  3. Dimmer issues.
Dimmer issues.
3 Posts 2 Posters 1.1k Views 2 Watching
  • C
    C
    chickey
    Hi guys, i'm trying to put together a dimmer circuit as well as a temp/voltage sensing and motion as well. I've got it all hooked up bar the motion side of things and the temp works great, voltage is sort of ok although not that accurate but can live with it but the dimmer side of things doesn't work great. I have used a STP16NF06L rather than the IRLZ44N but i thought this should be ok since i've used this in a ESP8266 dimmer project along with mysensors and Domoticz and it works great.
    What is happening is it's not actually dimming, if i put it above %50 it turns on but then it's a constant brightness and doesn't get brighter or dim going the other way. Is it just down to the mosfet substitution? I've tried with the standard sketch and it does this. My modified code is below. Any help would be much appreciated.
     * Version 1.0 - February 15, 2014 - Bruce Lacey
     * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
     * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
     * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
     * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
     * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
     * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
     * to the LED negative terminal and the MOSFET Source pin is connected to ground.
     * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
     * http://www.mysensors.org/build/dimmer
    #define SN "DimmableLED"
    #define SV "1.1"
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_VOLTAGE 2
    #include <DHT.h>
    #define LED_PIN 4      // Arduino pin attached to MOSFET Gate pin
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    DHT dht;
    float lastTemp;
    boolean metric = true;
    float lastHum;
    float lastVolt;
    int oldBatteryPcnt = 0;
    int analogInput = A0;
    float vout = 0.0;
    float vin = 0.0;
    int value = 0;
    float R1 = 30000.0;
    float R2 = 7500.0;
    static int currentLevel = 0;  // Current dim level...
    MyMessage dimmerMsg(0, V_DIMMER);
    MyMessage lightMsg(0, V_LIGHT);
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
     * Dimmable LED initialization method
      Serial.println( SN );
      gw.begin( incomingMessage );
      gw.present( 0, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( 0, V_DIMMER );
      gw.present(CHILD_ID_VOLTAGE, V_VOLTAGE);
      pinMode(analogInput, INPUT);
     *  Dimmable LED main processing loop
      gw.process();
      readTempHum();
      measureBattery();
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
        // Clip incoming level to valid range of 0 to 100
        Serial.print( "Changing level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel );
        fadeToLevel( requestedLevel );
        gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
        // hek comment: Is this really nessesary?
        gw.send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel ) {
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
    void readTempHum() {
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    void measureBattery() {
       // read the value at analog input
       value = analogRead(analogInput);
       vout = (value * 5.0) / 1024.0; // see text
       vin = vout / (R2/(R1+R2));
       int batteryPcnt = value / 10;
       #ifdef DEBUG
       Serial.print(vin);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         gw.send(msgVolt.set(vin, 1));
         oldBatteryPcnt = batteryPcnt;
    • C
      C
      chickey
      Rude to reply to your own posts or so i'm told but for the benefit of others i was being an idiot and pin 4 isn't pwm (facepalm) i was looking at this for a while last night as well. Ah well never mind it's working brilliantly now after switching to pin 5 :-)
        Great! Thanks for telling us the solution.
