  3. Change default pin
Change default pin
2 Posts 2 Posters 2.8k Views 2 Watching
  • niekN
    niekN
    niek
    wrote on last edited by niek
    I'm new with mySensors and I'm using them with Domoticz.
    I have running an DHT-22 sensor and that is working fine.
    I'm now building a light + pressure sensor because I think that those sensors are perfect to combine. But, by default the BH1750 and MBP085 are using the same pins on the Arduino.
    Is there a way to override the default pin?
    My current code (it's says:Could not find a valid BMP085 sensor, check wiring!)
    * Version 1.0 - idefix
    * Arduino BH1750FVI Light sensor
    * communicate using I2C Protocol
    * this library enable 2 slave device addresses
    * Main address  0x23
    * secondary address 0x5C
    * connect the sensor as follows :
    *   VCC  >>> 5V
    *   Gnd  >>> Gnd
    *   ADDR >>> NC or GND
    *   SCL  >>> A5
    *   SDA  >>> A4
    * http://www.mysensors.org/build/light
    #include <BH1750.h>
    #include <Wire.h>
    #include <Adafruit_BMP085.h>
    #define CHILD_ID_LIGHT 0
    #define CHILD_ID_BARO 1
    const float ALTITUDE = 4;
    BH1750 lightSensor;
    // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
    // If your controller supports the new V_LEVEL variable, use this instead for
    // transmitting LUX light level.
    // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
    uint16_t lastlux;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
     STABLE = 0,     // "Stable Weather Pattern"
     SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
     CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
     UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
     THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
     UNKNOWN = 5     // "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    float lastPressure = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage pressureMsg(CHILD_ID_BARO, V_PRESSURE);
    MyMessage forecastMsg(CHILD_ID_BARO, V_FORECAST);
     gw.begin();
     gw.sendSketchInfo("Light + Pressure", "1.0");
     if (!bmp.begin())
       Serial.println("Could not find a valid BMP085 sensor, check wiring!");
       while (1) {}
     gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
     gw.present(CHILD_ID_BARO, S_BARO);
     lightSensor.begin();
     uint16_t lux = lightSensor.readLightLevel();// Get Lux value
     Serial.println(lux);
     if (lux != lastlux) {
         gw.send(msg.set(lux));
         lastlux = lux;
     float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
     int forecast = sample(pressure);
     Serial.print("Pressure = ");
     Serial.print(pressure);
     Serial.println(" hPa");
     Serial.print("Forecast = ");
     Serial.println(weather[forecast]);
     if (pressure != lastPressure)
       gw.send(pressureMsg.set(pressure, 0));
       lastPressure = pressure;
     if (forecast != lastForecast)
       gw.send(forecastMsg.set(weather[forecast]));
       lastForecast = forecast;
     gw.sleep(SLEEP_TIME);
    float getLastPressureSamplesAverage()
     float lastPressureSamplesAverage = 0;
     for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
       lastPressureSamplesAverage += lastPressureSamples[i];
     lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
     return lastPressureSamplesAverage;
    // Algorithm found here
    // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
     // Calculate the average of the last n minutes.
     int index = minuteCount % LAST_SAMPLES_COUNT;
     lastPressureSamples[index] = pressure;
     minuteCount++;
     if (minuteCount > 185)
       minuteCount = 6;
     if (minuteCount == 5)
       pressureAvg = getLastPressureSamplesAverage();
     else if (minuteCount == 35)
       float lastPressureAvg = getLastPressureSamplesAverage();
       float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
       if (firstRound) // first time initial 3 hour
         dP_dt = change * 2; // note this is for t = 0.5hour
       else
         dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
     else if (minuteCount == 65)
       if (firstRound) //first time initial 3 hour
         dP_dt = change; //note this is for t = 1 hour
       else
         dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
     else if (minuteCount == 95)
         dP_dt = change / 1.5; // note this is for t = 1.5 hour
       else
         dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
     else if (minuteCount == 125)
       pressureAvg2 = lastPressureAvg; // store for later use.
         dP_dt = change / 2; // note this is for t = 2 hour
       else
         dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
     else if (minuteCount == 155)
         dP_dt = change / 2.5; // note this is for t = 2.5 hour
       else
         dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
     else if (minuteCount == 185)
         dP_dt = change / 3; // note this is for t = 3 hour
       else
         dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
       pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
       firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
     int forecast = UNKNOWN;
     if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
       forecast = UNKNOWN;
     else if (dP_dt < (-0.25))
       forecast = THUNDERSTORM;
     else if (dP_dt > 0.25)
       forecast = UNSTABLE;
     else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
       forecast = CLOUDY;
     else if ((dP_dt > 0.05) && (dP_dt < 0.25))
       forecast = SUNNY;
     else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
       forecast = STABLE;
     else
       forecast = UNKNOWN;
     // uncomment when debugging
     //Serial.print(F("Forecast at minute "));
     //Serial.print(minuteCount);
     //Serial.print(F(" dP/dt = "));
     //Serial.print(dP_dt);
     //Serial.print(F("kPa/h --> "));
     //Serial.println(weather[forecast]);
     return forecast;
    Edit: I'm not using the temperature function and combined both sketches from this site.
    • niekN niek
      * Main address  0x23
      *   VCC  >>> 5V
      *   Gnd  >>> Gnd
      *   SCL  >>> A5
      *   SDA  >>> A4
      #include <BH1750.h>
      #include <Wire.h>
      BH1750 lightSensor;
      uint16_t lastlux;
      enum FORECAST
      float pressureAvg;
      float pressureAvg2;
      float dP_dt;
      boolean metric;
       gw.begin();
       if (!bmp.begin())
         while (1) {}
           lastlux = lux;
       minuteCount++;
         minuteCount = 6;
         else
         else
         else
         else
         else
         else
         forecast = UNKNOWN;
         forecast = CLOUDY;
         forecast = SUNNY;
         forecast = STABLE;
       else
         forecast = UNKNOWN;
       return forecast;
      Yes and no. And maybe you don't have to :)
      Have you tried connecting both sensors to the same pins? That might work without you having to do anything. If that doesn't work, read on...
      The Adafruit BH1750 and BMP085 libraries do not support configuring which device on the i2c bus to "talk" to. There is an old pull request to add support, but it hasn't been added to the official code. You could download the fork.
      Both sensors communicate using i2c, and it is possible to connect multiple i2c devices to the same i2c bus.
      The two Adafruit libraries use the Wire library underneath. The Wire library handles i2c communication. So if you use the Wire library directly, you can connect both sensors to the same pins and follow the instructions here. Doing that will probably require some programming skills though, since you will need to do the stuff done by Adafruit's libraries manually.
      An alternative might be ut use Soft SPI to use a different set of pins, but I think that would require more work than using the Wire library.
