  3. problem in SoilMoistSensor
14 Posts 3 Posters 4.1k Views 1 Watching
  • R Offline
    R Offline
    Reza
    hi
    i have problem in SoilMoistSensor too
    with out water value is -8 -9 % ...
    with water this is -30 -40 +20% . . . :|
    • mfalkviddM Online
      mfalkviddM Online
      (thread moved to Troubleshooting from My Project)
      Description of My Project: Show off and share your great projects here! We love pictures!
      Description of Troubleshooting: Help! Everything just falls apart
      The above post seems to fit the description for Troubleshooting much better.
      R 1 Reply Last reply
        R Offline
        R Offline
        Reza
        @mfalkvidd ok
        • mfalkviddM Online
          mfalkviddM Online
          I haven't used the SoilMoistSensor sketch, but the comments at the top of the file says that it reports level, not percent, and that the levels you are describing are reasonable.
          What numbers are you expecting?
            R Offline
            R Offline
            Reza
            @mfalkvidd
            this is not true !
            in my app (imperihome) is -1% now !!! and after sense is -8 or -28 or +20 and . . .
            B 1 Reply Last reply
            • R Reza
              @mfalkvidd
              this is not true !
              B Offline
              B Offline
              BulldogLowell
              @Reza
              why not post the sketch you are using?
              • B BulldogLowell
                @Reza
                R Offline
                R Offline
                Reza
                @BulldogLowell hi
                I use same code in mysesors.org without any changes
                #include <math.h> // Conversion equation from resistance to %
                // Setting up format for reading 3 soil sensors
                #define NUM_READS 10 // Number of sensor reads for filtering
                #define CHILD_ID 0
                MySensor gw; // Arduino initialization
                MyMessage msg(CHILD_ID, V_LEVEL);
                long buffer[NUM_READS];
                int index;
                typedef struct { // Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
                int moisture;
                long resistance;
                } values;
                const long knownResistor = 4700; // Constant value of known resistor in Ohms
                int supplyVoltage; // Measured supply voltage
                int sensorVoltage; // Measured sensor voltage
                values valueOf[NUM_READS]; // Calculated moisture percentages and resistances to be sorted and filtered
                int i; // Simple index variable
                // initialize serial communications at 9600 bps:
                Serial.begin(115200);
                gw.begin();
                gw.sendSketchInfo("Soil Moisture Sensor Reverse Polarity", "1.0");
                gw.present(CHILD_ID, S_HUM);
                // initialize the digital pins as an output.
                // Pin 6,7 is for sensor 1
                // initialize the digital pin as an output.
                // Pin 6 is sense resistor voltage supply 1
                pinMode(6, OUTPUT);
                // Pin 7 is sense resistor voltage supply 2
                pinMode(7, OUTPUT);
                measure(6,7,1);
                Serial.print ("\t");
                Serial.println (average());
                long read1 = average();
                measure(7,6,0);
                long read2= average();
                long sensor1 = (read1 + read2)/2;
                Serial.print ("resistance bias =" );
                Serial.println (read1-read2);
                Serial.print ("sensor bias compensated value = ");
                Serial.println (sensor1);
                Serial.println ();
                //send back the values
                gw.send(msg.set((long int)ceil(sensor1)));
                // delay until next measurement (msec)
                gw.sleep(SLEEP_TIME);
                void measure (int phase_b, int phase_a, int analog_input)
                // read sensor, filter, and calculate resistance value
                // Noise filter: median filter
                for (i=0; i<NUM_READS; i++) {
                // Read 1 pair of voltage values
                digitalWrite(phase_a, HIGH);                 // set the voltage supply on
                delayMicroseconds(25);
                supplyVoltage = analogRead(analog_input);   // read the supply voltage
                digitalWrite(phase_a, LOW);                  // set the voltage supply off
                delay(1);
                digitalWrite(phase_b, HIGH);                 // set the voltage supply on
                sensorVoltage = analogRead(analog_input);   // read the sensor voltage
                digitalWrite(phase_b, LOW);                  // set the voltage supply off
                // Calculate resistance
                // the 0.5 add-term is used to round to the nearest integer
                // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
                long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage) ;
                delay(1);
                addReading(resistance);
                Serial.print (resistance);
                // Averaging algorithm
                void addReading(long resistance){
                buffer[index] = resistance;
                index++;
                if (index >= NUM_READS) index = 0;
                long average(){
                long sum = 0;
                for (int i = 0; i < NUM_READS; i++){
                sum += buffer[i];
                return (long)(sum / NUM_READS);
                • R Reza
                  @BulldogLowell hi
                  #define CHILD_ID 0
                  int index;
                  int moisture;
                  long resistance;
                  } values;
                  gw.begin();
                  pinMode(6, OUTPUT);
                  pinMode(7, OUTPUT);
                  measure(6,7,1);
                  measure(7,6,0);
                  Serial.println ();
                  delay(1);
                  delay(1);
                  index++;
                  long average(){
                  long sum = 0;
                  sum += buffer[i];
                  B Offline
                  B Offline
                  BulldogLowell
                  wrote on last edited by BulldogLowell
                  @Reza
                  Well, I really don't like a few things in that sketch, like the struct that is never used, for example.
                  or using a global variable as an array index:
                  or superfluous nonsense comments:
                  The other thing is that the "average" function may be using junk until you take 10 readings, and that takes 5 minutes to clear out:
                  try this instead which will initialize the array to zeroes:
                  long buffer[NUM_READS] = {0};
                  also, we ought to modify the addReading() and average() functions to size itself for the first 9 readings....
                  There may be other datatype issues, but let's start here.
                  • B BulldogLowell
                    @Reza
                    R Offline
                    R Offline
                    Reza
                    my friend i am weak in coding, I just use this device for my home . so please Correction the code and send to me . please
                    thank you <3
                    • R Reza
                      thank you <3
                      B Offline
                      B Offline
                      BulldogLowell
                      @Reza
                      well, I have no way of testing :(
                      but I would do like this:
                      #include "CircularBuffer.h"
                      #define CHILD_ID 0
                      CircularBuffer forward(NUM_READS);
                      CircularBuffer reverse(NUM_READS);
                        Serial.begin(9600);
                        gw.begin();
                        pinMode(6, OUTPUT);
                        pinMode(7, OUTPUT);
                        forward.addElement(measure(6, 7, 1));
                        reverse.addElement(measure(7, 6, 0));
                        Serial.print ("forward average:");
                        Serial.println (forward.mean());
                        Serial.print ("reverse average:");
                        Serial.println (reverse.mean());
                        float sensor1 = long((forward.mean() + reverse.mean()) / 2.0);
                        Serial.println (forward.mean() - reverse.mean());
                        Serial.println ();
                      long int measure (int phase_b, int phase_a, int analog_input)
                          long int supplyVoltage = analogRead(analog_input);   // read the supply voltage
                          delay(1);
                          long int sensorVoltage = analogRead(analog_input);   // read the sensor voltage
                          delay(1);
                          return long((knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage));
                      1: Start wiht a new sketch
                      2: add two tabs to the sketch like this:
                      3: paste these library files into the two tabs:
                      CircularBuffer.h
                      #ifndef CircularBuffer_h
                      #define CircularBuffer_h
                      #include <Arduino.h>
                      class CircularBuffer {
                        public:
                          CircularBuffer(size_t size);
                          void addElement(float newElement);
                          float mean();
                          float maxVal();
                          float minVal();
                          float sigma();
                          size_t numElements();
                          float arrayElement(int location);
                        private:
                          float* array;
                          float* next;
                          size_t size;
                          int index = 0;
                          int num_elements = 0;
                      CircularBuffer.cpp
                      CircularBuffer::CircularBuffer(size_t arraySize)
                        size = arraySize;
                        array = new float[arraySize];
                        next = &array[0];
                      void CircularBuffer::addElement(float newElement)
                        *next = newElement;
                        index++;
                        if (index >= size)
                          index = 0;
                        next = &array[index];
                        if (++num_elements > size)
                          num_elements = size;
                      float CircularBuffer::arrayElement(int location)
                        return array[location];
                      float CircularBuffer::mean()
                        float average = 0;
                        for (int i = 0; i < num_elements; i++)
                          average += array[i];
                        return average / num_elements;
                      size_t CircularBuffer::numElements()
                        return num_elements;
                      float CircularBuffer::maxVal()
                        float maximum;
                          if (i == 0)
                            maximum = array[0];
                          else if (array[i] > maximum)
                            maximum =  array[i];
                        return maximum;
                      float CircularBuffer::minVal()
                        float minimum;
                          if (i == 0)
                            minimum = array[0];
                          else if (array[i] < minimum)
                            minimum =  array[i];
                        return minimum;
                      float CircularBuffer::sigma()
                        float average = mean();
                        float sigma = 0;
                        for(int i = 0; i < min(size, num_elements) ; i++)
                          sigma += ((array[i] - average) * (array[i] - average));
                        return sqrt(sigma / min(size, num_elements));
                      • B BulldogLowell
                        @Reza
                        #define CHILD_ID 0
                          Serial.begin(9600);
                          gw.begin();
                          pinMode(6, OUTPUT);
                          pinMode(7, OUTPUT);
                          Serial.println ();
                            delay(1);
                            delay(1);
                        CircularBuffer.h
                          public:
                            float mean();
                            float maxVal();
                            float minVal();
                            float sigma();
                          private:
                            float* array;
                            float* next;
                            size_t size;
                            int index = 0;
                        CircularBuffer.cpp
                          size = arraySize;
                          next = &array[0];
                          *next = newElement;
                          index++;
                          if (index >= size)
                            index = 0;
                          float average = 0;
                          float maximum;
                            if (i == 0)
                              maximum = array[0];
                              maximum =  array[i];
                          return maximum;
                          float minimum;
                            if (i == 0)
                              minimum = array[0];
                              minimum =  array[i];
                          return minimum;
                          float sigma = 0;
                        R Offline
                        R Offline
                        Reza
                        wrote on last edited by Reza
                        size = arraySize;
                        next = &array[0];
                        *next = newElement;
                        index++;
                        if (index >= size)
                        index = 0;
                        float average = 0;
                        float maximum;
                        if (i == 0)
                        maximum = array[0];
                        maximum = array[i];
                        return maximum;
                        float minimum;
                        if (i == 0)
                        minimum = array[0];
                        minimum = array[i];
                        return minimum;
                        float sigma = 0;
                        this is not true .i test with full water and few water and no water but Numbers in disarray for example first secend is -8% and next 2% and next -16% and next 24% and next -7% . . .
                        • R Reza
                          size = arraySize;
                          next = &array[0];
                          *next = newElement;
                          index++;
                          if (index >= size)
                          index = 0;
                          float average = 0;
                          float maximum;
                          if (i == 0)
                          maximum = array[0];
                          maximum = array[i];
                          return maximum;
                          float minimum;
                          if (i == 0)
                          minimum = array[0];
                          minimum = array[i];
                          return minimum;
                          float sigma = 0;
                          B Offline
                          B Offline
                          BulldogLowell
                          I don't know what "this is not true" is meant to say...
                          As I mentioned, I cannot test. Perhaps you could show the Serial output using this modification of the sketch, changing the sleep in loop() to this:
                          delay(1000);
                          • B BulldogLowell
                            delay(1000);
                            R Offline
                            R Offline
                            Reza
                            @BulldogLowell
                            amount of humidity should be between 0 and 100% . is it true ? but my sensor showed me the different numbers.for example -8% -30% and....
                            • R Reza
                              @BulldogLowell
                              B Offline
                              B Offline
                              BulldogLowell
                              @Reza
                              you should show the output of the Serial Monitor.
                              There may be a variable overflowing...
