  3. IBoard with MySensors 2.0 library
4 Posts 3 Posters 2.6k Views 4 Watching
  • Bart BaarsB
    Bart BaarsB
    Bart Baars
    wrote on last edited by Bart Baars
    Just bought a Iboard 1.1 and used the thread below to configure it.
    https://forum.mysensors.org/topic/224/iboard-cheap-single-board-ethernet-arduino-with-radio/2
    I used the Gatewayw5100 sketch and editted the following:
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN 7
      #define MY_SOFT_SPI_MISO_PIN 6
      #define MY_SOFT_SPI_MOSI_PIN 5
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 3
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 8
    #endif```
    Also editted myconfig.h:
    // Enable SOFTSPI for NRF24L01, useful for the W5100 Ethernet module
    #define MY_SOFTSPI
     * @def MY_SOFT_SPI_SCK_PIN
     * @brief Soft SPI SCK pin.
    #ifndef MY_SOFT_SPI_SCK_PIN
     * def MY_SOFT_SPI_MISO_PIN
     * @brief Soft SPI MISO pin.
    #ifndef MY_SOFT_SPI_MISO_PIN
     * @def MY_SOFT_SPI_MOSI_PIN
     * @brief Soft SPI MOSI pin.
    #ifndef MY_SOFT_SPI_MOSI_PIN
    All seems to work fine, except that the board keeps restarting? Debug-output:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.0.237
    IP: 192.168.0.237
    The debug-log keeps flooding like this. I can ping the board, but 50% of all pings fail. Telnetting to port 5003 fails.
    Anyone got any idea what is happening?
    • F
      F
      flzicmu
      I just success with my IBOARD 1.1 and MySensors 2.0. No need to modify the file "myconfig.h". With your config I had the same result as you.
      here my sketch:
       * Version 1.0 - Henrik EKblad
       * Contribution by Tomas Hozza <thozza@gmail.com>
       * LED purposes:
      #define MY_GATEWAY_W5100
      //#define MY_GATEWAY_ENC28J60
      //#define MY_W5100_SPI_EN 4
      // radio on the same spi bus.
        #define MY_SOFTSPI
      // Enable to UDP
      //#define MY_USE_UDP
      #define MY_IP_ADDRESS ***<your IP> ***  // If this is disabled, DHCP is used to retrieve address
      #define MY_PORT 5003
      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
      // Flash leds on rx/tx/err
      #define MY_LEDS_BLINKING_FEATURE
      // Set blinking period
      // Enable inclusion mode
      #define MY_INCLUSION_MODE_BUTTON_PIN  14
      #define MY_DEFAULT_ERR_LED_PIN 15  // Error led pin
      #define MY_DEFAULT_TX_LED_PIN  17  // the PCB, on board LED
      #if defined(MY_USE_UDP)
        #include <EthernetUdp.h>
      #include <Ethernet.h>
      It seems to work fine. I let it run during all night...
      • F
        F
        flzicmu
        I confirm that my gateway works very well. I made several OTA firmware updates on my sensebenders.
        • clippermiamiC
          clippermiamiC
          clippermiami
          wrote on last edited by clippermiami
          Several years ago I built my Ethernet Gateway using this iBoard and the MySensors 1.2 firmware. I made the wiring changes on the board to use the "vanilla" Ethernet Gateway software and the NRF24L01 Radio. I am still using it but I'm ready to make the move to MySensors 2.0 so I'm pleased to see the board works with the new library.
          Did you make physical wiring changes on your hardware to suit the radio or just make the changes in changes in the Config. I have two of the iBoards, one with modified traces and one out of the box so I can go either way
