  2. Feature Requests
  3. Example code - DallasTemperatureSensor.ino
8 Posts 3 Posters 3.3k Views 3 Watching
  • F
    F
    flopp
    below is copied from the example sketch.
        #if COMPARE_TEMP == 1
        #else
      gw.sleep(SLEEP_TIME);
    If I have COMPARE_TEMP = 1 it will check if the new value is new and then send it to GW, if not new it will not send to GW.
    I want data even if the temperature is same so I have COMPARE_TEMP = 0.
    With my choose it will not test if the temperature is -127.00 or 85.00, this is something I want to do all the time even if I compare or not.
    • tlpeterT
      tlpeterT
      tlpeter
      I think you just have to comment out that part of the code (the 5 lines of code)
      • F
        F
        flopp
        wrote on last edited by flopp
        I have done that in my sketch.
        But my request is that the example should always check for -127 and 85, even if the user want to compare old value with new
        • tlpeterT
          tlpeterT
          tlpeter
          In the 2.0 sketch this is mentioned:
          So 0 should keep everything working and sens info even when not changed.
            As tlpeter mentioned, the MySensors 2.0 example checks for -127 and 85 even if COMPARE_TEMP is not set to 1. See https://github.com/mysensors/MySensorsArduinoExamples/blob/e31eb10311be071d376d55d0e23133b611a565ef/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino#L96
            • F
              F
              flopp
              I am sorry, I have low knowledge of the # sign.
              I have read about it and @tlpeter is right.
              Can you confirm that my knowledge is correct.
              #else
              if I have COMPARE_TEMP = 1, this will be compiled
              otherwise this will be compiled
              Sorry once again :no_mouth:
              • F flopp
                #else
                yes @flopp you got it right :)
                F 1 Reply Last reply
                  F
                  F
                  flopp
                  @mfalkvidd
                  :dancer:
