  3. Combine DimmableLEDActuator sketch with RelayActuator Sketch
10 Posts 4 Posters 2.6k Views 4 Watching
  • rsaefulR
    rsaefulR
    rsaeful
    wrote on last edited by rsaeful
    HI all,
    i trying to combine this dimmerLEDactuator with Relay actuator to control another Light, but relays seem not working and when i push on to relay, LED also turn on. here my code:
     * Version 1.0 - February 15, 2014 - Bruce Lacey
     * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
     * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
     * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
     * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
     * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
     * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
     * to the LED negative terminal and the MOSFET Source pin is connected to ground.
     * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
     * http://www.mysensors.org/build/dimmer
    #define SN "DimmableLEDRelay"
    #define SV "1.1"
    #define NODE_ID 1
    #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
    #define LED_CHILD 0
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define RELAY_PIN  6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_CHILD 1
    MyMessage relayMsg(RELAY_CHILD,V_STATUS);
    static int currentLevel = 0;  // Current dim level...
    MyMessage dimmerMsg(0, V_DIMMER);
    MyMessage lightMsg(0, V_LIGHT);
     * Dimmable LED initialization method
      //Serial.println( SN );
      gw.begin(incomingMessage, NODE_ID);
      gw.present(LED_CHILD, S_DIMMER );
      gw.present(RELAY_CHILD, S_LIGHT);
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( 0, V_DIMMER );
      pinMode(RELAY_PIN, OUTPUT);
     *  Dimmable LED main processing loop
      gw.process();
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
        // Clip incoming level to valid range of 0 to 100
        Serial.print( "Changing level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel );
        fadeToLevel( requestedLevel );
        // Change relay state
         digitalWrite(RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        //gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
        // hek comment: Is this really nessesary?
        gw.send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel ) {
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
    • logger02L
      logger02L
      logger02
      I think that you must to separate the both input messages in two anidate if, like:
      // Here the code for the relay
      }else if ( message.type == V_DIMMER) {
      // Here the code for the dimmer
      I hope that it will be useful for you
      rsaefulR 1 Reply Last reply
      • logger02L logger02
        rsaefulR
        rsaefulR
        rsaeful
        @logger02 Thank you for your reply, already change as your recommendation, but now LED not working (on), relay now working. when i push bulb icon for LED on domoticz, Relay will on and off. hmm i think this only how we write the logic, but still figure out how to :)
        TheoLT 1 Reply Last reply
        • logger02L
          logger02L
          logger02
          Could you paste the code?
            rsaefulR
            rsaefulR
            rsaeful
            @logger02 her the code
            #define SV "1.1"
            #define NODE_ID 1
            #define LED_CHILD 0
              gw.process();
              if (message.type == V_DIMMER) {
                else (message.type == V_LIGHT);{
            appreciate your help
            • rsaefulR rsaeful
              TheoLT
              TheoLT
              TheoL
              @rsaeful You need to handle messages separately as suggested by @logger02. To do this you first have to make a distinct in the sensor for which you receive a message. Then the type of message.
              void incoming( const MyMessage &message ) {
                if ( message.sensor ==  LED_CHILD && !message.isAck() ) {
                  if ( message.type == V_LIGHT ) {
                    // handle VLIGHT
                    if ( message.getBool() == true ) {
                      // turn on led
                    else {
                       // turn off led
                  else if ( message.type == V_DIMMER ) {
                     // handle dimmer (look at build examples)
                else if ( message.sensor == RELAY_CHILD && !message.isAck() ) {
                  // look for message type and handle RELAY state (you might need to do inverted on/off
              Hope it compiles and or helps. Just typed it in here.
              • rsaefulR rsaeful
                #define SV "1.1"
                #define NODE_ID 1
                #define LED_CHILD 0
                  gw.process();
                TheoLT
                TheoLT
                TheoL
                @rsaeful also better to handle fade code in your main loop. Too much logic in message handler might mess up communication to that node.
                rsaefulR 2 Replies Last reply
                • TheoLT TheoL
                  rsaefulR
                  rsaefulR
                  rsaeful
                  @TheoL i will try to re-write the code and report back here. thank you so much
                  • TheoLT TheoL
                    rsaefulR
                    rsaefulR
                    rsaeful
                    @TheoL almost there, Relay working well, Dimmer is also good but for turn off and on LED light still not yet is still on event i push off or set to minimum level, already 2.20 AM here, better take nap first. i need to understand more about messaging and Little difficult as i not fully understand programing. once again thank you to you all, almost go there.
                    my last code:
                    #define SV "1.1"
                    #define NODE_ID 3
                    #define LED_CHILD 0
                    #define LIGHT_OFF 0
                    #define LIGHT_ON 1
                    MyMessage relayMsg(RELAY_CHILD,V_LIGHT);
                    MyMessage dimmerMsg(LED_CHILD, V_DIMMER);
                    MyMessage lightMsg(LED_CHILD, V_LIGHT);
                      gw.process();
                          // handle VLIGHT
                          Serial.println( "V_LIGHT command received..." );
                               // turn on led
                                  int lightState = message.getString()[0] == '1';
                                  //int newLevel = 0;
                                  lightState==LIGHT_ON   ;
                          else {
                                // turn off led
                                   lightState==LIGHT_OFF;
                                   //gw.send(dimmerMsg.set(0), true);
                    BartEB 1 Reply Last reply
                    • rsaefulR rsaeful
                      my last code:
                      #define SV "1.1"
                      #define NODE_ID 3
                      #define LED_CHILD 0
                      #define LIGHT_OFF 0
                      #define LIGHT_ON 1
                        gw.process();
                            // handle VLIGHT
                                 // turn on led
                                    //int newLevel = 0;
                            else {
                                  // turn off led
                      BartEB
                      BartEB
                      BartE
                      @rsaeful
                      better use gw.wait() i.s.o. of delay. during the gw.wait() you are still receiving and sending MyS messages. delay is blocking
                      So the function will look like this
                           analogWrite( LED_PIN, (int)(currentLevel * 2.55));
                           gw.wait( FADE_DELAY );
