  2. Announcements
  3. 💬 The Sensor Network
46 Posts 11 Posters 21.5k Views 10 Watching
  • RagoTubeR RagoTube
    @jkandasa Hi, thank you, I am a newbie, please advice what are the changes to be done to use Node2Node, to receive data from a sender and display on a LCD or OLED please. I am finding difficult only on the Receiver side, please help.
    With Great Regards,
    J
    J
    jkandasa
    wrote on last edited by jkandasa
    #41
    @RagoTube
    Note: I didn't test this code. I believe it should work.
    Sender node
    #define MY_RADIO_RF24
    #define MY_NODE_ID 21
    #define DISPLAY_NODE_ID 0
    #define TEMPERATURE_SENSOR_ID 0
    #include "MySensors.h"
    // triggering interval
    static const uint32_t trigger_ms = 10000; // 10 seconds
    uint32_t lastTrigger = 0;
    MyMessage msgGeneral(TEMPERATURE_SENSOR_ID, V_TEMP);
    void presentation() {
      sendSketchInfo("Temperature node 1", "1.0");
      present(TEMPERATURE_SENSOR_ID, S_TEMP, "Temperature");
      if (millis() - lastTrigger > trigger_ms) {
        lastTrigger = millis();
        // set destination address
        msgGeneral.setDestination(DISPLAY_NODE_ID);
        // get temperature from your temperature sensor
        float lastTemperature = 0.0; // update from your sensor
        // send message to display node
        send(msgGeneral.set(lastTemperature));
    Display node (Gateway node)
    #define MY_GATEWAY_SERIAL
    #define TEMPERATURE_NODE_ID 21
      sendSketchInfo("Display node / Gateway", "1.0");
    void updateDisplay() {
      // update your display with "lastTemperature"
      if (message.sender == TEMPERATURE_NODE_ID) { // message from temperature node
        if (message.sensor == TEMPERATURE_SENSOR_ID && message.type == V_TEMP) { // message from temperature sensor
          lastTemperature = message.getFloat();
          updateDisplay(); // update display
    • RagoTubeR
      RagoTubeR
      RagoTube
      Thank you so much and very kind of you. I will try this.
      • RagoTubeR
        RagoTubeR
        RagoTube
        Hai jkandasa, It works fine, thank you so much for your examples and it cleared lot my doubts. Thanks again, you have given me good start.
        • RagoTubeR
          RagoTubeR
          RagoTube
          Hi, I missed to notice that, it works as long as the Gateway is ON, when I turn off the Gateway it stops receiving the data. I assumed that your example "Node2Node" code will work with out a Gateway in between. Please advice.
          J 1 Reply Last reply
            J
            J
            jkandasa
            #45
            @RagoTube looks like we need a gateway in a sensor network and with the help of gateway node-node communication can happen. The beauty of MySensors gateway is, you can use your gateway as a node.
            I just updated my example shown here. Now the display node is a gateway node.
            • RagoTubeR
              RagoTubeR
              RagoTube
              Thanks again for your immediate advice. It should be OK now.
