  3. Nice/cheap shield for nano/24L01
4 Posts 4 Posters 2.2k Views 4 Watching
  • siklosiS Offline
    siklosiS Offline
    siklosi
    Just saw this board...
    http://www.ebay.com/itm/NANO-Prototype-Shield-NANO-IO-Expansion-Board-with-XBee-24L01-Interface-/311668101335
    • F Offline
      F Offline
      Fabien
      I use this board for my test gateway. Works fine and all IO aviable with GND/5V next.
      • T Offline
        T Offline
        TimO
        Looks like the one I got from itead. Very handy for prototyping! :+1:
        • K Offline
          K Offline
          korttoma
          Just a heads up to prevent others from running in to same issue as I did.
          I tried to use this board together with a RFM69 radio module that I had connected through a Logic Level Shifter connecting it to the 8 pin nRF24L01 interface but I just could not get it to communicate. The problem was that the MOSI,SCK, CE and CSn pins had some resistor bridge voltage dividers on the board. I removed the voltage dividers and it started to work.
          I could probably have used the RFM69 module without the Logic Level Shifter directly on this board but I did not want to risk damaging the radios since they are the most expensive part in this setup.
          • Tomas
          12.2k
