  3. Magnetic Door Switch with Buzzer
9 Posts 3 Posters 4.2k Views 3 Watching
  • knipexK
    knipexK
    knipex
    Hello everybody,
    I hope someone can help me.
    I have connected a magnetic door switch sensor and a buzzer with Arduino.
    Now I would like that when you open the door switch the buzzer starts until the door switch is closed again.
    I have combined the Door/Window/Button Sketch with my buzzer-Sketch, but unfortunately starts the buzzer when the Arduino starts and when the door switch is closed again.
    I want the buzzer only starts when opening the switches and so long until the switch is closed again and will stop again.
    Please help me, thank you in advance
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #include <Bounce2.h>
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    int buzzPin= 2; // I/O-pin from buzzer connects here
    const int wpm = 20; // Morse speed in WPM
    const int dotL = 1200/wpm; // Calculated dot-length
    const int dashL = 3*dotL; // Dash = 3 x dot
    const int sPause = dotL; // Symbol pause = 1 dot
    const int lPause = dashL; // Letter pause = 3 dots
    const int wPause = 7*dotL; // Word pause = 7 dots
    Bounce debouncer = Bounce();
    int oldValue=-1;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      pinMode(buzzPin,OUTPUT); // Set buzzer-pin as output
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN, HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
      dash();
      dot();
      dash();
      dot();
      delay(lPause-sPause); // Subtracts pause already taken
      dash();
      dash();
      dot();
      dash();
      delay(wPause-sPause); // Subtracts pause already taken
    void dot(){
    digitalWrite(buzzPin, LOW); // Tone ON
    delay(dotL); // Tone length
    digitalWrite(buzzPin, HIGH); // Tone OFF
    delay(sPause); // Symbol pause
    return;
    void dash(){
    delay(dashL); // Tone length
    return;
      I thnk it would be sufficient to add an if clause around the morse code stuff:
      if(value==HIGH){
        dash();
        dot();
        dash();
        dot();
        dash();
        dash();
        dot();
        dash();
      • knipexK
        knipexK
        knipex
        Many thanks for your response !
        It works. :)
        But how can I change the code so that the morse code is played until the switch is closed again, because at the moment the morse code is played only once, when the switch is opened.
        • knipexK
          knipexK
          knipex
          I have tried to solve this with INTERRUPT.
          But that does not work !
          #define INTERRUPT BUTTON_PIN-3
          and
          if (value==HIGH) {
            dash();
            dot();
            dash();
            dot();
            dash();
            dash();
            dot();
            dash();
            gw.sleep(INTERRUPT,BUTTON_PIN-3, CHANGE);
            Why use gw.sleep at all? You want to Arduino to stay awake so it can continue playing, right?
            Side note: Don't use BUTTON_PIN-3, use digitalPinToInterrupt(BUTTON_PIN). That makes the code easier to follow and avoids the risk of forgetting to update one definition but not the other.
            • knipexK
              knipexK
              knipex
              you are absolutely right.
              I changed the code as follows:
              with HIGH the morse signal is played only once, therefore changed to LOW !
                 // DigitalWrite (BUTTON_PIN, HIGH);
                 digitalWrite (BUTTON_PIN, LOW);
              if (value == HIGH) {
                 dash ();
                 dot ();
                 dash ();
                 dot ();
                 delay (lPause-sPause); // Subtracts break already taken
                 dash ();
                 dash ();
                 dot ();
                 dash ();
                 delay (wPause-sPause); // Subtracts break already taken
                 attachInterrupt (digitalPinToInterrupt (BUTTON_PIN), buzzer_stop, CHANGE);
              void buzzer_stop() {
              return;
              void dot(){
              return;
              void dash(){
              return;
              But now works with a small error :
              the buzzer makes mose signal in an endless loop, however it is very quiet even though it actually is very noisy ?!
              • knipexK
                knipexK
                knipex
                I found the mistake, now it's really loud :)
                Thank you so much.
                ChakkieC mfalkviddM 2 Replies Last reply
                • knipexK knipex
                  Thank you so much.
                  ChakkieC
                  ChakkieC
                  Chakkie
                  @knipex Hi can you please post your working script?? I want the same functionality too. Thanks
                  Raspberry Pi 2
                  Domoticz
                  RFXCOM
                  ZWAVE Aeon stick
                  Coming soon Arduino mysensors GW
                  • knipexK knipex
                    Thank you so much.
                    @knipex what was the mistake?
