  3. Can't create MySigningAtsha204Soft signer
8 Posts 3 Posters 1.6k Views 3 Watching
  • bogdanB Offline
    bogdanB Offline
    bogdan
    I'm trying to introduce signing to my projects, but can't create the MySigningAtsha204Soft object. What did I miss here:
    #include <DHT.h>
    #include <MySigningAtsha204Soft.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    MyTransportNRF24 radio; // NRFRF24L01 radio driver
    MyHwATMega328 hw; // Select AtMega328 hardware profile
    // Change the soft_serial value to an arbitrary value for proper security
    uint8_t soft_serial[SHA204_SERIAL_SZ] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09};
    MySigningAtsha204Soft signer(true, 0, NULL, soft_serial); // Select SW ATSHA signing backend
    MySensor gw(radio, hw, signer);
    Compiler returns error: no matching function for call to 'MySigningAtsha204Soft::MySigningAtsha204Soft(bool, int, NULL, uint8_t [9])'
    • mfalkviddM Offline
      Which version of the MySensors library are you using? Looks like the example for 1.5.x, but I think it has changed for the development version.
      Either use the example with MySensors 1.5.x or use the development version and follow the instructions embedded in the source files (they are available online somewhere I think but I don't know where).
      bogdanB 1 Reply Last reply
        bogdanB Offline
        bogdanB Offline
        bogdan
        @mfalkvidd I'm using 1.5.1 version of MySensors.
          Strange. The code looks fine to me. Maybe @Anticimex has a clue?
          • A Offline
            A Offline
            Anticimex
            You try to instantiate an object with arguments that indicate you want whitelisting. Are you sure you have set MY_SECURE_NODE_WHITELISTING? If you have not, you have an incorrect number of arguments.
            • A Offline
              A Offline
              Anticimex
              This is the constructor:
              MySigningAtsha204Soft(bool requestSignatures=true,
              #ifdef MY_SECURE_NODE_WHITELISTING
              		uint8_t nof_whitelist_entries=0, const whitelist_entry_t* the_whitelist=NULL,
              		const uint8_t* the_serial=NULL, //SHA204_SERIAL_SZ sized buffer expected if provided
              		uint8_t randomseedPin=MY_RANDOMSEED_PIN);
              • bogdanB Offline
                bogdanB Offline
                bogdan
                wrote on last edited by bogdan
                Thank you, I managed to compile the program, by enabling whitelisting.
                But I don't understand, since I copied the sketch above from [security] Introducing signing support to MySensors, from example without whitelisting.
                And how can I tell if everything works fine (messages are properly signed). I receive messages on the Gateway, in debuuging i see:
                send: 28-28-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:1
                send: 28-28-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
                send: 28-28-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                no sign
                sensor started, id=28, parent=0, distance=1
                send: 28-28-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:Humidity
                send: 28-28-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                send: 28-28-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                send: 28-28-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                send: 28-28-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.0
                T: 21.00
                send: 28-28-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:45.0
                H: 45.00
                send: 28-28-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:44.0
                H: 44.00
                H: 45.00
                A 1 Reply Last reply
                • bogdanB bogdan
                  no sign
                  T: 21.00
                  H: 45.00
                  H: 44.00
                  H: 45.00
                  A Offline
                  A Offline
                  Anticimex
                  @bogdan there are no signed messages in that log (sg=0). If you want signed messages, you need to tell your node to require signed messages. What settings have you enabled in your sketch in addition to enabling signing and whitelisting? Enabling signing just tells your sketch that it can sign messages, it does not mean that the node will require others to sign messages sent to it.
