  3. Home Assistant
  4. An HASS service to send messages to nodes
homeautomationhome assistanthome-assistant
22 Posts 4 Posters 8.3k Views 3 Watching
  • X xlcnd
    It works like a charm in version 0.22.1.
    For complex sequences of IR codes, I just send a 'fake' code and then the node selects the appropriate sequence.
    Thanks again!
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @xlcnd
    Thanks for the feedback and live testing!
    • X
      X
      xlcnd
      Let me complete the example given for the node when you use V_IR_SEND.
      In order to send IR codes you need to transform the
      code in an unsigned long:
          char ircode[11] = {0};  // in case your code takes the form of 0xE0E0FF0F
          if (message.type == V_IR_SEND) {
            String hexstring = message.getString();
            hexstring.toCharArray(ircode, sizeof(ircode));
            // get the code as an unsigned long
            unsigned long code = strtoul(ircode, NULL, 0);
            // with IRLib send the code to TV
            sendSAMSUNG(code);
      Very simple, ** but is hard to find an example**!
