  3. Moisture Sensor - Payload problem
7 Posts 2 Posters 2.9k Views 2 Watching
  • vgaV
    vgaV
    vga
    wrote on last edited by vga
    Hi everyone,
    i want to use a Moisture-Sensor (YL69+YL39) to report the humidity-level (0-1023) to my serial-Gateway.
    All set-up well.
    My Serial-Gateway works fine, the Sensor-Node works also and is connected to the Gateway.
    Now, my problem is that the Sensor-Node doesn´t send the level data correctly, i think.
    The Sensor-Node should send the following Level:
    Humidity Level (0-1023): 19
    In the Serial Monitor from my Sensor-Node i always get this output, when a msg will be send:
    req id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    And this is the Gateway Serial Monitor:
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    So to me, it looks like the msg has no content!?
    pl=0 and l=0 -> no data in the msg, doesn´t it?
    Here is my Sensor-Node Sketch:
    // MySensor Library hinzufügen
    #define CHILD_ID 0   // Id of the sensor child
    //Definieren welche Sensor-ID die nachricht schickt
    //und welcher Variablen-Typ übermittelt wird. (V_LEVEL ist in S_MOISTURE möglich)
    // Entsprechend der Sensor-Liste und Variablen-Liste
    MyMessage msg(CHILD_ID, V_LEVEL);
    int lastSoilValue = 0;
    // YL-39 + YL-69 humidity sensor
    byte humidity_sensor_pin = A1;
    byte humidity_sensor_vcc = 6;
      // Start Gateway Kommunikation
      gw.begin();
      gw.sendSketchInfo("Soil Moisture Sensor", "1.0");
      gw.present(CHILD_ID, S_MOISTURE);
      // Init the humidity sensor board
      pinMode(humidity_sensor_vcc, OUTPUT);
      digitalWrite(humidity_sensor_vcc, LOW);
      // Setup Serial
    //while (!Serial);
    //delay(1000);
    //Serial.begin(9600);
    int read_humidity_sensor() {
      digitalWrite(humidity_sensor_vcc, HIGH);
      delay(500);
      int value = analogRead(humidity_sensor_pin);
      return 1023 - value;
      int soilValue = read_humidity_sensor();
      Serial.print("Humidity Level (0-1023): ");
      Serial.println(soilValue);
      delay(2000);
      if (soilValue != lastSoilValue) {
        gw.send(msg.set(soilValue));
        lastSoilValue = soilValue;
    So, can someone help my, finding the problem, why my Level-Value will not be transmitted?
    Thanks for help!
    AWIA 1 Reply Last reply
    • vgaV vga
      Hi everyone,
      All set-up well.
      req id
      255;255;3;0;3;
        gw.begin();
        // Setup Serial
      //while (!Serial);
      //delay(1000);
        delay(500);
        delay(2000);
      Thanks for help!
      AWIA
      AWIA
      AWI
      @vga It looks like your sensor is requesting an ID from the controller. As long as the ID is not received no message with content will be sent. Which controller are using? You can use a fixed node to test.
      • vgaV
        vgaV
        vga
        i´m a totally beginner with MySensors, so sorry for my questions:
        I have a FHEM-Controller working.
        But haven´t connected the Controller to the Gateway yet.
        I thought i can test the Communication between the Gateway and the Sensor-Node, without connect the Gateway to my Controller. Isn´t that possible?
        What do you mean with "fixed node"?
        • vgaV vga
          AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          @vga To indentify the node in the network a "Node Id" is needed. When you don't assign one yourself the sensor will ask the controller to issue one. As you have no controller connected it will never be issued and the node will keep asking. By assigning the node id yourself you will be able to use it without a controller attached. I modified your sketch to use a fixed node id (don't use 0 or 255)
          MySensor gw ;
            gw.begin((NULL, 2);     // AWI: assign fixed node id 2  (use anything from 1..254);
            // Setup Serial
          //while (!Serial);
          //delay(1000);
            delay(500);
            delay(2000);
          • vgaV
            vgaV
            vga
            Thank you AWI,
            While compiling the modified sketch in Arduino App, i´m getting the following error:
            no matching function for call to 'MySensor::MySensor(NULL, int)'
            • vgaV vga
              Thank you AWI,
              AWIA
              AWIA
              AWI
              @vga oops, my mistake. I corrected the example :blush: (my excuse: I usually work in development branch). Let us know the results..
              • vgaV
                vgaV
                vga
                It is working! ;D ...thank you very much!
                Now i understand a little bit more with MySensors ;)
