  3. Binary_switch_sleep_sensor sketch does not work
4 Posts 2 Posters 1.2k Views 2 Watching
  • S
    Sergio_uno
    wrote on last edited by Sergio_uno
    Hi all,
    As a first step with MySensors I decided to a build binary switch sensor. I found that pull-up on Pin 2&3 does not work. And this is because all void setup() section newer executed (I added a marker Serial.println("Setup section reached "); )
    Needles to say that void loop() does not work either.
    Here is the sketch
    #define MY_NODE_ID 123
    #define SKETCH_NAME "Binary Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2 // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
    #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    // Setup the buttons
    pinMode(PRIMARY_BUTTON_PIN, INPUT);
    pinMode(SECONDARY_BUTTON_PIN, INPUT);
    // Activate internal pull-ups
    digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
    digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
    void presentation() {
    sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
    // Register binary input sensor to sensor_node (they will be created as child devices)
    present(PRIMARY_CHILD_ID, S_DOOR);
    present(SECONDARY_CHILD_ID, S_DOOR);
    uint8_t value;
    static uint8_t sentValue=2;
    static uint8_t sentValue2=2;
    sleep(5);
    value = digitalRead(PRIMARY_BUTTON_PIN);
    Serial.print("Value pin2= ");
    Serial.println (value);
    if (value != sentValue) {
    // Value has changed from last transmission, send the updated value
    send(msg.set(value==HIGH ? 1 : 0));
    sentValue = value;
    value = digitalRead(SECONDARY_BUTTON_PIN);
    if (value != sentValue2) {
    send(msg2.set(value==HIGH ? 1 : 0));
    sentValue2 = value;
    // Sleep until something happens with the sensor
    sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    This is the copy from Serial monitor. You can see that there is no print "Setup section reached", meaning that is not reached and program stuck somewhere in the #define section
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=123)
    TSM:FPAR
    TSP:MSG:SEND 123-123-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    I have Arduino IDE 1.6.9. and updated MySensors library (2.0). The board I tested are arduino UNO and Nano, both behave the same.
    Any suggestions?
    • S Sergio_uno
      Hi all,
      Here is the sketch
      uint8_t value;
      sleep(5);
      sentValue = value;
      sentValue2 = value;
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      Any suggestions?
      @Sergio_uno the node is unable to find a way to send messages to the gateway. Do you have a gateway? If not, build one. It might be possible to use MY_PARENT_NODE_ID to test without a gateway but I don't know the details.
      • S
        Sergio_uno
        Thanks @mfalkvidd. I don't have a gateway and home automation controller. My idea is to run a code on a gateway arduino and use MySensor libraries to transport sensors data to the GW. Will it work without a home automation controller?
          It will work, and as long as the project just need little functionality it should be manageable. Managing a lot of functionality will be a pain though, since you won't have as nice development and debug tools available (compared to using a real controller on linux or windows machine).
          You will need to hard-code node IDs for all nodes (except the gateway which always has ID 0) though, just as you have already done with #define MY_NODE_ID 123. I mention it because a lot of people have tried to get auto ID from a gateway, but that won't work since the ID assignment is done by the controller.
