Problems with first sensors
I downgraded from arduino.cc IDE 1.6.10 to 1.6.8. Now it uploads to the arduino nano without errors...
Seriell monitor (serial gateway):
0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0) 0;255;3;0;9;TSM:INIT 0;255;3;0;9;TSM:RADIO:OK 0;255;3;0;9;TSM:GW MODE 0;255;3;0;9;TSM:READY 0;255;3;0;14;Gateway startup complete. 0;255;0;0;18;2.0.0 0;255;3;0;9;No registration required 0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OK 0;255;3;0;9;TSP:SANCHK:OKNow I want to connect the gw to my test VeraEdge. I followed the instructions, uploaded the .xml-files and created a device. But, in APPS/DEVELOP PPS/SERIAL PORT CONFIG" I can not find the via USB connected serial gateway. And, I do not know where to restart vera itself or the luup engine.
The dashboard shows this message: MySensors plugin : Choose the Serial Port. Under DEVICES the MySensors Plugin shows: Lua Startup Failure.
Using the IDE I saw the gw is working (see above). Why does Vera not recognize the gw on USB ?
Could someone help, please ?
Did you manage to do these steps in your Vera device:
Finally, go to: APPS Develop Apps Serial port configuration. See the screenshot to the right.
For the Used by device: setting, select the Arduino Gateway Plugin [] from the menu of available devices.
Set baud rate to 115200.
Set the parity to none with 8 data bits and 1 stop bit.more details here -> https://www.mysensors.org/controller/vera#configuring-the-vera-plugin-for-the-serialusb-gateway
