  3. Dimmable light for makeup mirror (battery powered)
ledsimplesaf
2 Posts 2 Posters 1.2k Views 1 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/124/Dimmable-light-for-makeup-mirror-battery-powered
    • mfalkviddM Offline
      This is a simple, low-cost and quick project that can get a high spouse acceptance factor.
      Mirror
      • Remove the led strip from the aluminum profiles.
      • Cut the aluminum profiles and the covers to appropriate length. I used a hacksaw to cut profile+cover at the same time to ensure the got the same length.
      • Cut the led strips at one of the cut points using a side cutter.
      • Remove the old wires (they are too short to reach the box) and solder new wires.
      • Put the led strip back inside the aluminum profile. Note that there is a small grove at the back for the strip, this ensures that the strip is close to the profile to maximize cooling.
      • Glue the profiles to the mirror. I used slow-curing epoxy.
      Electronics box
      • Drill holes in the project box for the switch (6mm) and the potentiometer (6mm should be enough but was too tight so I used 8mm).
      • Drill a 4mm hole for the wires to the led strips.
      • Upload the sketch to the Arduino
      • Connect the Arduino and the battery packs and put them inside the project box.
      • Fasten the project box using double-sided tape.
      Big thanks to my wife for letting me use the action photo.
      Makeup mirror light
