pinMode(RST_PIN, OUTPUT);
      digitalWrite(RST_PIN, LOW);
      pinMode(SS_PIN, OUTPUT);
      digitalWrite(SS_PIN, LOW);
    void presentation() {
      sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
      present(CHILD_ID_LOCK, S_LOCK);      delay(RF_INIT_DELAY);
      //present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);
      Serial.begin(BAUD);   // Initialize serial communications with the PC
      pinMode(GARAGEPIN, OUTPUT);     // Initialise in/output ports
                      // Make sure MFRC will be disabled on the SPI bus
      /*pinMode(RST_PIN, OUTPUT);
      digitalWrite(SS_PIN, LOW);*/
      pinMode(LED_PIN, OUTPUT);
      digitalWrite(LED_PIN, LOW);
      // Setup the button
      pinMode(SWITCH_PIN, INPUT);
      // Activate internal pull-up
      digitalWrite(SWITCH_PIN, HIGH);
      debouncer.attach(SWITCH_PIN);
      debouncer.interval(5);
      // Init mysensors library
      /*sendSketchInfo("RFID Garage", "1.1"); delay(RF_INIT_DELAY);
      present(CHILD_ID_ALARM, S_MOTION);   delay(RF_INIT_DELAY);*/
      recallEeprom();
      // Init MFRC RFID sensor
      SPI.begin();      // Init SPI bus
      mfrc522.PCD_Init();   // Init MFRC522
      ShowReaderDetails();          // Show details of PCD - MFRC522 Card Reader details
      //send(lockArmMsg.set(armed));
      Serial.println(F("Init done..."));
      timer++;
      delay(HEARTBEAT);
      debouncer.update();
      // Get the update value
      int switchValue = debouncer.read();
      if (switchValue != oldSwitchValue) {
        // Send in the new value
        Serial.print(F("Switch "));
        Serial.println(switchValue);
        if (switchValue && programmode) {
          lastTime = millis() / 1000;
        if (!switchValue && programmode && lastTime > 0) {
          if ((millis() / 1000) - lastTime > 3) {
            Serial.println(F("Reset all cards"));
            blinkFast(50);
          else {
            Serial.println(F("Program off"));
            storeEeprom();
        if (!switchValue) {
          programTimer = 0;
        oldSwitchValue = switchValue;
      if (programmode && ((timer % (ONE_SEC / HEARTBEAT)) == 0)) {
        ledon = !ledon;
        digitalWrite(LED_PIN, ledon);
        programTimer++;
        // Stop program mode after 20 sec inactivity
        if (programTimer > PROG_WAIT) {
          digitalWrite(LED_PIN, false);
          Serial.println(F("Program expired"));
      if ((timer % (200 / HEARTBEAT)) == 0) {
        // Look for new cards
        if (!mfrc522.PICC_IsNewCardPresent()) {
          if (releasecnt > 0) {
            releasecnt--;
            if (!releasecnt) {
              olduid.size = 0;
              Serial.println(F("release"));
          return;
        releasecnt = 5;
        // Select one of the cards
        if (!mfrc522.PICC_ReadCardSerial()) {
          return;
        // Dump debug info about the card; PICC_HaltA() is automatically called
        //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
        if (!olduid.size || !sameUid(&(mfrc522.uid), &olduid)) {
          ShowCardData(&(mfrc522.uid));
          copyUid(&(mfrc522.uid), &olduid);
          if (isValidCard(&olduid)) {
            OpenDoor(false);
          else {
            if (sameUid(&(mfrc522.uid), &masterkey)) {
              // Only switch in program mode when mastercard is found AND the program button is pressed
              if (switchValue) {
                Serial.println(F("Program mode"));
                programmode = true;
                programTimer = 0;
                lastTime = 0;
            else {
              if (programmode) {
                Serial.println(F("new card"));
                programTimer = 0;
                if (countValidCards < MAX_CARDS)
                  // Add card to list...
                  copyUid(&(mfrc522.uid), &validCards[countValidCards]);
                  countValidCards++;
                  blinkFast(15);
              else {
                Serial.println(F("Invalid card"));
                //if (armed) {
                 // send(wrongMsg.set(1));
                 // delay(2000);
                  //send(wrongMsg.set(0));
    void ShowCardData(MFRC522::Uid* uid) {
      Serial.print(F("Card UID:"));
      for (byte i = 0; i < uid->size; i++) {
        if (uid->uidByte[i] < 0x10) {
          Serial.print(F(" 0"));
        else {
          Serial.print(F(" "));
        Serial.print(uid->uidByte[i], HEX);
      Serial.println();
      dest->size = src->size;
      dest->sak = src->sak;
      for (byte i = 0; i < src->size; i++) {
        dest->uidByte[i] = src->uidByte[i];
      if (old->size != check->size) {
        return false;
      for (byte i = 0; i < old->size; i++) {
        if (old->uidByte[i] != check->uidByte[i]) {
          return false;
      return true;
      for (byte i = 0; i < countValidCards; i++) {
        if (validCards[i].size != uid->size) {
          break;
        for (int j = 0; j < uid->size; j++) {
          if (validCards[i].uidByte[j] != uid->uidByte[j]) {
            break;
          if (j == (uid->size - 1)) {
            return true;
      return false;
    void storeEeprom()
      byte address = 0;
      saveState(address++, countValidCards);
        saveState(address++, validCards[i].size);
        for (byte j = 0; j < 10; j++) {
          saveState(address++, validCards[i].uidByte[j]);
    void recallEeprom()
      byte address = 0;
      countValidCards = loadState(address++);
      if (countValidCards > MAX_CARDS) {
        Serial.println(F("Not a valid EEPROM reading set to default"));
        storeEeprom();
        return;
        validCards[i].size = loadState(address++);
          validCards[i].uidByte[j] = loadState(address++);
    void blinkFast(int times)
      for (int i = 0; i < times; i++) {
        ledon = !ledon;
        delay(100);
    void OpenDoor(bool fakeOpen)
      Serial.println(F("Open door!"));
      if (!fakeOpen) {
        digitalWrite(LED_PIN, HIGH);
        digitalWrite(GARAGEPIN, HIGH);
      delay(1000);
      if (!fakeOpen) {
        digitalWrite(GARAGEPIN, LOW);
    void ShowReaderDetails() {
      // Get the MFRC522 software version
      byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
      Serial.print(F("MFRC522 Software Version: 0x"));
      Serial.print(v, HEX);
      if (v == 0x91) {
        Serial.print(F(" = v1.0"));
      else if (v == 0x92) {
        Serial.print(F(" = v2.0"));
      else {
        Serial.print(F(" (unknown)"));
      Serial.println("");
      // When 0x00 or 0xFF is returned, communication probably failed
      if ((v == 0x00) || (v == 0xFF)) {
        Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
          OpenDoor(false);
      /*else
        if (message.type == V_ARMED) {
          armed = message.getBool();
          Serial.print(F("Arm status: "));
        else
    I'm not good at programming that's why I'm asking for help:expressionless: :expressionless:
    E
    E
    evb
    @Ispandy what happens if you download the same sketch from the working node 3 tot your new node 50?
    Adapt of course the node-id!
    If it works we can exclude a hardware problem, then it must be a software problem.
    In that last case, we can check your sketch more deeply.
    IspandyI 1 Reply Last reply
    • E evb
      IspandyI
      IspandyI
      Ispandy
      @evb thank you for the response, and sorry for late reply.
      As I mentioned above, that node 3 is running as it should, and I've copied it to node 50 and it's also running normally. The problem is on sketch node 50 when i click the switch in openhab the relay doesn't respond but when i scan the card on rfid, the relay responds. Unlike node 3, the relay responds to both card scans and openhab.
      Regards,
      E 1 Reply Last reply
      • IspandyI Ispandy
        Regards,
        E
        E
        evb
        @Ispandy, let resume some things because I'm lost
        You copied the sketch code from node 3 (= correctly running node with cardscans and remote control from openhab) to node 50 and you adapted the node id.
        This same sketch on node 50 is running correctly with cardscans but not with openhab? Correct?
        If above is correct: somewhere your openhab configuration for this node 50 is not correct. You say that node 50 is never receiving the openhab command, so there is a problem with your openhab configuration for node 50.
