  3. Help on code for Mysensors 2.0
11 Posts 5 Posters 4.2k Views 3 Watching
  • S
    stingone
    Hi everone.
    Couple of months i created a code for my dallas an ph sensor. however i reinstalled my pc and installed the mysensors 2.0 resulting in a error with No forward link or gateway feature activated.
      Original code created by DFRobot for their probes,
      adapted by haze5@icloud.com Mysensors for the project.
    #include <OneWire.h>
    #include "Vcc.h"        // https://github.com/Yveaux/Arduino_Vcc
    static const float VccMin = 0.0;        // Minimum expected Vcc level, in Volts. (0.6V for 1 AA Alkaline)
    static const float VccMax = 3.3;        // Maximum expected Vcc level, in Volts. (1.5V for 1 AA Alkaline)
    static const float VccCorrection = 3.29 / 3.31;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
    #define CHILD_ID_PH 0
    #define ArrayLenth 10               // times of collection
    #define PH_SENSOR_ANALOG_PIN A0         // pH meter Analog output to Arduino Analog Input 0
    #define LED_DIGITAL_PIN 13
    #define Offset 0.25           //deviation compensate
    #define CHILD_ID_TEMP 1
    unsigned long lastSend = 0;
    static const unsigned long SEND_FREQUENCY = 30000;  // Minimum time between send (in milliseconds)
    float lastPhHValue;
    static const float deltaPhValue = 0.5;
    int numSensors=0;
    boolean metric = true;
    MyMessage msgPH(CHILD_ID_PH, V_VAR1);
    MyMessage msg(CHILD_ID_TEMP,V_TEMP);
        sensors.begin();
        //gw.begin(NULL, 100, false); //deze gebruiken, 100 is de node_id, die weer gebruiken in pimatic
        gw.begin();
        //Serial.print("0;0;3;0;2;");Serial.print(LIBRARY_VERSION);
        pinMode(LED_DIGITAL_PIN, OUTPUT);
        gw.sendSketchInfo("pHmeter", "1.0");
        gw.present(CHILD_ID_PH, S_WATER);
        gw.present(i, S_TEMP);
        // By calling process() you route messages in the background
        gw.process();
        read_PH();
        read_TEMP();
        gw.sleep(SLEEP_TIME);
    void read_PH(){
       unsigned long now = millis();
        bool sendTime = now - lastSend > SEND_FREQUENCY;
        if (sendTime)
            lastSend = now;
            //    float v = vcc.Read_Volts();
            //    Serial.print("VCC = " );
            //    Serial.print(v);
            //    Serial.println(" Volts" );
            int batteryPcnt = (int)vcc.Read_Perc(VccMin, VccMax);
            //    Serial.print(batteryPcnt);
            //    Serial.println(" %" );
        // Read PH_SENSOR_ANALOG_PIN in phValue
        float voltage = analogReadAverage(PH_SENSOR_ANALOG_PIN, 10) * 5.0 / 1024;
        // convert the millivolt into pH value
        float PhValue = 3.5 * voltage+Offset;
        if (sendTime || abs(PhValue - lastPhHValue) > deltaPhValue)
            Serial.print("    pH:");
            Serial.print(PhValue, 2);
            Serial.println(" ");
            gw.send(msgPH.set(PhValue, 2)); // envoi au reseau avec deux decimales
            digitalWrite(LED_DIGITAL_PIN, digitalRead(LED_DIGITAL_PIN) ^ 1);
            lastPhHValue = PhValue;
    void read_TEMP(){
      gw.sleep(conversionTime);
        #if COMPARE_TEMP == 1
        #else
    double analogReadAverage(uint8_t pin, unsigned long ms)
        double average = 0;
        int buffer[ArrayLenth];
        for (int i = 0; i < ArrayLenth; i++)
            buffer[i] = analogRead(PH_SENSOR_ANALOG_PIN);
            delay(ms);
        if (ArrayLenth < 5)
            // less than 5, calculated directly statistics
                average += buffer[i];
            average = average / ArrayLenth;
        else
            // Sort the values from small to large
                for (int j = i + 1; j < 10; j++)
                    if (buffer[i] > buffer[j])
                        int temp = buffer[i];
                        buffer[i] = buffer[j];
                        buffer[j] = temp;
            // take the average value of center sample
            for (int i = 2; i < ArrayLenth - 2; i++)
            average = average / (ArrayLenth - 4);
        return average;
    • scalzS
      scalzS
      wrote on last edited by scalz
      Hello.
      It seems that you have not converted your old sketch to 2.0 In the new release there is no need of declaring a Mysensor instance like before "Mysensor gw" and some other stuff ..
      So, what you can do:
      • convert your sketch to 2.0. For details see here : https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
      • or look at the 2.0 examples sketch to see how it looks now. and don't worry if there is not so much code in new sketch compared to before, the stuff is hidden that's all ;)
      If still issues, please post logs so we can help you. without not easy..
      S 1 Reply Last reply
      • scalzS scalz
        Hello.
        stingone
        @scalz said:
        Hello.
        I will try to change the code. for now i installed the 1.5 again however compiling is fine but it says at the end error uploading sketch thats all no other messages.. i already tried 3 board other usb cable. com ports settings are fine and i can use the serial monitor with the existing code but somehow it wont upload the new.
        • sundberg84S
          @stingone - if you get an upload error, its not about the code. Its the connection between computer, usb, uploader and arduino.
          Do you have changed drivers for the programmer recently? got the right programmer set in arduino ide? Can you paste the log from arudino ide in here?
          • scalzS
            scalzS
            @stingone oki. when it fails to upload (for the error you're describing), try again to upload, that should work. sometimes it can need multiple attempts. it's not mysensors related.
            • GertSandersG
              GertSandersG
              GertSanders
              After recompiling to 2.0.0 and uploading to your node, you will also need to bring the gateway to version 2.0.0
              A 2.0.0 gateway should work with older nodes. But new 2.0.0 nodes require a 2.0.0 gateway.
              • S
                stingone
                Got it working with another laptop..wil recompile to 2.0 in the weekend.
                Just a quick question. I have 2 sensors on 1 arduino. Works fine however sometimes it shows the value of the temp sensor on the value of the ph sensor.
                #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
                float lastPhHValue;
                int numSensors=0;
                    sensors.begin();
                    gw.begin();
                    gw.sendSketchInfo("pHmeter", "1.1");
                    gw.process();
                    read_PH();
                    read_TEMP();
                void read_PH(){
                    if (sendTime)
                        lastSend = now;
                        //    Serial.print(v);
                void read_TEMP(){
                    #else
                    double average = 0;
                        delay(ms);
                    if (ArrayLenth < 5)
                    else
                                    buffer[j] = temp;
                    return average;
                And in Pimatic
                      "id": "temperatuur-aquarium",
                      "name": "Temperatuur Aquarium",
                      "class": "MySensorsDST",
                      "nodeid": 2,
                      "sensorid": 0
                      "id": "phmeter-aquarium",
                      "name": "pH Aquarium",
                      "class": "MySensorsPH",
                      "nodeid": 2,
                      "sensorid": 0,
                      "batterySensor": false
                debug [pimatic-mysensors]: <- MySensorsPH { sender: 2, sensor: 0, type: 0, value: '25.4' }
                22:23:06debug [pimatic-mysensors]: <- MySensorDST { sender: 2, sensor: 0, type: 0, value: '25.4' }
                22:23:06debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;0;3;0;9;read: 2-2-0 s=0,c=1,t=0,pt=7,l=5,sg=0:25.4
                22:23:05debug [pimatic-mysensors]: <- MySensorsPH { sender: 2, sensor: 0, type: 24, value: '6.60' }
                22:23:05debug [pimatic-mysensors]: <- I_LOG_MESSAGE 0;0;3;0;9;read: 2-2-0 s=0,c=1,t=24,pt=7,l=5,sg=0:6.60
                If you look at the output in pimatic you can see that the mysensorsPH and mysensorsDST have the temp value. This happens 50% of the time.
                • S stingone
                  float lastPhHValue;
                  int numSensors=0;
                      sensors.begin();
                      gw.begin();
                      gw.process();
                      read_PH();
                      read_TEMP();
                  void read_PH(){
                      if (sendTime)
                          lastSend = now;
                          //    Serial.print(v);
                  void read_TEMP(){
                      #else
                      double average = 0;
                          delay(ms);
                      if (ArrayLenth < 5)
                      else
                                      buffer[j] = temp;
                      return average;
                  And in Pimatic
                        "nodeid": 2,
                        "sensorid": 0
                        "nodeid": 2,
                        "sensorid": 0,
                  @stingone this line
                  will set the child id to 0 for the first temp sensor, to 1 for the second and so on. That's why you get temperature data on id 0, which is also used by the ph sensor.
                    @stingone this line
                    stingone
                    @mfalkvidd said:
                    @stingone this line
                    What would be best to do?
                      It depends on how much work you are prepared to do and how much flexibility you want in the code.
                      If you only use one temperature sensor and don't have any plans to add more, change
                      to
                      gw.send(msg.set(temperature,1));
                        to
                        stingone
                        Only using the ph sensor and 1 temperatuur sensor no need for more temp sensors.
