  3. NRF24-Autoack
NRF24-Autoack
6 Posts 2 Posters 2.9k Views 6 Watching
  • cimba007C Offline
    cimba007C Offline
    cimba007
    as I understand the NRF24-driver relies on auto-ack to deliver a packet on the lowest level before resolving undeliverable packets at the transport layer.
    For some reason my modules don't work very well with auto ack ( https://forum.mysensors.org/topic/1664/which-are-the-best-nrf24l01-modules/276 )
    I have not fully tested the results of disabling auto ack but I wan't to know/get an better insight at what level I might mitigate my issue. To rely on the transport layer seems to be the wrong solution as 3-5 consecutive packet losses results in an expansive parent recovery procedure.
    Is there anybody who had a similar issue or could point out some idea on how to implement an acknowledgement on the RF24 driver level? The main problem would be the receiving node which has to know where to send the ack back.
    It should be no mayor problem to use
    LOCAL bool RF24_sendMessage( uint8_t recipient, const void* buf, uint8_t len ) {
    and before returning switch to listen mode and wait for a few millis for an manual acknowledge packet.
    I would be happy about any suggestions on how to resolve this issue.
    PS: Is there any callgraph on the complex mysensors layer or anybody knows a programm to browse trough the code in an call graph fashin? e.g. high level send -> transportlayer send -> rf-layer send .. etc.? To be honest the statemachine is not that easy to understand.
    Greetings Marc
    • cimba007C Offline
      cimba007C Offline
      cimba007
      As I try to understand what is happening inside the library I got a little diagram. My next goal would be to implement an software autoack on a low level and I would be happy to receive some input.
      autoack and ack refer the the low level ack-feature of the nrf24
      I am still not sure if a low level software autoack is the feature I want to have but the hardware autoack seems to be blocking in a while loop until the successful ack is received anyway.
      	do {
      		status = RF24_getStatus();
      	} while  (!(status & ( _BV(MAX_RT) | _BV(TX_DS) )) && timeout--);
      Waiting for the soft-ack seems to be easy:
              .... sending normal packet here ....
      	RF24_startListening();
      	// <---> WAIT HERE FOR SOFT-ACK ?!
      	// true if message sent and not timeout
      	return (status & _BV(TX_DS) && timeout);
      Finding out who send the message in the "RF24_readMessage.h" seems to be the hard part .. although "MyMessage.h" contains some hint:
      	uint8_t last;            	 // 8 bit - Id of last node this message passed
      Is it correct to assume that the first byte of the payload is the sending node of the received packet? The node-id reflect the LSB (lowest 8 bit) of the default node-address
      #ifndef MY_RF24_BASE_RADIO_ID
      #define MY_RF24_BASE_RADIO_ID 0x00,0xFC,0xE1,0xA8,0xA8
      Well .. still waiting on some comments >.>
      Y 1 Reply Last reply
      • cimba007C cimba007
        	do {
        Y Offline
        Y Offline
        @cimba007 the mysensors library already supports requesting a software ack from the target node. A message can be flagged (command_ack_payload) so the target will send the same message back as confirmation it did arrive at the target. A node requesting a software ack should therefore parse incoming messages scanning for the ack response.
        You seem to have a software background, so I guess you can figure out the rest by looking at the code.
        Good luck!
        cimba007C 1 Reply Last reply
        • Y Yveaux
          Good luck!
          cimba007C Offline
          cimba007C Offline
          cimba007
          wrote on last edited by cimba007
          @Yveaux Thank you Yveaux. I didn't know that you get whole exact same message as ack so it would be very easy to confirm correct reception. I will try it out! Might be much easier then implementing it on low level.
          		#else
          			// Call incoming message callback if available
          			if (receive) {
          				receive(_msg);
          Got it ;-)
          • cimba007C Offline
            cimba007C Offline
            cimba007
            My current design for utilizing autoack in software.
            This solution does not depend on the receive function but depends on advanced parameters for wait. It relies on receiving the same message in the wait-function (same command and type). In printmsg function of Helper.ino I tried to do some further checks for sender and destination and ackFlag.
            Maybe some1 could create a stripped down version which might be included in the mysensors-examples.
            My "controller" is a "GatewayESP8266MQTTClient" Sketch on a second node.
            wait(200,message.getCommand(),message.type)
            MainFile.ino
            #include <Streaming.h>
            #include "Statistic.h"
             * Version 1.0 - Henrik EKblad
             * Example sketch showing how to measue light level using a LM393 photo-resistor
             * http://www.mysensors.org/build/light
            #define MY_NODE_ID 10
            #define MY_BAUD_RATE 57600
            //#define MY_DEBUG
            #define LIGHT_SENSOR_ANALOG_PIN A3
            #define MICRO_SENSOR_ANALOG_PIN A1
            unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
            #define CHILD_ID_LIGHT 0
            #define CHILD_ID_MICRO 0
            #define TRIPPED_THRESHOLD 50
            MyMessage msg_light(CHILD_ID_LIGHT, V_LIGHT_LEVEL); // 23
            MyMessage msg_micro(CHILD_ID_MICRO, V_TRIPPED);     // 16
            MyMessage msg_micro_debug(0,V_VAR1);   // 24
            MyMessage msg_obstx_debug(0,V_VAR2);   // 25
            unsigned long msg_micro_send;
            void before()
              // LightSensor
              pinMode(A3,INPUT_PULLUP);
              pinMode(A2,OUTPUT);
              digitalWrite(A2,LOW);
              // Microwave
              pinMode(5,OUTPUT);        // VCC BISS0001
              digitalWrite(5,HIGH);
              pinMode(6,OUTPUT);        // Enabled
              digitalWrite(6,LOW);      // Enable
              pinMode(7,OUTPUT);        // GND
              digitalWrite(7,LOW);
              pinMode(8,OUTPUT);        // VCC Radar
              digitalWrite(8,HIGH);
              pinMode(A1,INPUT);        // PIR 2nd Amplification Stage
              // Other
            void presentation()  {
              sendSketchInfo("Microwave+Light", "1.0");
              // https://www.mysensors.org/download/serial_api_20#sensor-type
              present(CHILD_ID_MICRO, S_MOTION);
              //present(0, S_ARDUINO_NODE);
              // Report VCC
              static long vcc = readVcc();
              static int vccpercent = map(vcc,1800,3280,0,100);
              sendBatteryLevel(max(min(vccpercent,100),0),false);
              Serial << "| vcc: ";
              p(F("%4d"),vcc);
              Serial << " ";
              // Required for ack
              //wait(100);
              // Report LightLevel
              analogRead(LIGHT_SENSOR_ANALOG_PIN);
              int lightLevel_raw = analogRead(LIGHT_SENSOR_ANALOG_PIN);
              int lightLevel = (1023-lightLevel_raw)/10.23; // as of 1023 !!
              Serial << "| light_raw: ";
              p(F("%4d"),lightLevel_raw);
              Serial << " ";
              Serial << "| light: ";
              p(F("%3d"),lightLevel);
              Serial << " ";
              send(msg_light.set(lightLevel),false);
              // Report WirelessLink Information
              Serial << "| observe_tx: ";
              uint8_t obstx = RF24_readByteRegister(OBSERVE_TX);
              p(F("%X"),obstx);
              Serial << " ";
              send(msg_obstx_debug.set(0x0F&obstx),false);
              // Report Microwave
              Statistic mw_s;
              mw_s.clear();
              delay(90);
              analogRead(MICRO_SENSOR_ANALOG_PIN);
              delay(10);
              for(int i = 0; i < 1000; i++)
                mw_s.add(analogRead(MICRO_SENSOR_ANALOG_PIN));
                delay(1);
              Serial << "| mw_raw: ";
              int stddev = mw_s.pop_stdev();
              p(F("%4d"),stddev);
              Serial << " ";
              Serial << "| mw_min: ";
              int minimum = mw_s.minimum();
              p(F("%4d"),minimum);
              Serial << " ";
              Serial << "| mw_max: ";
              int maximum = mw_s.maximum();
              p(F("%4d"),maximum);
              Serial << " ";
              Serial << "| mw: " << (stddev > TRIPPED_THRESHOLD ? "1" : "0") << " ";
              send(msg_micro_debug.set(stddev),false);
              msg_micro_send = micros();
              send(msg_micro.set(stddev > TRIPPED_THRESHOLD ? "1" : "0"),true);
              if(isTransportOK())
                if(!waitforack(200,msg_micro)) // time, msg
                  Serial.print(" | no ack! ");
                else
                  Serial.print(" | msg ok! ");
                  Serial.print(" | "); Serial.print(micros()-msg_micro_send); Serial.print("uS");
              // waitforack includes time for repair transport
              Serial << endl;
            bool waitforack(unsigned long ms, MyMessage &message)
                bool ok = false;
                uint8_t c = 10;
                while(!ok && c)
                  // Ack?!
                  if(wait(200,message.getCommand(),message.type))
                    Serial.print(" | rpd: "); Serial.print(RF24_readByteRegister(RPD));
                    return true;
                  else
                    if(isTransportOK())
                      Serial.print(" | Transport broken! ");
                      wait(1000);
                    Serial.print(" ~ ");
                    send(message,true);
                  c--;
                if(c == 0)
                  return false;
            // https://forum.mysensors.org/topic/3463/m_ack_variable-or-m_set_variable/2
              /* Don't do much here, will delay "wait" */
              //Serial.println();
              //printmsg(message,&msg_micro,msg_micro_send);
            Helper.ino
            long readVcc() {
              #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
              #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                ADMUX = _BV(MUX5) | _BV(MUX0);
              #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                ADMUX = _BV(MUX3) | _BV(MUX2);
              #else
              long result = (high<<8) | low;
              //result *= 1.0637;
            #include <stdarg.h>
            void p(const __FlashStringHelper *fmt, ... ){
              char buf[128]; // resulting string limited to 128 chars
              va_list args;
              va_start (args, fmt);
            #ifdef __AVR__
              vsnprintf_P(buf, sizeof(buf), (const char *)fmt, args); // progmem for AVR
            #else
              vsnprintf(buf, sizeof(buf), (const char *)fmt, args); // for the rest of the world
              va_end(args);
              Serial.print(buf);
            void mysleep(int SLEEP_TIME)
                if(isTransportOK()){
                  Serial << "| wait ";
                  wait(25);
                  Serial << "| zZz > ";
                  sleep(SLEEP_TIME);
                  Serial << "| < zZz " << endl;
                else {
                  wait(1000);
            void printmsg(const MyMessage &message, const MyMessage *reference, unsigned long starttime)
              unsigned long s = micros();
              Serial.print("-------------Message Information:-------------"); Serial.println();
              Serial.print("last:        "); p(F("%8d"),message.last);        Serial.println();
              Serial.print("sender:      "); p(F("%8d"),message.sender);      Serial.println();
              Serial.print("destination: "); p(F("%8d"),message.destination); Serial.println();
              Serial.print("command:     ");
              switch(message.getCommand())
                case 0: Serial.print("presentation (0)");                     Serial.println(); break;
                case 1: Serial.print("set (1)");                              Serial.println(); break;
                case 2: Serial.print("req (2)");                              Serial.println(); break;
                case 3: Serial.print("internal (3)");                         Serial.println(); break;
                case 4: Serial.print("stream (4)");                           Serial.println(); break;
              Serial.print("isAck:       "); if(message.isAck()) { Serial.print("    true"); } else { Serial.print("   false"); } Serial.println();
              Serial.print("type:        "); p(F("%8d"),message.type);        Serial.println();
              Serial.print("sensor:      "); p(F("%8d"),message.sensor);      Serial.println();
              const char mybuffer[25];
              message.getString(mybuffer);
              Serial.print("payload:     "); Serial.print(mybuffer);          Serial.println();
              if(starttime != 0)
                Serial.print("RoundTripT.  "); p(F("%8ld"),(s-starttime));Serial.println(" uS");
                if(&reference)
                  const MyMessage m = *reference;
                  if
                    (message.getCommand() == reference->getCommand())
                  &&(message.sender       == reference->destination)
                  &&(  (message.isAck() == 1) && mGetRequestAck(m)  )
                  Serial.print("identical!");                                   Serial.println();
                  Serial.print("0x");p(F("%02X"),reference->command_ack_payload);Serial.println();
              Serial.print("----------------------------------------------"); Serial.println();
            void printmsg(const MyMessage &message)
              printmsg(message, NULL, 0);
            void printmsg(const MyMessage &message, unsigned long starttime)
              printmsg(message, NULL, starttime);
            Example Output:
            // no transmission error
            | vcc: 3280 | light_raw:  729 | light:  28 | observe_tx: 0 | mw_raw:   21 | mw_min:  424 | mw_max:  565 | mw: 0  | rpd: 1 | msg delivered!  | 28200uS
            // one retry
            | vcc: 3280 | light_raw:  728 | light:  28 | observe_tx: 0 | mw_raw:   37 | mw_min:  387 | mw_max:  571 | mw: 0  ~  | rpd: 1 | msg delivered!  | 212712uS
            "long term"-update:
            You can see that channel 16 got at least loss (channel 16 = software autoack and retry)
            • cimba007C Offline
              cimba007C Offline
              cimba007
              I stripped down my example and tried to capsulate it in its own wrapper class. This is by no means complete or ready to use .. it is just there to give interested people some kind of input on how to work with the wait/autoack stuff if you can't use your radios autoretry feature like me.
              If you need some comments to understand parts of the code feel free to ask.
              LightSensorSoftwareAckNRF24_class.ino
              //#define MY_DEBUG
              #define MINUTES 60000UL
              #include "helper.cpp"
              void before()
                // LightSensor
                // http://akizukidenshi.com/download/ds/senba/GL55%20Series%20Photoresistor.pdf
                // GL5549
                pinMode(A3,INPUT_PULLUP); // 20-50 kOhm
                pinMode(A2,OUTPUT);
              MySensorChild photoSensor = MySensorChild(CHILD_ID_LIGHT,S_LIGHT_LEVEL,"Photoresistor GL5549");
                sendSketchInfo("LightClass_Test", "0.1");
                photoSensor.do_present();
                // Set Message
                photoSensor.message()->set(random(0,100));
                // Print Result
                photoSensor.print(photoSensor.waitsend(250));
                delay(1000);
              helper.cpp
              #include "core/MySensorsCore.h"
              #include "core/MyTransport.h"
              #include "drivers/RF24/RF24.h"
              #include <stdarg.h>
              class MySensorChild
                public:
                  typedef struct {
                    uint8_t rpd;
                    unsigned long long elapsedtime;
                    uint8_t success;
                    uint8_t retrycount;
                  } return_struct;
                  void print(return_struct r)
                    Serial.print(r.success == 1 ? "success" : "fail   "); Serial.print(" | ");
                    Serial.print("time: "); p(F("%8d"),r.elapsedtime);    Serial.print("uS | ");
                    Serial.print("retr.: "); p(F("%2d"),r.retrycount);    Serial.print(" | ");
                    Serial.print("rpd: "); Serial.print(r.rpd);           Serial.print(" | ");
                    Serial.println();
                public:
                  MySensorChild(uint8_t childid, uint8_t valuetype, char * description)
                    // Base Values that define a Message
                    this->description = description;
                    this->childid = childid;
                    this->valuetype = valuetype;
                    this->message_internal = MyMessage(childid, valuetype);
                  MyMessage * MySensorChild::message()
                    return &this->message_internal;
                  void do_present()
                    present(this->childid, this->valuetype, this->description);
                  return_struct MySensorChild::waitsend(unsigned long ms)
                      bool ok = false;
                      const uint8_t retrycountlimit = 10;
                      unsigned long long starttime = micros();
                      return_struct r;
                      send(message_internal,true);
                      uint8_t c = retrycountlimit;
                      while(!ok && c)
                        // Ack?!
                        if(wait(ms,message_internal.getCommand(),message_internal.type))
                          r.rpd = RF24_readByteRegister(RPD);
                          r.elapsedtime = micros()-starttime;
                          r.success = true;
                          r.retrycount = retrycountlimit-c;
                          return r;
                          //Serial.print(" | rpd: "); Serial.print(RF24_readByteRegister(RPD));
                          // Return!
                          //return true;
                        else
                          if(!isTransportOK())
                            wait(100);
                          //Serial.print("~");
                        c--;
                      if(c == 0)
                        r.success = false;
                        return r;
                        //return false;
                private:
                  MyMessage message_internal;
                  char * description;
                  uint8_t childid;
                  uint8_t valuetype;
                  unsigned long lastSend;
                    va_list args;
                  #ifdef __AVR__
                  #else
                    va_end(args);
                    Serial.print(buf);
              Example output (mydebug enabled @ gateway)
              success | time:   16mS | retr.:  0 | rpd: 1 | <\r><\n>
              success | time:   17mS | retr.:  0 | rpd: 1 | <\r><\n>
              success | time:   13mS | retr.:  0 | rpd: 1 | <\r><\n>
              success | time:   10mS | retr.:  0 | rpd: 1 | <\r><\n>
              success | time:   12mS | retr.:  0 | rpd: 1 | <\r><\n>
              success | time:   11mS | retr.:  0 | rpd: 1 | <\r><\n>
              fail    | time: 2504mS | retr.: 10 | rpd: 0 | <\r><\n>
              fail    | time: 2505mS | retr.: 10 | rpd: 0 | <\r><\n>
              Always a good idea to disable debugging if you are happy with the performance. Debugging output on serial on the mqtt-gateway (esp8266) takes quite a while.
              success | time:    4mS | retr.:  0 | rpd: 1 | <\r><\n>
              success | time:    2mS | retr.:  0 | rpd: 1 | <\r><\n>
              success | time:    5mS | retr.:  0 | rpd: 1 | <\r><\n>
