  3. ESP8266 Gateway motion sensor only working when "serial monitor" open
3 Posts 2 Posters 1.8k Views 2 Watching
  • O Offline
    O Offline
    Opus40
    wrote on last edited by Opus40
    Hi every one
    I'm building a ESP8266 as a motion sensor and have got it working but only when the serial monitor is open in the Arduino IDE. if I don't have the monitor open it just stays in the motion detected state "1" this i can see using both MSYController and in the Vera Interface. As soon as i open the serial monitor it then goes back to "0" until it detects motion then it sends the correct info along to Vera working the way i want it to until disconnecting the serial monitor.
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #include <EEPROM.h>
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "home"
    #define MY_ESP8266_PASSWORD "**********"
    // Enable UDP communication
    //#define MY_USE_UDP
     #define MY_ESP8266_HOSTNAME "sensor-gateway2"
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
    #else
      #include <ESP8266WiFi.h>
    #include <Bounce2.h>
    boolean lastTripped = 0;
    Bounce debouncer = Bounce();
    int oldValue=-1;
    // Initialize motion message
    debouncer.interval(5);
    void presentation() {
      sendSketchInfo("Motion Sensor", "1.31");
      present(CHILD_ID, S_MOTION);
     // Read digital motion value
       if (lastTripped != tripped ) {
          send(msg.set(tripped?"1":"0")); // Send new state and request ack back
          Serial.println(tripped);
          lastTripped=tripped;
    debouncer.update();
      int value = debouncer.read();
      if (value != oldValue) {
         Serial.print("motion Value: ");
         Serial.println(value);
    send(msg.set(value==HIGH ? 1 : 0));
             oldValue = value;
    I'm hoping some one can see some thing simple i have done.
    Thanks for any help
    Y 1 Reply Last reply
    • O Opus40
      Hi every one
       * LED purposes:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
       * GND        GND
      #include <EEPROM.h>
      #else
      int oldValue=-1;
      debouncer.update();
               oldValue = value;
      Thanks for any help
      Y Offline
      Y Offline
      @Opus40 Seems like you're mixing debouncer input and regular IO pin input.
      If you connect something like a PIR sensor you don't need to debounce the input; this is only required for mechanical switching parts like a push button.
      Also, debouncer is not connected to any IO pin, so the debouncer input won't work anyway.
      Not sure if this is causing your problems, but I would start using only digitalRead on the PIR input.
      O 1 Reply Last reply
      • Y Yveaux
        O Offline
        O Offline
        Opus40
        I started out with just the basics, but i get spammed out put of motion triggered and disregards if there is motion or not with the following code
         * LED purposes:
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
        #include <EEPROM.h>
        #define MY_ESP8266_PASSWORD "********"
        // #define MY_ESP8266_HOSTNAME "sensor-gateway"
        #else
          sendSketchInfo("Motion Sensor", "1.0");
          send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        Thank you for the reply
        if i comment out all the debounce and re upload it then doesn't read the motion sensor and just out puts motion dectected at power up.
