  3. Super Simple RFM69HW Node
13 Posts 4 Posters 2.5k Views 4 Watching
  • N Offline
    N Offline
    This post is deleted!
    alexsh1A 1 Reply Last reply
    • N NeverDie
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      @NeverDie how did you program the chip? Or you programed it before soldering?
      N 1 Reply Last reply
      • alexsh1A alexsh1
        N Offline
        N Offline
        • N Offline
          N Offline
          Y alexsh1A 2 Replies Last reply
          • N NeverDie
            Y Offline
            Y Offline
            @NeverDie wow! That's one mega hack solution :satisfied:
            How about decoupling caps in your Super Simple RFM69HW node?
            I'd guess it requires a good and stable power supply.
            • Y Yveaux
              N Offline
              N Offline
              • N NeverDie
                N Offline
                N Offline
                • N NeverDie
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @NeverDie where did you get such a small antenna? How is reception in your view? Very much interested rather than having a 16.5cm wire
                  • alexsh1A alexsh1
                    N Offline
                    N Offline
                    • S Offline
                      wrote on last edited by scalz
                      @NeverDie
                      interesting ;) even if i'm not a big fan of lot of wiring :confused: but it's nice for prototyping. In fact I'm not enough patient! and the more component you add the more pain to solder everything. That's why i prefer custom pcb :) but i understand the concept. Why don't you try to design a custom pcb??
                      i never tried this type of antenna, seems interesting but add another 2€..in other side it helps in assembly..dilemma! Maybe I will try for some future board for curiosity.
                      I see you stick your antenna behind your radio module, but perhaps if you don't want to loose too much efficiency, it would be better to not put antenna above ground or trace..Very curious to see performance as wire works very well on my side;
                      Anyway! thx for share your experience ;)
                      • S scalz
                        @NeverDie
                        N Offline
                        N Offline
                        • S Offline
                          ah ok, i thought you may know designing..so i misunderstood :confused: Btw your SSRN is a nice other alternative. I didn't wanted to be negative. just personal feedback with also some positive ;)
                          about designing and assembling etc there are already lot of nice board like moteino, gertsanders, and koresh too!
                          i apologize for frustration but can't help you for the moment. no need of challenge but nice try, i don't see why and for what???
                          so patience or diy as you are doing. keep the good work
                          • S scalz
                            N Offline
                            N Offline
                            Yeah, I see all too clearly what your saying.
                            I'm outta here.
                            12.1k
