  3. Can it be done? (Countdown timer that survives wait or sleep)
21 Posts 6 Posters 7.6k Views 4 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    wrote on last edited by Mark Swift
    #21
    @TheoL With regards the LED's, I slightly changed the logic so they count down, rather than up, i.e. they extinguish as each hour passes until the 4th hour.
    I don't see an issue with the current rain sensor / moisture sensor logic, I'm ensuring a reading is taken, but not seeing it unless they've changed? The number you see there now is only because I was testing, normally they're either
    lastMoistureValue = moistureValue OR lastRainValue = rainValue
    The main issue I see is that I need to countdown to be in sync with
    if (lastMoistureValue == 0 || lastRainValue == 0)
    so if (lastMoistureValue == 0 || lastRainValue == 0) is true on each loop, then the countdown LED's are reset also.
    I'll no doubt change the loop wait to much longer once deployed.
