  2. Announcements
  3. 💬 Infrared Sender and Receiver
45 Posts 26 Posters 25.0k Views 26 Watching
  • B
    B
    bollarcreets
    Following (I think) the instructions to the letter:
    • Using a Pro Mini
    • Installed the IRremote library (current version through Arduino Libraries Manager: 2.8.0)
    • Copied exactly the sample code
    When I come to compile, I get the following error:
    /home/pc/Arduino/IrSensor/IrSensor.ino: In function 'void sendRCCode(byte)':
    IrSensor:361:32: error: 'AIWA_RC_T501' was not declared in this scope
         else if (pIr->code.type == AIWA_RC_T501) {
    IrSensor:362:15: error: 'class IRsend' has no member named 'sendAiwaRCT501'; did you mean 'sendRC5'?
            irsend.sendAiwaRCT501(pIr->code.value);
                   sendRC5
    IrSensor:364:83: error: 'MITSUBISHI' was not declared in this scope
         else if (pIr->code.type == LG || pIr->code.type == SANYO || pIr->code.type == MITSUBISHI) {
    /home/adams-pc/Arduino/IrSensor/IrSensor.ino: In function 'void dump(decode_results*)':
    IrSensor:419:43: error: 'USECPERTICK' was not declared in this scope
               Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
    IrSensor:422:49: error: 'USECPERTICK' was not declared in this scope
               Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    exit status 1
    Am I missing something?
    E 1 Reply Last reply
    • B bollarcreets
      • Using a Pro Mini
                     sendRC5
      exit status 1
      E
      E
      evb
      @bollarcreets, I am afraid that the script has never been adapted to the evolution of the IRRemote library.
      If you take library version 2.2.3, the script will compile.
      If you take the source code from the latest version 2.8.1 you will also see that the typedef enums AIWA_RC_T501 and MITSUBISHI are commented out.
      If you want to run this example script with the latest version of the library, you will need to analyse and understand the script in order to modify it...
      B 1 Reply Last reply
      • E evb
        B
        B
        bollarcreets
        @evb said in 💬 Infrared Sender and Receiver:
        That does indeed work - thanks!
        What's the best way to get the tutorial edited to include this information?
        • B bollarcreets
          @bollarcreets I've added a note in the instructions. Please let me know if you think it could be reworded or put someplace else to make it clearer.
            B
            B
            bollarcreets
            @mfalkvidd thanks, that change is all that's needed I think. Thanks to you and @evb for the prompt help!
