  3. Header pin solderless splitter / duplicator
7 Posts 4 Posters 5.5k Views 1 Watching
  • S
    samppa
    Is there an easy way to split the Arduino header pin to two or more? Many times there is not enough pins for GND and power or place for the pull-up resistor. It would be great to have a simple pin rail that would be internally interconnected with female or male pins for the dupont cables, pull-up resistors etc..
    I tried to google in vain, so I wonder if there is such a thing existing?
    • greglG
      greglG
      gregl
      Breadboard??
      I'm a massive fan of these.
      http://imall.iteadstudio.com/im120417016.html
      • has header and power regulator for NRF24 radio.
      • has +5v and GND and Signal for each I/O - so you can use pullup/downs for each input as needed.
      S 1 Reply Last reply
      • Z
        Z
        Zeph
        You could take a header strip (male sockets as found on an Arduino, or female pins) and solder a wire to bridge the solder end. Cover the exposed soldered pins with RTV, hot glue, or liquid electrical tape.
        • Z Zeph
          samppa
          @Zeph
          I was hoping to avoid DIY and find some ready made piece for splitting the header pin.. :-)
          • greglG gregl
            Breadboard??
            samppa
            @gregl
            Thanks for the idea, but don't you think it is a bit funny to get a nano and add shield that triples the size? :-)
            I would like the sensors to be as small as possible. I bought some screwshields but even that doubles the size..
            • sowardS
              sowardS
              soward
              I've looked around for these as well, but couldn't find any and just made my own. Perhaps it's a product opportunity?
              • sowardS soward
                samppa
                @soward
                Go ahead design those, sell to all arduino dealers and mass produce them.
                (Notice the order; first sell then produce)
